Old 11-23-2012, 02:48 AM   #1
robispec
Drives: Black frs project
Robispec's Ride Black FRS Time Attack Mule
OUR DETAILED BUILD THREAD IS RIGHT HERE
http://www.ft86club.com/forums/showthread.php?t=28180
For those who don't know who or what Robispec is, we are a chassis shop that takes pride in making cars handle better than stock, have consistant handling charactristics, and allow the cars driver to have more feedback before things get outta control.
This is what we have done so far.
Lowered the car 3" with a combination of tire size and custom suspension components that yield stock camber gain curves,lowered Center of gravity, corrected roll center, bump steer and stock travel on the suspension (though we do change the compression vs droop limits).
I was able to take the car to the local dealer and get side by side shots. We also had it out to the Redline time attack but showed up late and ran in the rain shower session...I did have a member here drive the car and get his impressions He can chime in if he wants to.
picts
Front view
yes those are louvers to keep the car cool. the stock hood is lighter than any aftermarket hood sofar.
nose to nose
and
rear view
robispec is offline   Reply With Quote
The Following 3 Users Say Thank You to robispec For This Useful Post:
ScionFamily (01-20-2013), Turbowned (01-22-2013), Wolfking (11-23-2012)
Old 11-23-2012, 03:04 AM   #2
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Looks a great, but a little too low for me. It also appears that it will fail to traverse any speed bumps!
Wolfking is offline   Reply With Quote
Old 11-23-2012, 03:46 AM   #3
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
been waiting for this post ever since I heard rumblings of you guys getting a car. Verrrrrry excited~
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 11-23-2012, 03:53 AM   #4
robispec
Thanks we also have a HUGE radiator in the stock location with a included oil cooler..and still have the AC condensor working (we live in the desert too). stock radiator is 5/8" core (yes you read that right)..the new one is 2.5" Nascar core...car weights now 2525. looks stock inside and out..
Going for 2450 with the next round of modifications.
Robi
Old 11-23-2012, 07:30 AM   #5
ML
ML's Avatar
Drives: 13 White MT FR-S
Any info on the exhaust? Looks interesting
Old 11-23-2012, 08:28 AM   #6
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Robispec!!!
I met you here here while you were here in Dubai a few years back working on the Touring cars & stuff...one word...awesome!
Curious to know what bits you stuck on the car to oreserve the geometry at that height, which dampers you're running (assuming Robispec KW V3s), what you're doing for aligment....in short...everything you care to share!
Glad to see you on here & will be watching your development work.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 11-23-2012, 09:21 AM   #7
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Robi
Do tell, Robi, do tell...
GTB/ZR-1 is offline   Reply With Quote
Old 11-23-2012, 10:44 AM   #8
GMASTER6
GMASTER6's Avatar
Drives: Toyota GT86
I'd like to see that FR-S when it's completed:happy0180:
GMASTER6 is offline   Reply With Quote
Old 11-23-2012, 11:03 AM   #9
ebphoto
Drives: FR-S, NA8, S13
usual custom spec kw's?... super interested in suspension and cooling setup you have.
ebphoto is offline   Reply With Quote
Old 11-23-2012, 11:46 AM   #10
robispec
we made a 3.1 KG aluminum cat back for our race car and it survived 30 minute sessions quite well... 70 degree farenheit ambiant temps.
Engine out, custom SS header,"V"banded to a transision pipe for NA or SC applications. (the header can be used for NA SC or Turbo apps) over pipe and catted section weighed in (with the alu rear) at 9.1 KG complete. engine back.. time will tell on the durability. We are a chassis shop so we made the lightest part possible. you can just see the 2.5" aluminum muffler and tailpipe just peeking out.
If we get enough interest the header and transision part are possible
We got 25 whp with this an Intake and ecutec tune NO CEL's
The Following User Says Thank You to robispec For This Useful Post:
ML (11-23-2012)
Old 11-23-2012, 11:57 AM   #11
robispec
Originally Posted by ultra View Post
Robispec!!!
Glad you remembered me!
Front end uses
  • Robispec modified Ground control topmounts (gets us to 2" higher upper strut mounting points).
  • Robispec custom lower control arms with track, camber, castor, and roll center adjustment/correction (all on spherical bearings).
  • bumpsteerable outer tierod ends.
Rear end uses
  • Custom Robispec upper damper mounts adds 2" travel to the rear suspension.
KWs with inhancements ;-)
Basic "fast/safe" RWD alignment..straight where you can get away with it, toe in for stability if needed.
Old 11-23-2012, 12:12 PM   #12
robispec
Well we "lost" 225 lbs
  • custom exhaust
  • Front and rear bumper beam delete
  • custom front lower control arms (lighter stiffer stronger more adjustable)
  • Brakeman BBK front
  • carbon fiber driveshaft
  • e-brake delete (prepping for a superlite rear BBK)
  • Enkei wheels and Toyo R1R tires
  • took out all trunk non-essentials (everything).
items left to find more weight reduction while appearing stock (but WAY too low lol)
  • battery
  • seats
  • airbag delete
  • rear trunk FRP replacement
  • front fender FRP replacement
  • Rear BBK (brakeman)
  • all sound deadning and undercoating
The Following 2 Users Say Thank You to robispec For This Useful Post:
GTB/ZR-1 (11-23-2012), Sonolin (05-14-2013)
Old 11-23-2012, 12:45 PM   #13
robispec
THESE ARE ALL PROTOTYPE PARTS
radiator with included oil cooler
Oil cooler mock up
Front lower control arms
rear topmounts
Old 11-23-2012, 01:02 PM   #14
GTB/ZR-1
GTB/ZR-1's Avatar
  • custom exhaust
I'd say that's probably w/ an empty tank as well? That's an awful lot of weight for the mods listed.
Also, the mods you still have planned will be fairly significant (my LithiumPros batt alone will save ~25lbs).
Getting my car prepped for Nat level SCCA Solo work.
Thanks for the reply!
Canu_50's FR-S Time Attack, drift car!! canu_50 Member's Car Journals 28 12-05-2013 02:04 AM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
Ontario Time Attack - upcoming events 6, 7 and 8 7thgear CANADA 1 07-12-2012 02:29 PM
Ontario Time Attack - TMP July 7th 7thgear CANADA 8 07-07-2012 06:14 PM
FT86c Drift & Time Attack Races in GT5 ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 153 06-25-2011 05:53 PM
