Old 02-05-2013, 02:32 AM   #99
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Originally Posted by g0lden View Post
Even if others claim it to be easy to remove the front bumper, It still seems rather time consuming just to get to the filter for cleaning.
I'd rather another version that doesn't pass through the frame, and stops before it :-)
Then get one...don't think that it will be a TRUE cold air intake though, because every intake so far that stops before the frame sucks in hot air from the engine bay even if the nozzle is pointing into the gap over the radiator. @2forme has done testing that proves this.
The Perrin is a TRUE cold air intake, it sucks air from in front of the bumper BEFORE it gets to the radiator. While the Airaid, aFe, Injen and other similar designs all just pull air mainly from the engine bay. This ends up with warmer intake air temps.
So I really don't understand why people are coming into my review thread complaining about removing the front bumper. I've said from the VERY beginning that if you aren't comfortable with removing your bumper then this intake ISN'T for you. By all mean's get the aFe intake...it's a good intake that is easy to install...but don't expect the performance gains and response of a true cold air intake like the Perrin, FA20Club or VMS intake. It's apples to oranges, so I don't know why people are attempting to compare the two. They are for two different types of enthusiasts so get whichever one you prefer.
"Let me preface that this install is FAR more involved than your average intake. If you're looking for something you can remove easily and return to stock within a short period this intake is not for you."
First sentence from my "The Installation" section in the first post of this thread.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
*KID* (02-05-2013)
Old 02-05-2013, 06:31 AM   #100
FR-S Matt
Once you remove the bumper once, you understand it and it becomes easy. It's removing it for the first time. Actually, just removing the bumper to clean the filter is pretty easy once it is installed. 10 plastic clips in the fenders, 6 under the bumper and two silver screws, with two plastic clips on the top and 5 bolts. Might take me about 10 minutes now that I know. I love working on my car, so I have no issue with it. The Perrin is probably the best designed/looking CAI currently and I love mine.
The hardest part I had of the install was getting the filter to stay on. It sits a bit funny on the tube and you have to carefully tighten it.
Nice gains on that dyno with it.
Old 02-05-2013, 06:47 AM   #101
brufleth
Drives: 2007 WRX
Getting the bumper reseated on my car is a massive headache. Even after several attempts by experience body work guys it doesn't sit quite right on one corner. It is very easy to run into problems when you start playing with soft plastic parts that need to line up just right with metal parts.
brufleth is offline   Reply With Quote
Old 02-05-2013, 08:05 AM   #102
FR-S Matt
It just snaps back in right where it went. You start from one side carefully and move to the other. The worst part is messing with the stupid plastic clips which is an entire reason why I'll be buying push pin pliers. It's easy to damage the clips since they bend easy. Had no issues lining up the screw holes for the two silver bolts on the bottom. It's all worth it once you see how awesome this intake looks, sounds, and the way it drives.
Old 02-05-2013, 08:54 AM   #103
2forme
My temperature testing has shown that the AFE is also a cold air intake. I will do testing on Sony's car as soon as the weather permits then post a comparison graph showing temperature delta.
The Following 2 Users Say Thank You to 2forme For This Useful Post:
sierra (02-05-2013), Tylub (02-05-2013)
Old 02-05-2013, 10:06 AM   #104
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
@Sony
Good review and pictures. Thanks for sharing.
Fyi, your name and address can be seen in the first picture. Could be a privacy concern.
F1point4 is offline   Reply With Quote
Old 02-05-2013, 12:47 PM   #105
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Originally Posted by Sony View Post
Yea... unfortunately gmookher has given Perrin a bad rap on the forum. They make good stuff, and it's sad because gmookher wasn't even a Perrin rep or anything...he was just an a**hole who liked Perrin products...
I try not to be an jacka**...I hope I succeeded.
Yeah, but even after gmookher, I still like my perrin products
and I'm looking forward to this intake as well with the hose inlet combination because I like the idea of a true cold air (after the whole airaid incident).
And to anybody uneasy about removing the bumper, It's very simple and only takes me 5 minutes give or take. it's only a few bolts and clips
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 02-05-2013, 12:52 PM   #106
Tylub
Tylub's Avatar
@Sony sorry to bring in another intake question but how would you think the vigilant CAI would compete? both have somewhat the same design.
did you say the perrin intake was aluminum? concerns with "heat soak" I don't really care because i bet it sounds better than a plastic body
instagram @Tylub
Old 02-05-2013, 12:53 PM   #107
FR-S Matt
It is coated aluminum. Looks and feels pretty resistant.
Old 02-05-2013, 12:55 PM   #108
2forme
Coated aluminum still heat soaks really fast.
Old 02-05-2013, 12:59 PM   #109
FR-S Matt
Yeah, I'll see how well it performs here when it's 100+ in the summer. The tube heating up I'm not so worried about. The filter pulling the air not sitting under the hood is what I was more concerned about.
Let me know when you get those results for the temperature testing!
Old 02-05-2013, 01:02 PM   #110
2forme
No problem. The coolest (read, while driving with plenty of air flowing) the AIRAID got was 15 degrees above ambient. AFE managed 8 or so. I'd imagine this would be in the ballpark of 6-7. Like I said, just gotta wait for the weather to clear up.
Old 02-05-2013, 01:13 PM   #111
Tylub
Tylub's Avatar
well anything's better than AIRAID.. i'll be waiting for your results
Oh man you're from maryland? when I went over for christmas it was snowing for a bit. MAN i missed the california heat when I was over there lol
instagram @Tylub
Old 02-05-2013, 01:56 PM   #112
2forme
Maryland? LOL MA = Massachusetts.
PERRIN Silicone Intake Duct Review JoeBoxer Engine, Exhaust, Transmission 287 01-24-2018 10:01 PM
Perrin Catback Exhaust Installation and Review! Sony Engine, Exhaust, Transmission 316 01-24-2016 01:01 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 12:56 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 04:58 PM
