Old 02-04-2013, 06:06 PM   #43
plucas
plucas's Avatar
Drives: Subaru
Originally Posted by robispec View Post
SO here are some picts and info on our SUPER HEAVY DUTY COLLING UPGRADE
we are ready to go to market with these this week.
At Robispec we are fans of extra credit work and so we went to an "overkill cooling solution" stock radiator is 15mm core we replace this with 2 25mm tube core add a liquid to liquid oil cooler in the "cold side tank" and have less than 2 feet of total lines to complete the whole "kit".
The best thing about this is that you dont need to thermostaticly control the oil temp (a big potential problem with the Air to liquid cooler solutions) as the water thermostat does this for you and actually heats the oil faster during warm up then stabilizes it to run about 20-30 degrees hotter than the water temp. this is better in many ways than the current kits on the market.
1. lighter overall
2. short hose runs,minimal resistance to flow = no extra strain on the stock oil pump
3. "fixes" the Water cooling issues sure to develop with the stock radiator.
4. Uses existing cooling airflow and leaves fender locations for brake ducting
5. With low profile fans ADDS space in front of the engine for turbo/SC piping
can use stock A/C with this.
NO cutting plastec to mount
Cold air over the top as needed
STOCK mounting points used
OVER TRIPLE THE COOLING CAPACITY and an extra Qt of engine oil.
takes 2 hours to install
total system cost Radiator oilcooler takeoff plates hoses, an fittings, fans
EVERYTHING INCLUDED for John Q Public to install $1,195.00
Look for the group buy to save money on the first ten of these.
Robi
That is not a Nascar core btw.
plucas is offline   Reply With Quote
Old 02-04-2013, 06:29 PM   #44
robispec
Drives: Black frs project
This core is used in the NASCAR sanctioned events across the country in the asphalt modified division...I agree with you is is not a C&R 2500.00 radiator for the "show" on tv. Still nascar guys I agree it is tripple "A" ball, but still the same sactioning body. It has almost the same air resistance as the stock radiator and frontal area, has 2 25mm tubes in place of the single 18mm tube of the stock radiator. My cars fans used come on all the time now they never switch on...so we must be doing something right and oil temps dropped DRAMATICLY.
robispec is offline   Reply With Quote
Old 02-04-2013, 06:41 PM   #45
plucas
plucas's Avatar
Drives: Subaru
It is just a little misleading imo to say it is a nascar core. The technology and quality of cores in nascar is way different than the ones in nascar sanctioned events.
Not trying to hate, just don't want people being accidentally mislead.
Old 02-04-2013, 06:52 PM   #46
robispec
agreed. I'm not trying to mislead people either. But People need to understand that the term "nascar" can cover your local every other friday night dirt 1/2 mile series up to to Daytona. If someone is paying 1200 for a radiator with a heat exchanger fans and wiring built in small #'s and thinking they can bolt it into Jeff Gordons car I think they are misleading themselves.. that said These "cores" routinely cool 650 HP v8's haulling around 3000 lb cars...
Old 02-04-2013, 09:44 PM   #47
DEnd
Drives: anyone seen my steering wheel?
Really?
It's a friggin Radiator. Sprint Cup guys don't run anything "special."
DEnd is offline   Reply With Quote
Old 02-04-2013, 09:55 PM   #48
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Thumbs up to this build and two thumbs up to the radiator/oil cooler combo. Looks like it would make any N/A car bulletproof on the track, and any FI car it would keep temps under control and be a great mod for durability.
The Following User Says Thank You to ATL BRZ For This Useful Post:
*KID* (02-05-2013)
Old 02-04-2013, 09:59 PM   #49
plucas
plucas's Avatar
Drives: Subaru
Originally Posted by DEnd View Post
Really?
Have you seen one up close? Compared them to others? It is not "just a friggin radiator"...
There is is huge difference in quality from the average aftermarket core... But I am sure you are a heat exchanger specialist
Awesome car overall man. I like people who focus on the important parts of cars like handling
Old 02-04-2013, 10:32 PM   #50
wootwoot
Drives: FRS
Any idea when the radiator/oil cooler will be available?
Old 02-04-2013, 11:55 PM   #51
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
nice car Robi glad to meet you at the dyno day!
-Randy
Evasive Motorsports is offline   Reply With Quote
Old 02-05-2013, 12:04 AM   #52
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Well I happen to be a huge NASCAR fan and seen a couple sprint cup cars built.. And know that C&R racing incorporated custom builds the cores and tanks to each teams specs.. But any one can order a custom built core from the, if you have the cash, as the ones for say restrictor plate racing at Daytona or talladega are not the same as say like Bristol or even Michigan.. And I've seen very very very expensive rads...
http://www.crracing.com/radiators
And just because it isn't sprint cup, doesn't mean it's not NASCAR.. Even the Canadian tire series is now a NASCAR sanctioned event.. It even owns grand-am now
[ame="http://en.wikipedia.org/wiki/NASCAR"]NASCAR - Wikipedia, the free encyclopedia[/ame]
Gixxersixxerman is offline   Reply With Quote
Old 02-05-2013, 02:57 AM   #53
robispec
-Randy
thanks nice to see your shop!
any Idea what the highest dyno # was on the NA cars? I got 179/145
and was the highest at the time.
Robi
Old 02-05-2013, 08:04 AM   #54
DEnd
The main difference between an average aluminum aftermarket radiator and one used in sprint cup cars is that the sprint cup radiators are sized specifically for each track and engine, though probably less so since NASCAR reduced the size of the radiator allowed. But there really isn't a huge quality or technology difference between what you can easily get in the aftermarket (though not all aftermarket radiators are equal), and what the big guys run.
Old 02-05-2013, 06:01 PM   #55
wootwoot
Drives: FRS
Would this type of unit over-cool the car in a street/track application?
Old 02-05-2013, 06:27 PM   #56
EarlQHan
Drives: Subarus
i've seen the cores in person, they're quite different. plucas designs those sprint car radiators as a day job. i don't think he needs you to tell him what his job entails
EarlQHan is offline   Reply With Quote
Canu_50's FR-S Time Attack, drift car!! canu_50 Member's Car Journals 28 12-05-2013 02:04 AM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
Ontario Time Attack - upcoming events 6, 7 and 8 7thgear CANADA 1 07-12-2012 02:29 PM
Ontario Time Attack - TMP July 7th 7thgear CANADA 8 07-07-2012 06:14 PM
FT86c Drift & Time Attack Races in GT5 ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 153 06-25-2011 05:53 PM
