gmookher
Old 02-02-2013, 03:44 PM   #281
reeves
Originally Posted by Black Tire View Post
2. Try Amsoil 75W-90 GL-4 MTF for spring-summer-fall transmission duty (O.K., I'm a real Amsoil fan so I would really like to try this myself) that will include track use, and Amsoil or Motul in the differential. I think I may change to Pentosin for next winter.
I'm an Amsoil fan as well, and I tried their 75W-90 tranny fluid before trying the Pentosin. It was slightly better than stock feel-wise, but it was still stubborn shifting into 2nd when cold.
And by cold, I don't mean outside temperatures either.. On a cold startup in the morning during fall season (60-70 degrees), I still had issues shifting into 2nd with Amsoil. Pentosin is the only fluid so far that let me shift into 2nd with no resistence (most of the time).. even in sub-freezing temperatures.
I think the grinding is probably bushing-related too.. I may try that next when I get the time/money to do it.
The Following User Says Thank You to reeves For This Useful Post:
Black Tire (02-07-2013)
Old 02-02-2013, 11:12 PM   #282
bpracer
Drives: Asphalt FR-S
I'm a month in to using Pentosin and so far, no problems. Still very slick shifting and better on cold mornings to get in first and second gear.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 02-03-2013, 10:33 PM   #283
FRSRAVEN
Just did a transmission fluid swap. I live in central Texas, and though it doesn't get extremely cold, I have had some 20 degree starts in the last month or so, and shifting at these temperatures is abysmal. Furthermore, cold shifting in general, even on warm days, was sub-par.
I replaced the factory fluid with Amsoil MTF. MTF is a synthetic 9cst fluid designed for manual gearboxes that prefer a thinner fluid. Typical 75w-90 gear oil will be around 14cst at operating temperature. Pentosin is around 7cst at operating temperature.
I went with the Amsoil fluid because I felt it would be thin enough to provide adequate cold shifting performance, but thick enough to offer some protection during the summer time. Additionally there is a local supplier who stocks it, and it was actually cheaper then most of my other local alternatives.
Observations:
Immediately shifts were smother. First and second gear glide into place, and third gear no longer makes an uncomfortable crunching sound. Once warm, shifts remain positive, yet smooth. Not all of the notchiness is gone (a good thing), which means there is still that sensation that you are operating something mechanical, however there is no longer resistance to go into gear that was common on cold starts, and the synchros don't feel like they are cannibalizing themselves.
Overall I'm very pleased, especially considering the swap only cost $30. I'll report back after I get my first really cold morning, but so far so good.
While I was under the car, I also replaced the differential fluid with Amsoil Severe Gear 75w-90. I did this to remove break-in contaminants from the differential (of which there were many), and to see if I could rectify the binding sensation I perceived when going around tight corners at low speed. Additionally I would get a little bit of chatter under certain driving conditions.
Initial impressions so far are good. I no longer feel the binding when going around tight turns. However I'll hold off on a final verdict until I rack up some more miles.
The swap was worth it simply due to the amount of iron contaminants I removed, even with only 2k miles on my car. I was surprised, very surprised.
The magnetic plug on the diff was completely soiled. Even the magnetic plug on the transmission was heavily soiled. Anyone considering a fluid swap, I suggest it simply to remove break in wear from the diff and gearbox.
I changed my oil on the same day. Nothing special to note, other then the torque on the oil filter from the factory was absurd.
FRSRAVEN is offline   Reply With Quote
Old 02-04-2013, 02:12 PM   #284
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
Everyone has had this same experience.
First thing to do is let friends know: get the inferior fluids out of the trans and diff!
I wouldn't be surprised if our automatic equipped friends have similarly poor ATF as factory fill... That will get ugly in a few years.
Esoteric is offline   Reply With Quote
Old 02-06-2013, 12:29 AM   #285
Esoteric
Esoteric's Avatar
Originally Posted by fenton View Post
Hey Esoteric,
I just put a order in on your website, it gave me a option to ship to Canada so i went ahead with the order.
You guys do ship to canada right?
Look for your package in the mail soon
Let us know how you like it!
The Following User Says Thank You to Esoteric For This Useful Post:
fenton (02-07-2013)
Old 02-07-2013, 08:58 AM   #286
Sargy
Long Distance Driver
Sargy's Avatar
1-2 cold always feels rough, but it's definitely 2-3 where I'm getting the "click" sound. Hm...might have to look into Pentosin at some point.
Drive my car for reference next time we see each other
Sargy is offline   Reply With Quote
Old 02-07-2013, 09:30 AM   #287
OrbitalEllipses
Drives: Attitude
Running Pentosin right? The 2nd gear crap only happens when I leave it outside overnight. Otherwise, just the occasional 3rd gear "click" and 5th gear harshness.
Old 02-07-2013, 10:05 AM   #288
Sargy
Sargy's Avatar
Correct.
Old 02-07-2013, 10:07 AM   #289
OrbitalEllipses
Drives: Attitude
Correct.
Symptoms of misbehaving gearbox before fluid flush?
Old 02-07-2013, 10:25 AM   #290
Sargy
Sargy's Avatar
Correct, it was much easier to miss gears because of slight lock ups and crunches, the joys of driving it blissfully was killing me with that. the 2nd gear crunch, third gear and 5th gear.
It gets better every day but on day one after the change I began to laugh when I drove off into 2nd on a cold cold cold morning. It just feels right.
Old 02-07-2013, 10:30 AM   #291
OrbitalEllipses
Drives: Attitude
Thanks a lot @Sargy! I guess I'll take it to the dealer and request fresh "approved" fluid to see if that helps. I want this done under warranty before I use a different viscosity fluid.
Sargy (02-07-2013)
Old 02-08-2013, 12:05 PM   #292
sid325
Drives: Ultramarine FR-S 6MT
Anyone using Pentosin have any additional long-term feedback? I'm about to pull the trigger. My 2nd gear is useless below 50 and 3rd is notchy going in. I thought it might get better with use, but not very hopeful.
Thanks
sid325 is offline   Reply With Quote
Old 02-08-2013, 01:17 PM   #293
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
This thread is amazing op is the best. Ordered 3 liters. Much obliged!
bdanisi is offline   Reply With Quote
Old 02-12-2013, 02:48 PM   #294
luuser75
luuser75's Avatar
Drives: M/T Raven FR-S
how hard is it to replace the fluids yourself? i'm calling shops and they're charging a good amount for labor since i already have the fluids and washers...
luuser75 is offline   Reply With Quote
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 06:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 09:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
