Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 02-06-2013, 06:27 AM   #127
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Menlyn Mcarthy told me bring your own oil we dont have anything on our system
GeeTee86 is offline   Reply With Quote
Old 02-06-2013, 06:48 AM   #128
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
That is actually worrying - so when it's time for the 15000km service, do they expect US to supply THEM with oil at OUR expensive? Fat chance of that happening...
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 02-06-2013, 06:50 AM   #129
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
Very worrying... I'd love to hear Toyota SA's response about what Menlyn had to say... Mccarthy Bruma knew about the oil! And they said they would only order if a car was pre-booked for service.
Vic_RSA is offline   Reply With Quote
Old 02-06-2013, 06:51 AM   #130
Mike Hoxbig
Mike Hoxbig's Avatar
Not going to happen with me. I don't mind paying for consumables, but they need to supply it. I'm not taking responsibility for anything breaking due to it.
Mike Hoxbig is offline   Reply With Quote
Old 02-06-2013, 07:12 AM   #131
GeeTee86
86 Nut
GeeTee86's Avatar
Exactly Mike. It's one thing to tell me to bring my own oil. Luckily I know a little bit about oil, but, what if I was a woman and bought SAE60?
Old 02-06-2013, 07:16 AM   #132
GeeTee86
86 Nut
GeeTee86's Avatar
Liqui Moly Oil guide:
4600 Density 0.855 Viscosity Index 178 @40degrees 64 @100degrees 11.6
4200 0.855 160 71 12.3
I have Special F
0.850 177 53 10.0
Old 02-06-2013, 07:56 AM   #133
Vic_RSA
Vic_RSA's Avatar
I was thinking a (uneducated and ill-informed - don't generalise! ) woman would go with a can of the best, good old GTX 20W50... Protects the hell out of your engine (if it was made 35y ago)...
Old 02-06-2013, 08:04 AM   #134
GeeTee86
86 Nut
GeeTee86's Avatar
Yah haha. They don't makem like they use to! (in this case a good thing!!)
Old 02-06-2013, 09:00 AM   #135
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
Hi Guys
This is just some info for those that don't know much about oil. The numbers on the oil grade is the viscosity of the oil when it's cold and hot. (5W30) The lower the number the colder temp it can handle.
We don't have heavy minus temps here in SA, hence the 5W viscosity is better suited to our climate. We have hotter days than Japan, and Europe hence the 30 instead of 20.
Remember to keep your oil level above the minimum mark else their is insufficient oil to lubricate your engine properly.
Do not overfill above the max mark else you will just end up burning away the excess oil (car will smoke).
Check your oil when the car is cold. Can be warmish, but not hot, else the oil level will give a higher than expected reading.
Car must be on a level surface.
Razzle is offline   Reply With Quote
The Following 3 Users Say Thank You to Razzle For This Useful Post:
CzechZA (02-06-2013), Gp1666 (02-11-2013), Vladror (02-06-2013)
Old 02-11-2013, 05:22 AM   #136
RueFT86
Drives: Toyota FT86
Guys - who has done there first service already on the 86's - 15 000kms.
Firstly which dealership did you go to and how was the service.
I'm a bit sceptical of taking the 86 to any dealership so I need some insight please.
RueFT86 is offline   Reply With Quote
Old 02-11-2013, 05:49 AM   #137
v3rgil
Drives: Toyota 86 Black (Standard)
Toyota Secunda,
they where the 1st to repair the stall and spatter issue by replacing my Cam Gear, they had to remove the entire front of the car and drain the oil to remove the cam-chain cover.
6000km further and no issues
v3rgil is offline   Reply With Quote
Old 02-11-2013, 07:25 AM   #138
Vic_RSA
Vic_RSA's Avatar
I think the first step is to phone the service manager at your proposed dealer and ask how many 86's they have serviced. I'm about 6900km away...
Old 02-11-2013, 07:48 AM   #139
KapteinBos
KapteinBos's Avatar
Drives: Toyota 86, Pearl White, Manual
McCarthy Midrand had none before mine about 3 weeks ago. mine was just a oil change though...
KapteinBos is offline   Reply With Quote
Old 02-11-2013, 08:05 AM   #140
GeeTee86
86 Nut
GeeTee86's Avatar
I did an oil change at Barlo Menlyn, it was the first in their shop
