Old 01-30-2013, 02:47 PM   #85
03Z33
drift
03Z33's Avatar
Will read through the thread later when I have more time but didn't see these mentioned:
New Cusco vertical catch-can/separtor with internal partitions:
http://www.cusco.co.jp/en/parts_prod...ta_86_sub.html
ARC catch can (this one drains to the oil cap also)
http://www.arc-brazing.co.jp/carlineup/toyota_86.html
Revolution catch can:
http://revo-tune.jp/catalogue/detail.php?id=284
Revolution also offer oil pan baffle plate:
http://revo-tune.jp/catalogue/detail.php?id=322
03Z33 is offline   Reply With Quote
Old 01-30-2013, 04:51 PM   #86
Dezoris
Dezoris's Avatar
You absolutely do not want to re-route PCV vapor back to the oil cap. Its a gimmick at best.
If you are ok with unburned fuel, blow by oil and water vapor in your oil pan then go for it. Even if by chance gravity actually drains the can back to the oil cap its a horrible idea and design.
The Following User Says Thank You to Dezoris For This Useful Post:
Plumbus (05-07-2020)
Old 01-30-2013, 06:41 PM   #87
mad_sb
Drives: 2013 Asphalt FR-S
I went vented:
Can I ask why without offending you?
The way you have that setup, from what i can see anyway, does not look like your can is going to catch anything since nothing will circulate through it. I think it would do the same thing to remove the can and put little filters on the nipples on the block.
Old 01-30-2013, 06:48 PM   #88
wbradley
Sarcastic SOB
wbradley's Avatar
[QUOTE=03Z33;699911]New Cusco vertical catch-can/separtor with internal partitions:
And it lookls like its connected between the front crankcase vent and the intake behind the air box.
I wonder why they keep showing it connected this way. Is it something to do with forced induction installs or what?
Please somebody that knows difinitively, confirm the can is supposed to go between the PCV and manifold.
Old 01-30-2013, 07:09 PM   #89
mad_sb
[quote=wbradley;700461]
If you want full coverage you need two cans, one on the intake manifold side and one on the intake side. They are just show it that way in the picture. If you only want to do a single can, do the manifold side like i did above, that is where the majority of the crank case vapor will circulate (except when WOT).
Old 01-30-2013, 07:28 PM   #90
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I don't expect it to catch anything. I am hoping my oil stays in the crankcase where it belongs. If any oil does come out, then I want it to be caught in the catch can. Trust me, I can smell the oily air through the filter. I still feel like this is the best solution for a turbocharged car until someone shows me proof that adding a vacuum line from before the turbo to put the crankcase under vacuum, will increase horsepower.
Old 01-30-2013, 10:21 PM   #91
mad_sb
Sounds like you have used similar setups in the past on other vehicles?
I'm not suggesting pulling a vacuum on the crank case will increase power, though i know lots of people make that claim and it doesn't take much consideration to understand the theory.. a piston traveling down the bore working against 20 PSI of pressure against the under side of the piston will have to work harder than a one moving through vacuum.
My preference is based on what i have observed on the dyno (dip sticks popig out, oil spewing all over the place, oil film covered engine bays, excessive oil smoke) and the theory behind why we have pcv systems in the first place (to prevent sludge buildup for one).
IMO the reason for a closed system is to scrub the oil vapor out of the crank case gases. If you had an open system that actually did that i think it would probably be superior to a closed system because you would not be re-circulating any of the other vapors.
Old 04-09-2013, 03:23 PM   #92
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Figured I would update you. I drained my catch can for the first time since I installed it in January. I have been boosted for a couple months now. It had about 8 ounces of the same looking liquid as this video:
[ame="http://www.youtube.com/watch?v=arKumsxHx-8"]Subaru catch can contents - YouTube[/ame]
It is mostly condensation mixed with oil.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
akuhei (04-09-2013), shiro (08-28-2013), Sportsguy83 (04-09-2013)
Old 04-09-2013, 03:54 PM   #93
Hanakuso
Saikou Michi needs to release there setup soon..
Hanakuso is offline   Reply With Quote
Old 04-24-2013, 06:39 PM   #94
reeves
Originally Posted by ATL BRZ View Post
I run a Moroso
Internal baffling, easy to drain, no rattles.
Did the included hoses on the this Moroso fit your BRZ pcv inlet? Did you just use the stock hoses, or did you need to buy completely new hoses? TIA!
Old 04-24-2013, 06:53 PM   #95
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
The included hoses fit the stock pcv hoses! Gotta trim them both down and use hose clamps at the connections.
Make sure you tap into the rear pcv for the majority of the blow by, not the front vent that goes to the intake.
The Following User Says Thank You to ATL BRZ For This Useful Post:
reeves (04-24-2013)
Old 04-24-2013, 09:45 PM   #96
reeves
Yea I saw your 'corrected' PCV connection on the previous page.. thanks for the heads up! Did you catch any oil yet after you corrected it?
Old 04-25-2013, 12:20 AM   #97
Xdragonxb0i
Drives: ex500r
Does anyone have a picture of a catch can sitting right next to a lightweight battery?
Xdragonxb0i is offline   Reply With Quote
Old 04-25-2013, 08:46 AM   #98
ATL BRZ
ATL BRZ's Avatar
Scroll up to post #85
BRZ vs FRS - The Debate TAP Auto Parts Scion FR-S / Toyota 86 GT86 General Forum 139 05-07-2013 06:26 PM
The Great Torque vs. Horsepower Debate phenom86 Engine, Exhaust, Transmission 53 11-11-2012 09:54 PM
The Great Hatch vs Trunk Debate nate89 Scion FR-S / Toyota 86 GT86 General Forum 229 10-24-2011 09:39 AM
Forget the NA vs Turbo debate!!!! Midship Runabout Engine, Exhaust, Transmission 69 04-05-2011 05:24 PM
