Old 02-05-2013, 06:14 AM   #155
keen as
keen as's Avatar
Drives: 86 GT MT
My oil temp shows no data. !!!!!!!! Can anyone help?
When i follow the instructions for the custom PID and input the details to set up the oil temp, I don't have an option for OBD header. Is this important? Why doesn't my Torque app have it. I am using a cheap LG phone with android 2.3.
Also, when I restart my Torque app, it has deleted the custom PID.
Many thanks, great thread.
keen as is offline   Reply With Quote
Old 02-05-2013, 07:48 AM   #156
andreyiv
Drives: Hot Lava FR-S
It's probably because you can't enter the ODB header. I just checked and it looks like the free version of Torque (Torque Lite) doesn't have a field for OBD header like you are describing. Didn't realize it before but it seems that this PID may only work with the paid version (Torque Pro). Maybe try that? I did experiment with different OBD headers and the only two that worked for me were 7E0 and Auto, leaving it blank resulted in no data.
Hope this helps.
Andrey
andreyiv is offline   Reply With Quote
Old 02-05-2013, 03:57 PM   #157
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
The mods have concluded that there is not enough information at the moment for the thread to be worry of a sticky, although maybe once we reverse engineer more PID'S they will sticky it
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 02-05-2013, 04:01 PM   #158
Yruyur
Yruyur's Avatar
Ill do a screen shot of ecutek tonight to see what data it pulls so we can compare to torque to see what else we should get.
Old 02-05-2013, 04:06 PM   #159
keen as
keen as's Avatar
Drives: 86 GT MT
Hope this helps.
Andrey
Thanks Andrey, bought Torque Pro, it works fine.
Thanks again for your help.
Old 02-05-2013, 04:24 PM   #160
keelerad
keelerad's Avatar
Drives: Silver Manual Toyota GT86
Talking Oil temp video
Got it working (thanks Andrey) and did a video when trying it out (sorry about the shaky mount for the Nexus 7)
[ame="http://www.youtube.com/watch?v=bXgm4KQjVwU"]catandfiddle2 - YouTube[/ame]
This is the A537 to the Cat and Fiddle, in the Peak District National Park, England.
https://maps.google.co.uk/?ll=53.252...54324&t=m&z=13
Alec
keelerad is offline   Reply With Quote
Old 02-05-2013, 05:01 PM   #161
Brody602
Drift King
Brody602's Avatar
Torque Pro has quite a bit more to offer compared to the lite version, and it's relatively cheap for what you can do with it, in my opinion the developper deserves the money, he's constantly pushing oit new updates to accommodate newer vehicles etc, he has done an amazing job with the app.
Cheers,
Brody
Old 02-06-2013, 02:05 AM   #162
pkny
Drives: Firestorm FR-S 6MT
Converting the torque code to xgauge code
Thanks, Andreyiv.
I am trying to convert your code to xgauge code. This is what I got so far:
TXD 07E02101
RXF 056106010000
RXD
MTH 00010001FDD8
I am trying to figure out the location of AC, and then I looked at elrod’ scan result:
Command: 2101 response:01F
0:61 01 00 00 00 00
1:55 64 46 3E 64 3F 00
2:00 00 00 00 0D 2B 55
3:21 20 00 43 06 CD 09
4:63 2F C9 3E 00 00 00
It looks like the bold parts are the A and C, but they aren’t.
Can anyone give me the response when sending 2101 and the corresponding oil temperature? Thank you.
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
Old 02-06-2013, 06:23 AM   #163
GT86vs944
GT86vs944's Avatar
Drives: Toyota GT86, Porsche 944, BMW e30M3
Hi There,
I followed this thread now for quite a while because I built a Torque theme for the German GT86Drivers Community. Becuase Anreyiv found out the PID of the Oiltempratur I now included it into my theme and released it as an RC1.
  • You can find my metric theme here: Toyota_GT86_Theme_RC1.zip
    To use it you just need to extrackt the zip-file into the \.torque\themeDir folder. The folder might be hidden, so make sure your filebrowser shows also hidden files.
  • I also uploaded my dasbord:Toyota_GT86_Dashboard_metric_RC1.dash
    Put this file into the folder \.torque\dashboards\, then start Torque and got to "Realtime Information" > "Settings" choose "Layout Settings" and import the Layout/Dashboard.
At the moment I use three screens. They look like this:
My Setup looks like this:
I just have to figure out how to connect the phone to a charger, because Torque needs a lot of power...
If you got any questions don't hesitate to ask.
Have fun & Drive Safe,
Michael
GT86vs944 is offline   Reply With Quote
Old 02-06-2013, 07:54 AM   #164
andreyiv
Originally Posted by pkny View Post
Thanks, Andreyiv.
TXD 07E02101
RXF 056106010000
RXD
MTH 00010001FDD8
0:61 01 00 00 00 00
Figuring out AC was actually what took me the most thinking and was the most frustrating. In the scan you provided it's value 3E (22 degrees C) on the line that starts with 4:. Torque seems to work the same as Excel, one past Z is AA, two is AB and so on.
Hope this helps.
Andrey
Old 02-06-2013, 08:38 AM   #165
Brody602
Drift King
Brody602's Avatar
@GT86vs944 if you like, i can add your gauge design to the OP, also maybe a suggestion since there is a lot of people using the imperial system on these forums maybe make a set that say mpg instead of l/100km?
-Brody
Old 02-06-2013, 09:42 AM   #166
GT86vs944
GT86vs944's Avatar
-Brody
You're right, I haven't really thought about that, but it is not a big deal to change that. So I created a non-metric Torque Layout for the GT86. Sure, you can add everything to the OP, would be nice to maybe state my nickname
The screens now look a little different because theres only MPG and no GPM option in Tourque (at least as far as i have seen. So i put die 0-6mph and the 1/4 mile time on the "home screen".
Old 02-06-2013, 01:34 PM   #167
so26
Drives: Raven FR-S 6MT
Is there anyway of detecting knock with torque pro?
so26 is offline   Reply With Quote
Old 02-06-2013, 01:40 PM   #168
Brody602
Drift King
Brody602's Avatar
If you have torque pro you can run the knock detector plugin; https://play.google.com/store/apps/d...kills.kd&hl=en
I havn't tried it though, but it has a good rating so I'm sure it works well
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
