View Poll Results: What FT-86 wheel size do you want to see on production version?
15 inch 4 3.51%
16 inch 16 14.04%
17 inch 56 49.12%
18 inch 31 27.19%
19 inch 7 6.14%
Voters: 114. You may not vote on this poll
Old 01-08-2010, 05:10 PM   #113
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
hahaha, I always pointed out to people that my old corolla has an oil cooler from the factory. It always surprised them. Well, it did before the car got really well known around here. Before that, to most people, it was just an old corolla. The RWD comment stumped a Cop once too when he pulled me over. Annyyywhooo...
I expect the "competition" model will have one as well. I not too worried about the brakes either. The 4-wheel disc on the AE86's are more than enough to stop the car, albeit, you definitely get a bit of fade goin' on after some heavy stopping. It'll be interesting to see just how large the rotors will be. Also, with them having drifting in mind when it comes to this car, I'm kinda interested in knowing how biased the braking will be in favor of the front.
OldSkoolToys is offline   Reply With Quote
Old 01-08-2010, 06:09 PM   #114
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
lol yeah other people was wowed up about a 86 having a oem oil cooler and optional LSD I tell them yes toyota made sure this little car will be ahead of its time.
brakes are one of my most have, more than more power I rather have more stopping power, here my solution on my AE86. Its a RX7 4 piston calipers on a Acura GSR rotors, w/ a brake booster & brake master cylinder w/ earls steel brake lines.
o yeah my plans for ft86 on brakes will be 6 pistons AP carbon pads & sloted rotors
4agze is offline   Reply With Quote
Old 01-08-2010, 10:16 PM   #115
Axel
Axel's Avatar
Drives: '13 BRZ
great looking disks & wheels!!
Axel is offline   Reply With Quote
Old 01-08-2010, 10:55 PM   #116
4agze
4agze's Avatar
wheel was sold already, it was ok i switch to 15x8 -3
Old 01-17-2010, 04:51 AM   #117
Lexicon101
Inexperienced
Lexicon101's Avatar
Drives: Crappy old '90 civic. Frankie.
Originally Posted by scape View Post
i'd personally prefer wider tires and a slightly taller sidewall than what they showed, and come down to 16" (i voted this) or 17" diameter.
maybe 235/40 or 245/40, of course the total diameter would have to be pretty close to the stock size, but I don't mind going a bit under
The first number is the width in millimeters. The second number is the ratio of height to width. A 245/40R16 will have a 98MM tall sidewall. A 225/40R19 will have a 90MM sidewall. The difference in sidewall is relatively small, and the total height of the wheel from ground to the top of the tire on those 16's would be 602.4MM or 23.7", while the total height of the wheel on the 19's would be 662.6MM or 26"...
Your speedo will be fucked up.
(All of this is to say.. if you do plan on this change in wheels, make sure to get things adjusted.)
Lexicon101 is offline   Reply With Quote
Old 01-17-2010, 12:42 PM   #118
RegisBou
Drives: Scion xA, Toyota MkI Mr2 (Sold)
This is specifically my concern.
but a 45 or 50 on a 16 shoudn't be to bad as long you get re-111's...or any performance tire for that matter if they are really a performance tire. they have super mega stiff sidewalls that will flex a little at those hieghts in terms of rubber stress. But a little bit of flex is good i think. Not like my all-season tires though...the car dips hard when the sidewall gives out O_o
RegisBou is offline   Reply With Quote
Old 08-12-2012, 12:06 AM   #119
MattyJ
MattyJ's Avatar
Drives: FT-86 GTS, R34 GT-T
ordering a set of Volk 19" te37's .. dayum!!
MattyJ is offline   Reply With Quote
Old 08-12-2012, 12:19 AM   #120
chuy21
Drives: 2009 Cobalt SS 373 FWHP 431 Lb-Ft
You had to revive a 2 year old thread?
chuy21 is offline   Reply With Quote
Old 08-12-2012, 01:10 AM   #121
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Wheel width probably should have been included.
17 x 7.5 or 8 to accommodate wider tires better.
CircuitJerk is offline   Reply With Quote
Old 08-15-2012, 01:57 AM   #122
MattyJ
MattyJ's Avatar
Hehehehe
Us aussies downunder are the last to do anything .. but have the most fun!
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 01:23 AM
No Subaru FT-86 for Australia! And currently no Subaru AWD version production plans. Edi BRZ First-Gen (2012+) — General Topics 103 10-27-2009 03:27 PM
