Old 02-03-2013, 12:55 PM   #253
skatery1989
Drives: BRZ Limited
What size was the smaller pulley?
skatery1989 is offline
Old 02-03-2013, 01:47 PM   #254
sw20kosh
Drives: 2013 Black FR-S
For my testing yesterday I was reving the car to 7700-7800rpms.
I was on a low reading mustang Dyno for this test.. A stock car on this Dyno reads about 120-125 whp reads 15-20% less then a dynojet .. Dynopacks tend to read higher then dynojet.
All you need to understand is on a lower reading Dyno the gains are also smaller when compared to a higher reading Dyno. So if you put a exhaust on a car and pickup 20whp on a dynojet , you would only pickup 15whp on a low reading Dyno.
When I was in Cali I used a mustang Dyno and dynojet on the same day.. One Dyno showed 199whp, other showed 240whp
Anyways-
With the smaller pulley I could make up for lack of boost with timing.. I didn't see any real big power difference between 91 and 93 octane... 5whp isnt anything to talk about. I've had similar results with some of the turbo kits I've been working on. No doubt the FA20 motor is a strange beast.
Making max HP is not what I want to do, I want reliable and consistent results.. For me the car needs make the same power at least 3 times in a row on back to back Dyno runs with no cool off...
With 100octane or e85 I would expect a 30-40whp bump In power with the smaller pulley.
John
No I wasn't quoting perrins #s for the high #s. I was highlighting the large difference in power between the stock pulley and the 10psi pulley. A difference in power will show up even if you are on a mustang dyno. Sounds to me you are able to squeeze a lot of power out of the 7 psi pulley since you can advance timing enough to equal the gains of 3 more psi.
sw20kosh is offline
Old 02-03-2013, 02:24 PM   #255
Calum
That Guy
Drives: 2013 asphalt FRS MT
Really intriguing results.
Perrin also had their exhaust system on the car. What parts of the exhaust I don't know, but I remember them saying something about it in their thread. John, any thoughts on what kind of gains could come from an exhaust system added to this kit? With the stock pulley and the smaller pulley?
Calum is offline
Old 02-03-2013, 02:27 PM   #256
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Innovate kit tuning started yet?
JoeBoxer is offline
The Following User Says Thank You to JoeBoxer For This Useful Post:
WatchmaN (02-03-2013)
Old 02-03-2013, 02:46 PM   #257
Yruyur
Yruyur's Avatar
If we have your pumpgas and e85 and get the innovate tuner kit is there an additional cost for tuning.
Yruyur is offline
Old 02-03-2013, 06:47 PM   #258
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I have had all my race motors tuned on Mustang Dyno's. They are in my mind the real deal. The loads simulating and everything that it offer's tends to hurt some ego's.
John,
I'm getting a base line dyno from a local shop on Tuesday. I will do three pulls and do the same after I've installed the SC kit.
Gregg
jdzumwalt is offline
The Following User Says Thank You to jdzumwalt For This Useful Post:
thebear21 (02-03-2013)
Old 02-03-2013, 08:02 PM   #259
2forme
John,
I'm getting a base line dyno from a local shop on Tuesday. I will do three pulls and do the same after I installed the SC kit.
Gregg
Which kit did you go with?
2forme is offline
Old 02-03-2013, 09:00 PM   #260
jdzumwalt
Motor Sports slut
I decided for my use the Vortech was perfect. I love the car as a high strung car. Also I think a large torque hit may make it a bit slower at the track. For me I like the way the car feels I just want sugar on top.
The Following 4 Users Say Thank You to jdzumwalt For This Useful Post:
2forme (02-03-2013), A5D5TRYR (02-03-2013), Calum (02-04-2013), Huehuecoyotl (02-04-2013)
Old 02-03-2013, 09:51 PM   #261
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
Pretty much agree completely. I love the steady building power right to redline. It just feels more and more insane as the revs build and keeps on revving well passed what most of your passengers think it should..... I'm getting a little aroused... I think I have a problem...
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline
Old 02-03-2013, 11:52 PM   #262
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
260whp on mustang or bust. heh heh.
Coheed is offline
Old 02-04-2013, 04:02 AM   #263
Visconti
Drives: 05 STi
260whp on a mustang is a lot.
John,
Gregg
Sounds good.
Fyi - Sent you a email
Yes.
Anyone that goes forced induction will need to purchase another tune. I haven't priced out anything on the innovate kit just yet
In a few days I hope
This car had a exhaust
Visconti is offline
The Following 3 Users Say Thank You to Visconti For This Useful Post:
JoeBoxer (02-04-2013), tripjammer (02-14-2013), Yruyur (02-04-2013)
Old 02-04-2013, 05:59 AM   #264
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Please be the "world's first" to give us does damn numbers for innovate sc.
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline
The Following 2 Users Say Thank You to WatchmaN For This Useful Post:
Lawnik (02-04-2013), swift996 (02-04-2013)
Old 02-04-2013, 02:46 PM   #265
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I wanted to say thanks to John for all his help yesterday with my EcuTek flashing problems.
King Tut is offline
Old 02-04-2013, 03:54 PM   #266
Calum
That Guy
As I understand it, adding an exhaust to an NA engine will give less gains vs adding the same exhaust to a SC'd engine. So would it be safe to say the 243 that you got on 91 octane would look more like 220-230 on an otherwise stock car.
Edit, was that 243 also on a Mustang Dyno?
Calum is offline
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Visconti Tuning - Who wants to run on e85? or 100 Octane Visconti Engine, Exhaust, Transmission 174 05-21-2013 03:00 PM
VISCONTI TUNING WILL BE IN PHX JAN 18-20 WHO'S READY Visconti Southwest 9 01-06-2013 01:40 AM
Visconti Tuning Stage 1 Tester #3 (I think) ruskymx Engine, Exhaust, Transmission 46 09-15-2012 04:29 AM
Visconti Tuning NA STG1 Group Buy Visconti Groupbuys 683 08-24-2012 11:28 AM
