Old 01-30-2013, 01:19 PM   #141
2forme
Originally Posted by Trashed675 View Post
@2forme
If you get the torque guys to go for it, can you have two devises connected to BT at the same time? EI a phone and a BT odb2 adapter? Just something to think about.
Well the Torque thing would just allow you to use a USB OBD2, not a BT one. In reality, this is actually a better solution as USB refreshes much faster than BT.
The BT limitation is built into the OS I believe. We'd have to look into rooting/ROMing it before we could determine whether or not it's a hardware limitation.
Old 01-30-2013, 01:55 PM   #142
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by 2forme View Post
Everything else on the head unit has run really well. The knockoff actually has less backlight bleed than the Ca-Fi.
I've noticed the Adayo has some what quite a bit of reflection on the screen from the sun. Is this true with the Ca-Fi and the Ca-Fi knockoff?
Thanks
stevo_12v is offline   Reply With Quote
Old 01-30-2013, 01:57 PM   #143
2forme
Thanks
Um, the reflection is about the same between the knockoff and ca-fi. I did notice the sun performance of the adayo was a bit lacking compared to the other two.
Old 01-30-2013, 02:31 PM   #144
Khánh
Khánh's Avatar
Drives: sc00ter
2forme, did you get your new headunit yet? Mine is arriving today..
Khánh is offline   Reply With Quote
Old 01-30-2013, 02:45 PM   #145
stevo_12v
I found something to use for the reflection of the android head unit(s).
http://www.officeworks.com.au/retail...ion/ACFLMOA002
Gonna pick one up tomorrow. Cut it to size.
Old 01-30-2013, 02:54 PM   #146
2forme
Yea, I already said in a post somewhere that it isn't worth a review. I'm sending it back tomorrow.
You won't be able to see the screen in the sun if that's anti-glare. Just letting you know now.
Old 01-30-2013, 04:55 PM   #147
Lo
Drives: Old Saturn
@2forme
Hey! First off, thanks for all the info you've given us and answering some if not all of our questions!
Maybe it's because I don't know anything when it comes to car stereos, but I was wondering if it's possible to use the ports (usb and aux in) that come with the car next to the "phone dock" with the Ca-Fi knockoff. Would that give you extra inputs or would they take the space of an already existing input on the stereo...
I hope my question isn't too stupid.
PS: For my fellow Canucks, (i.e. some ebay.com products aren't accessible to us including 2forme's ebay link) here's a link to the Ca-Fi knockoff ebay.ca http://www.ebay.ca/itm/2-Din-Car-Ste...t_18982wt_1111
Lo is offline   Reply With Quote
The Following User Says Thank You to Lo For This Useful Post:
2forme (01-30-2013)
Old 01-30-2013, 05:21 PM   #148
xwd
@2forme
Android greater than 2.3 allows using multiple BT devices at the same time. Apps like torque and one I used called solostorm can use a BT GPS and OBD2 adapter at the same time.
Old 01-30-2013, 06:32 PM   #149
2forme
That's not the issue. The issues is the BT chipset is limited to A2DP only. It won't pair any devices other than phones.
Old 01-30-2013, 06:39 PM   #150
2forme
Originally Posted by Lo View Post
@2forme
There's no way to use those in addition to the usb ports on the head unit. You can mod the stock one to extend one of the ports on the back.
Old 02-04-2013, 09:07 PM   #151
melchoir55
Drives: 2013 Prius 2
Have you had the chance to try out the ca-fi dashlinq universal? I'd like to know how it compares to the ca-fi you reviewed in the OP.
melchoir55 is offline   Reply With Quote
Old 02-05-2013, 12:54 PM   #152
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Crazy thought for you guys, why not a wifi odb2 adapter? The ones i've seen have been more expensive then the BT ones, but it should technically work via an adhoc network. Obviously you won't be able to be connected to your home network and the adapter at the same time but la dee da.
If someone gets brave enough to try one, let us know how it works out.
Trashed675 is offline   Reply With Quote
Old 02-05-2013, 12:55 PM   #153
2forme
Been there, done that. You can't create an adhoc network on these units without root (it even says so in the Torque app [root access required]).
I'm trying to get a better feel on the Torque forums as to which USB API's they needed to use for the Ca-Fi unit.
Old 02-05-2013, 01:05 PM   #154
Trashed675
Trashed675's Avatar
Well crap, and i thought i was being helpful haha. Well keep us posted on what your digging turns up.
Who's interested in a full Android head unit? 2forme Electronics | Audio | NAV | Infotainment 307 10-05-2013 10:56 AM
How do Android phones work with the stock head unit? FastLap Electronics | Audio | NAV | Infotainment 14 10-09-2012 11:34 PM
looking for a head unit for Fr-s like the Brz. enjoi23 Electronics | Audio | NAV | Infotainment 5 08-08-2012 02:51 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
