Old 02-06-2013, 09:11 PM   #1
frs_firestorm
Drives: 2013 FRS
Looking for a place to install lowering springs in DFW area
Anybody know a reputable shop to install lowering springs in DFW area.
Any recommendations? and expected cost?
THX.
frs_firestorm is offline   Reply With Quote
Old 02-07-2013, 05:16 PM   #2
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
The only two shops I have used and personally trust would be Evolution Dynamics in Lewisville (the shop is owned by a mechanical engineer who used to work at Lockheed Martin), and Texas Track Works in Fort Worth. TTW specialize in suspension setups and have an on-site alignment rig.
-Acree
Acree is offline   Reply With Quote
Old 02-07-2013, 06:54 PM   #3
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
Do them yourself and save that cash, did my eibach prokit and theres good DIY on here. After, drive it a bit to see if you need an alignment, check for vibration, check if it pulls left or right and if no real problems then it'll be fine if you just daily drive. But if you track or drift your car an alignment is needed, but you'll also need camber bolts too.
ericvanderwoodsen is offline   Reply With Quote
Old 02-08-2013, 12:20 AM   #4
Do Boy
Turbo FR-S
Do Boy's Avatar
Send a message via ICQ to Do Boy Send a message via AIM to Do Boy Send a message via MSN to Do Boy Send a message via Yahoo to Do Boy
THX.
I would check with AWDTuning. They do great work
Do Boy is offline   Reply With Quote
Old 02-08-2013, 04:51 AM   #5
cf6mech
Drives: FRS Silver LS1 swapped.
SECOND ON AWDTUNING. Probably the cheapest as well.
cf6mech is offline   Reply With Quote
Old 02-08-2013, 03:13 PM   #6
frs_firestorm
Drives: 2013 FRS
Thank you guys for the recommendations. I will give them a call today.
considering RCE or swift springs.
both will drop the car about an inch.
is the camber bolt absolutely necessary for an inch drop?
Old 02-08-2013, 03:27 PM   #7
Acree
Acree's Avatar
No but an alignment is. Texas Track Works does unlimited annual alignments for less than $200. They have a guy working there who used to create camber plates for Vorschlag. He dialed in my Evo IX perfectly.
-Acree
Old 02-16-2013, 12:55 AM   #8
Hachi-roku
Hachi-roku's Avatar
Drives: 2015 Subaru WRX
Hey I reminded my cousin about you. He said he's been busy working on other car. He said to call him again and he will let you know.
Hachi-roku is offline   Reply With Quote
install, lower, spring
Racecomp Engineering Yellow lowering springs install special! Racecomp Engineering Mid-Atlantic 12 12-17-2015 01:34 PM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 02:39 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
Lowering springs HELP FRS_13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-27-2012 10:03 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-10-2012 11:36 PM
