Drives: Subaru WRB BRZ Limited
As stated the passenger door courtesy lights do not turn off at all.
Even when the car is off. I accidentally squished the housing of the door light and now it wont turn off at all. Also its on constantly at a dim setting compared to usual. Help please. |
#3 |
#4 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Try taking off the housing of the lens as you may of squished the contact points.
I assume the driver side is okay, so it may also be the door switch as well... Then again if it is...then your window would not respond at all either if you open/close the door.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#5 |
Try disconnecting then re connecting the battery.
| The Following User Says Thank You to Mo707 For This Useful Post: | zex (02-03-2013) |
#6 |
I tried switching the driver side over to the passenger side and it still doesnt work
#7 |
Drives: 2014 BRZ Limited SWP 6MT
Any follow up on this issue? Did warranty replace the BUI or they made you pay?
Had the same issue happen to me today with a brand new 3 day old 2014 BRZ dealership service people trying to blame it on the LED's which is BS because they are same voltage and consume even less power and noone else that i know had the issue with their LED's..and bulb works perfect on the driver side but not on the passenger sideHelp please if someone knows |
#8 |
Drives: 2015 Trailhawk
Happened to a buddy of mine on his new (2013 MY) car and dealer replaced a module.... shrug. he had LEDs in there as well.
#9 |
Did he put halogens back before going to the dealer? did the warranty cover it? did he put LED's back after it got replaced and it works fine now?
#10 |
Sorry... Yes... Warranty covered it, Kept the LEDs in the whole time and they work now as well.
#11 | |
such BS that they are trying to give me..pisses me off
#12 |
Sorry to hear that man.... Some dealers are just better then others when it comes to keeping the customer happy post sales.
#13 | |
Drives: SWP BRZ
| BRZ Driver's Door Courtesy Light Won't Work | delusional | Issues | Warranty | Recalls / TSB | 31 | 05-29-2022 07:15 AM |
| Door Ajar Light will not turn off | Aznek | Issues | Warranty | Recalls / TSB | 15 | 02-02-2015 09:40 AM |
| Changing out the door/courtesy lights - problem | mikalem | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 02-10-2014 08:39 AM |
| LED WHITE COURTESY FOOT LIGHT- Group Buy | F-T | Exterior Parts - Lighting | 2 | 03-04-2013 04:59 AM |
