Old 02-04-2013, 04:06 AM   #1
jpdesilva
jpdesilva's Avatar
Drives: Firestorm FRS
Question Exhaust? HELP!!!!
So im looking into a exhaust for my frs. I want something loud, but at the same time something that sounds nice. Im looking into the Greddy evo3. Any suggestions or comments on that? Also (this may sound dumb), when the exhaust silencers are removable, what does that mean and what is the result from them being removed? Any advice would help!
jpdesilva is offline   Reply With Quote
Old 02-04-2013, 04:14 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
evo 3 drones a lot. not good if you drive for a long period of time
if you want something loud but still sounds nice, check out the WORKS AB delete
it's very light, sounds good, and cheap!
---> http://www.ft86club.com/forums/showthread.php?t=24472
86_ZN6 is offline   Reply With Quote
Old 02-04-2013, 04:28 AM   #3
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
There's a lot of good stuff out there and really there's no right or wrong answer as the phrase "its too loud" is going to vary person to person. However, basically everything will be about 10db louder than stock at least.
I'd start listening to youtube videos and specifically look for videos with in cabin cruising at 55-65mph as well as fly-bys at WOT
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 02-04-2013, 04:50 AM   #4
jpdesilva
jpdesilva's Avatar
What does "drone" mean? Sorry Im new to all this.
Old 02-04-2013, 05:03 AM   #5
jpdesilva
jpdesilva's Avatar
I saw the videos from that link and I'm impressed, where can I order it and get it installed?
Old 02-04-2013, 05:06 AM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
drone is the sound that you here inside the cabin while you're cruising at around 70mph. drone makes you dizzy after you step out of your vehicle
you can order them here ---> http://www.86-zn6.com
as for installation, you can install the AB yourself with just basic tools.
if you're not comfortable with it, then have a local muffler or performance shop in your area do the install. it should take around 30 mins for the install
seems like you're from LA, there's a bunch of shops that can do the install for you
make sure to add the mid pipe to have a catback system
Old 02-05-2013, 02:44 PM   #7
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Heres mine
Darryljr11 is offline   Reply With Quote
The Following User Says Thank You to Darryljr11 For This Useful Post:
FT-86 SpeedFactory (02-05-2013)
Old 02-05-2013, 02:46 PM   #8
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
I have the AB Works exhaust and it was super easy to install. Just need to jack up the car, unbolt two bolts, remove the muffler from the hangers, then reverse the process, admire your work!
The exhaust was initially loud, but after a few hundred miles it became quieter.
mechaghost is offline   Reply With Quote
Old 02-05-2013, 03:13 PM   #9
2forme
If you want loud and sexy, SRT. I have it. It's definitely loud, but sounds really, really nice.
Old 02-05-2013, 03:15 PM   #10
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
This.
Also, for your viewing pleasure....
http://www.youtube.com/user/FT86SpeedFactory
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
seven (02-05-2013)
Old 02-05-2013, 05:04 PM   #11
seven
Tells it like it is
seven's Avatar
Originally Posted by FT-86 SpeedFactory View Post
This.
I'll post mine later, but I will say I'm amazed how quiet the AP combo pipe is with the Q300 cat-back. My g/f and I both thought that from inside the car that is basically sounded stock under anything besides WOT.
Outside the car it has some tone, but nothing obnoxious or even very attention getting. I love it. Should go great with the AVO kit later.
brz, exhaust, frs, greddy, scion fr-s
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
Single exit Exhaust and exhaust cap hypermax Engine, Exhaust, Transmission 2 04-02-2013 09:41 PM
Can someone explain the diffrence between catback exhaust and axleback exhaust? speedy racer Engine, Exhaust, Transmission 12 09-23-2012 12:24 PM
Catback Exhaust vs Axleback Exhaust – What’s the difference? phenom86 Engine, Exhaust, Transmission 10 07-28-2012 09:08 AM
