Old 02-02-2013, 06:59 PM   #141
OrbitalEllipses
Drives: Attitude
Originally Posted by serialk11r View Post
Well if you drive a shitton of highway miles (especially if you like to go fast on the highway, like 80mph, cuz friction usually gets pretty bad over 3000rpm) and it's a rather big gearing change then it could end up paying for itself over time, but the primary use would probably be noise and possibly reduced oil consumption? At lower engine speeds the pitch of the exhaust is lower and the mechanical noise is much reduced so it's far more tolerable.
Gotcha. I actually thought about this some more...if I wanted to constantly be cruising at over 4K which is probably really buzzy, I'd have just gotten a bike.
Originally Posted by Allch Chcar View Post
Was it OrbitalEllipses?
Maybe.
Old 02-02-2013, 07:26 PM   #142
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
To get this straight. I'm just swapping parts out and no tuning required? I find this to be the best mod to go, plus an aftermarket tune DYI from ECUTek.
efactor84 is offline   Reply With Quote
Old 02-02-2013, 08:32 PM   #143
Racecomp Engineering
correct. One would have to ask themselves...
" after I do exhaust, reflash, and intake how else can I make better USE of my power......TO THE WHEELS?"
Shorter overall gears seems logical. ESPECIALLY FOR NA cars.
Hell the HOT ROD domestic guys have been doing this for 40+ years !
Bet you money when cams are available they will cost in the 1000-1500 range PLUS labor and it wont be a simple intake "like" install either.
Myles
Old 02-03-2013, 12:08 AM   #144
efactor84
efactor84's Avatar
Myles
Seems like my goal is to stay NA, and get to 200+whp without going to the force induction route. But, that could always change when the Aftermarket releases the turbo kits out.
Old 02-03-2013, 05:43 AM   #145
Calum
That Guy
Drives: 2013 asphalt FRS MT
When? The aftermarket already has several forced induction options. You can find a lot of info in the forced induction forum.
Old 02-08-2013, 06:23 PM   #146
Subzero
Old...
Subzero's Avatar
Drives: Subaru
aside from how SICK this car sounds, I think this car runs the 4.81 final drive !
At 2200 lbs its sick !
Enjoy!
Wow! The Hyperlemon WRX at Tsukuba was only 3 seconds faster. That's impressive for this car to do that with no boost!
[ame]http://youtu.be/KqD5L-tY4rk[/ame]
Subzero is offline   Reply With Quote
Old 02-08-2013, 09:17 PM   #147
AND......Tsuchiya was driving that JUN car too ! He for sure is one of the fastest drivers in Japan( then and now).
That WRX was and still is pretty legendary !
temporary thread jack here..
http://bugeyegarage.wordpress.com/20...on-gdb-bugeye/
Old 02-08-2013, 10:19 PM   #148
Subzero
Old...
Subzero's Avatar
Drives: Subaru
That link says 55s lap times. That makes a bit more sense to be 6 seconds faster than just 3. The Lemon still has twice the power.
I really like how the BRZ carries itself at speed. Even stock it feels very poised. The BRZ looks like it has more finess between the two in these vids. I liked how it did not fight its own weight when I drove it.
Old 02-09-2013, 04:20 AM   #149
mrbbs
Drives: GT86
Can anyone help me out where I can find the Cusco 4.8:1 final drive in Europe (Belgium)?
http://www.cuscousainc.com/jpg/Scion...ed%20Chart.jpg
mrbbs is offline   Reply With Quote
Old 03-01-2013, 05:12 PM   #150
Sargy
Long Distance Driver
Sargy's Avatar
Anyone here got a recommendation in the 4.7 area?
All I see is MFactory, which I believe is good in the Honda scene, (correct me if im wrong!)
Sargy is offline   Reply With Quote
Old 03-04-2013, 06:50 AM   #151
mrbbs
Drives: GT86
It's a shame information for final drive is so hard to get.
I emailed Cusco Europe, US, Japan but no replies to my emails.
I would like to know when the 4.875:1 final drive will be available.
Seems the 4.556:1 is already available since a couple of months
Old 03-04-2013, 03:04 PM   #152
86drift
86drift's Avatar
Drives: Toyota 86 GT
It should be available now. But you'll need to run the matching Cusco LSD.
I've ordered the 5.125 (which happens to be a Toyota part) and MZ center.
86drift is offline   Reply With Quote
Old 03-04-2013, 03:39 PM   #153
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
quick question for you guy's, do I need to change something else or i'm good with only this. If yes what and why?
http://ft86speedfactory.com/mfactory...-gear-556.html
thanks
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 03-04-2013, 04:58 PM   #154
Pandle
Drives: CBS BRZ
I'm guessing most of the options like this and the one posted above arent compatible with an automatic transmission?
Pandle is offline   Reply With Quote
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
