Old 01-30-2013, 11:13 PM   #827
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Fnbeast86 View Post
Noob ? What's te difference between normal one or offset exhaust
Read less than 30 posts before you, it has been explained twice in that span...
Edit, posts 802 and 809
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Fnbeast86 (01-30-2013)
Old 01-31-2013, 08:12 AM   #828
df.dima
Drives: FR-S and Mazda 3 Sky
Originally Posted by xjohnx View Post
Snagged this from Nameless' facebook:
Here's a picture posted earlier, offset and normal for those who is unsure.
df.dima is offline   Reply With Quote
Old 01-31-2013, 10:14 AM   #829
FR-S Matt
I'm 6'6" and going to put my car on jacks and install this system when I get it. Now I wish I was short, lol.
Old 01-31-2013, 11:20 AM   #830
jimbobrand
jimbobrand's Avatar
Drives: 2013 Subaru BRZ Premium
The Nameless axelback is about the quietest exhaust for the BRZ/FR-S other than maybe the TRD. You might want to get a second set of hands to help with the install since it sometimes takes a bit of force to detach the exhaust from the hangers (even with silicone spray).
Like others have said, the uneven tip issue isn't just a problem with the Nameless and I've seen it on Perrin's and SRT's. It seems that if you loosen the forward exhaust hangers on the front pipe you can get enough wiggle room to straighten everything up.
Jim Brand
2013 Subaru BRZ Premium 6MT WRBP
Oklahoma Subaru Crew-OKSC.org
TXIC San Antonio
jimbobrand is offline   Reply With Quote
Old 01-31-2013, 12:27 PM   #831
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
On my install i'm using 2 Urethane hangers at the back of the car, and i can't see any issue with the tips. If there is a difference is like<1-2mm and i cant see it
Ravenlokk is offline   Reply With Quote
Old 01-31-2013, 12:28 PM   #832
OrbitalEllipses
Drives: Attitude
Just the two rearward most hangers?
Old 01-31-2013, 03:53 PM   #833
mtsound
For those who have installed the overpipe/ front pipe combo...
Do you need to lift the engine/undo engine mounts? Since its a long tube
Thanks
mtsound is offline   Reply With Quote
Old 01-31-2013, 06:41 PM   #834
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
Ok I emailed Nameless about the uneven tips, and this was their response:
The tip alignment issue was simply a shift during the shipping process, and is very easily remedied. Furthermore, if you encounter any fitment issues during or after your installation, we encourage you to contact us right away. Usually we can diagnose and resolve any issues without any real complication.
I replied, asking when the new design would be rolled out, etc, and this was their response:
From this point forward, all of our exhausts will be produced using our new configuration (3" or 2.5" Main Circuit to dual 2.25") unless otherwise noted. We have the parts in stock currently to build out the new design, and there will be no difference in price between the two.
With this new design, we will be offering the same style muffler configuration that we currently offer on the Subaru WRX/STI Hatchback. We will have a muffler delete, 4" Straight through, and the 5" offset design. The 5" offset design is going to give you the deepest exhaust note, with the lowest volume between the 3 different configurations. If you plan on introducing forced induction at some point in the future, the 3" main circuit will be the optimal solution for you. If you do not plan on going that route, then I would recommend the 2.5" primary with the dual 2.25" secondaries, that is going to give you the deepest, quietest tone out of the possible configurations.
Cajun is offline   Reply With Quote
The Following User Says Thank You to Cajun For This Useful Post:
Sportsguy83 (01-31-2013)
Old 01-31-2013, 06:54 PM   #835
Sportsguy83
Drives: Limited BRZ
Thanks
You need to loosen one mount on the passenger car. Just need to unbolt one (or two I don't remember right now), lift the engine from the oil pan about 2 inches and good to go.
Old 01-31-2013, 07:36 PM   #836
sierra
Drives: Skoda Yeti DSG diesel 4x4
Meaning they get bent during freight and we can bend then straight to get a perfect tip alignment? As most of us have the right tip out 10mm more than the left it sounds like the same fix.
What do we need to do?
sierra is offline   Reply With Quote
Old 01-31-2013, 08:15 PM   #837
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Insert big stick. Pry gently? That's what I would do. It's only metal tubes. 10mm at the tip won't take much. It got bent so unbend it?
industrial is offline   Reply With Quote
Old 01-31-2013, 08:26 PM   #838
sierra
Unbend it about which point though?
Old 01-31-2013, 08:39 PM   #839
Sportsguy83
Drives: Limited BRZ
At some point in this thread (or the header one), someone posted the instructions Nameless gave them to do it.
Old 01-31-2013, 08:46 PM   #840
FR-S Matt
I'd ask Jason about it if you are concerned. They have no problem addressing any concerns with their exhaust.
BRZ performance driving demo - looks great Oriental Life BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-11-2012 02:20 AM
What type of performance parts will you be looking to buy first? bFreed Engine, Exhaust, Transmission 12 11-09-2011 05:51 PM
Performance automatics madfast Engine, Exhaust, Transmission 118 08-25-2011 03:26 AM
FT-86 Article on Performance magazine 4agze Scion FR-S / Toyota 86 GT86 General Forum 7 01-09-2010 11:33 AM
