Old 02-03-2013, 05:43 PM   #1
NOHOME
Drives: RAVEN
Deos this car not warn you when you are low on washer fluid?
I know that I am anti-electronic nannies, but on the way back from the ski slope, I ran out of washer fluid with no chance for a fill for many miles.
I guess I got used to my other cars having an idiot light to warn me before I ran out. Am I missing something?
NOHOME is offline   Reply With Quote
The Following User Says Thank You to NOHOME For This Useful Post:
cgrey (02-04-2013)
Old 02-03-2013, 05:44 PM   #2
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
No.
Subie is offline   Reply With Quote
Old 02-03-2013, 05:45 PM   #3
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
No warning light. Does come with a dipstick in the washer fluid tank though.
FRSFirestorm is offline   Reply With Quote
Old 02-03-2013, 06:01 PM   #4
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Sure it does! When you pull the lever and you notice the stream does not travel up as far as it did the first time you ever used it, that's your "low fluid" warning. Attention to detail, there soldier!
Wolfking is offline   Reply With Quote
The Following 2 Users Say Thank You to Wolfking For This Useful Post:
mangostick (02-03-2013), OnkelC (02-04-2013)
Old 02-03-2013, 06:41 PM   #5
PNW FRS
PNW FRS's Avatar
PDI "Not"
I just checked mine and discovered that the reservoir was basically empty. Car is brand new and I've only used the spray 1or 2 times.
I filled it up and it took almost 1/2 of a Gal. Kind of weird.. I'm going to keep an eye on this... maybe there's a slow leak.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 02-03-2013, 06:50 PM   #6
FRSFirestorm
Red is Fastest
Mine held almost a gallon but not empty.
Old 02-03-2013, 06:51 PM   #7
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
That's good. My current car has a light that turns on and off even with a decent amount left and its so annoying.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 02-03-2013, 06:59 PM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
Based on the other electronics in the Subie I wouldn't be surprised if they had the warning sensor, although likely not.
Based on this car being a Scion and having some good standard performance gear, it's expected for stuff like this to be absent. I have lived with and without this feature, no biggie.
NOHOME I'm still waiting for a you to add a positive or enthusiastic post to this forum. Maybe in the summer!
Old 02-03-2013, 07:00 PM   #9
FRiSson
Drives: FR-S MT
There is a warning system. Shortly before it runs out, the stream gets weak.
FRiSson is offline   Reply With Quote
Old 02-03-2013, 07:18 PM   #10
Ingen
Drives: Ultramarine FR-S 6MT
Mine was pretty much totally empty. Took the whole gallon with room to spare.
Stupid road salt has me using it constantly.
As for warning, the cleaning performance on the passenger side will fall off first. Of it isn't cleaning as well overe there, look to refill! That's what I observed anyway.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
The Following User Says Thank You to Ingen For This Useful Post:
raptor87 (02-03-2013)
Old 02-03-2013, 07:20 PM   #11
Boost_Junkie
3.141592654
Boost_Junkie's Avatar
Drives: 2013 Galaxy Blue BRZ
1st world problems...
Boost_Junkie is offline   Reply With Quote
The Following User Says Thank You to Boost_Junkie For This Useful Post:
CaptainSlow (02-03-2013)
Old 02-03-2013, 08:21 PM   #12
CaptainSlow
CaptainSlow's Avatar
No shit. When you pull the lever and nothing comes out, it's empty. Not that difficult.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
immortal_suby (02-04-2013)
Old 02-03-2013, 08:36 PM   #13
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
this car also doesnt warn you when you're about to over cook your rice. this is outrageous!
chenshuo is offline   Reply With Quote
Old 02-03-2013, 10:20 PM   #14
FRiSson
Drives: FR-S MT
Now that's a 3rd World problem!
The Following User Says Thank You to FRiSson For This Useful Post:
b.e (02-03-2013)
Crush Washer Sizes Eric1855 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 55 08-30-2021 02:21 AM
Washer Mod? 636 Engine, Exhaust, Transmission 64 02-20-2018 04:08 PM
FYI - Washer Fluid light Ben_G BRZ First-Gen (2012+) — General Topics 48 01-03-2013 04:18 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
front washer? Filipino Royale Cosmetic Modification (Interior/Exterior/Lighting) 0 06-21-2012 02:06 PM
