Old 01-22-2013, 12:29 PM   #29
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
What offset on the wheels?
Did you have the KW's Dyno tested?
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 01-22-2013, 12:49 PM   #30
robispec
Drives: Black frs project
Simmons
+45 fronts are on spacers as we test different front track widths
(we can go up to 50mm wider on the front track
kws no dyno but knew they needed some "tweeking" so went with my gut feeling and they seam to work pretty well...
robispec is offline   Reply With Quote
Old 01-23-2013, 11:54 AM   #31
Simmons
Simmons's Avatar
That doesn't look 3" lower?
Here is a pic of my car with the 245/40/17 at 2 1/4" lower than stock.
Simmons
Old 01-23-2013, 01:34 PM   #32
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Can you give us any more info on those brakes?
Nathan
SubieNate is offline   Reply With Quote
Old 02-04-2013, 01:42 AM   #33
robispec
Simmons
Yeah the tires were 245/35/17 for a rolling diameter that is 1.25" shortet than stock (and showing a bigger fender gap too)
Old 02-04-2013, 01:46 AM   #34
robispec
Nathan
Well finallized weights
fronts are 22 lbs lighter than the stock fronts
Ebrake delete (EVERYTHING) yields 18 lbs less
rear Kit saves 20 lbs
Total weight reduction is SIXTY POUNDS OF UNSPRUNG WEIGHT!
50+ of it rotating mass too.
Testing for durability now.
Robi
Old 02-04-2013, 06:25 AM   #35
plucas
plucas's Avatar
Drives: Subaru
Originally Posted by robispec View Post
Thanks we also have a HUGE radiator in the stock location with a included oil cooler..and still have the AC condensor working (we live in the desert too). stock radiator is 5/8" core (yes you read that right)..the new one is 2.5" Nascar core...car weights now 2525. looks stock inside and out..
Going for 2450 with the next round of modifications.
Robi
What is this Nascar core you speak of? Where did you get it?
plucas is offline   Reply With Quote
Old 02-04-2013, 08:40 AM   #36
Captain Insano
Please start selling all this stuff... Along with DIY videos of the things like the ebrake tear out!! Lovin this stuff.
Captain Insano is offline   Reply With Quote
Old 02-04-2013, 08:42 AM   #37
Captain Insano
Also, are you going to be releasing a hood with the louvers? I think you should, think it would be a good seller for track cars.
Old 02-04-2013, 01:13 PM   #38
robispec
we run this CUSTOM core in the NASCAR/stock car people who rarly turn right west series (not the BIG show)
we get it in america. Built here too. USDM yo Bro!
Old 02-04-2013, 02:37 PM   #39
plucas
plucas's Avatar
Drives: Subaru
Is it a PWR or Denso core?
Old 02-04-2013, 03:28 PM   #40
TWMPerformance
Drives: Manual Transmission, All the Way!
Nice build!
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 02-04-2013, 03:41 PM   #41
MyRx
MyRx's Avatar
I like where you're going with this. Lightweight and track worthy, make up for some of that hp the car doesn't have.
Curious on your radiator & oil cooler setup, is that one unit? I was looking at aftermarket rads and the cooler is $$$. More info on yours pls.
Old 02-04-2013, 05:39 PM   #42
robispec
SO here are some picts and info on our SUPER HEAVY DUTY COOLING UPGRADE
we are ready to go to market with these this week.
At Robispec we are fans of extra credit work and so we went to an "overkill cooling solution" stock radiator is 15mm core we replace this with 2 25mm tube core add a liquid to liquid oil cooler in the "cold side tank" and have less than 2 feet of total lines to complete the whole "kit".
The best thing about this is that you dont need to thermostaticly control the oil temp (a big potential problem with the Air to liquid cooler solutions) as the water thermostat does this for you and actually heats the oil faster during warm up then stabilizes it to run about 20-30 degrees hotter than the water temp. this is better in many ways than the current kits on the market.
1. lighter overall
2. short hose runs,minimal resistance to flow = no extra strain on the stock oil pump
3. "fixes" the Water cooling issues sure to develop with the stock radiator.
4. Uses existing cooling airflow and leaves fender locations for brake ducting
5. With low profile fans ADDS space in front of the engine for turbo/SC piping
Picts in the car
here are the cores for comparison. BIG PROBLEM and no oil cooler included with the car either.
Even the A/C condensed is thicker than the Stock radiator!(3/4" vs 5/8 ")
here is the BEST solution...to the above problem
system out of the car
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 47KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 52KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 83KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 44KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 75KB.
can use stock A/C with this.
NO cutting plastec to mount
Cold air over the top as needed
STOCK mounting points used
OVER TRIPLE THE COOLING CAPACITY and an extra Qt of engine oil.
takes 2 hours to install
total system cost Radiator oilcooler takeoff plates hoses, an fittings, fans
EVERYTHING INCLUDED for John Q Public to install $1,195.00
Look for the group buy to save money on the first ten of these.
Robi
The Following 2 Users Say Thank You to robispec For This Useful Post:
Kakawate (11-20-2013), nix (02-05-2013)
Canu_50's FR-S Time Attack, drift car!! canu_50 Member's Car Journals 28 12-05-2013 02:04 AM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
Ontario Time Attack - upcoming events 6, 7 and 8 7thgear CANADA 1 07-12-2012 02:29 PM
Ontario Time Attack - TMP July 7th 7thgear CANADA 8 07-07-2012 06:14 PM
FT86c Drift & Time Attack Races in GT5 ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 153 06-25-2011 05:53 PM
