Old 08-27-2012, 09:03 PM   #1
FastLap
Drives: 2025 Toyota GR86 Premium PP
How do Android phones work with the stock head unit?
I'm thinking of moving from an iPhone to an Android phone. Right now the Bluetooth/USB integration of my iPhone with the stock head unit seems great (works just like an iPod display that shows the playlists, artists, etc.).
Being new to Android I'm wondering how this would work with an Android phone? Is there something similar to iTunes that allows playlists and so forth to be created, and is the stock head unit capable of reading those as well, or is it only really compatible with "i" devices and everything else will just appear as a "folder view" the same as if you connect a USB flash drive?
On a side note, and not completely related to the car, but figured you Android users would know, what if I already have all my music in iTunes and in the .M4A format (vs. MP3), is there a way to sync that and use it on the Android phone?
FastLap is offline   Reply With Quote
Old 08-27-2012, 09:28 PM   #2
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
ts easy and I never have issues but I normally just use Pandora to play music because I don't like to download too much on my phone. Also I believe they have an app that can't convert to mp3 but not 100% sure. If you can't find it just convert it on your computer.
20valvewynn83 is offline   Reply With Quote
Old 08-27-2012, 09:40 PM   #3
FastLap
I'm thinking maybe it's better to just get a little iPod Shuffle or something for the car... although that would require using the USB port instead of Bluetooth. I guess you can still use Bluetooth for phone calls in that situation.
Old 08-27-2012, 09:57 PM   #4
whataboutbob
AutoX-10/10ths every run
My Droid Razr worked fine with the original head unit.
Old 08-27-2012, 10:28 PM   #5
dsgerbc
Drives: BRZ(sold), STI
My S3 won't sync contacts. Didn't try playlists though.
dsgerbc is offline   Reply With Quote
Old 08-28-2012, 03:35 PM   #6
sega_102
Drives: Scion FR-S
My S3 synced contacts just fine.
You have to confirm that you want to send the contacts on the phone. Did you miss that step?
sega_102 is offline   Reply With Quote
Old 08-28-2012, 06:50 PM   #7
dsgerbc
Nope. It syncs a handful of irrelevant contacts (like 411 etc) and two genuine contacts and chokes. Everything else bluetooth-related works.
Old 08-28-2012, 06:56 PM   #8
travace
travace's Avatar
Drives: Scion FR-S
on a HTC evo 3d and it syncs jsut fine.... i can even have phone from my wifes go through speaker while my phone only connects the audio stuff.... switching between multiple phones is a breeze
the pause play and next track on the deck always work just fine as well.
travace is offline   Reply With Quote
Old 09-03-2012, 02:48 AM   #9
knaa
Drives: FRS
I have the HTC One X and it works pretty well, disconnects sometimes but reconnects after a few seconds
knaa is offline   Reply With Quote
Old 09-04-2012, 02:19 PM   #10
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
+1
However, one thing I've noticed is that I have to sync contacts every time (not a problem, as I can just find the person I want to call on my "recents" list in my phone. Anyone I would want to call is usually right there, anyway). Not sure if it's because I haven't synced the contacts, but any incoming call shows up as just a number, so unless I look at my phone, I'm answering blind, for the most part. Also, sometimes the "Phone" option from the radio menu does not appear.
Haven't lost connection yet, and the bluetooth media works just fine and even shows song names. Overall, I'm happy with it (not too picky about my first part)
Propaganda is offline   Reply With Quote
Old 09-04-2012, 07:05 PM   #11
megatron
It's over prime!
megatron's Avatar
Drives: Scion FR-S
i'm on a samsung galaxy S with cyanogen mod 10 (jellybean)
bluetooth,contacts synced,call quality is all top notch and no glitches what so ever
i'm on the upgraded radio (bespoke)
megatron is offline   Reply With Quote
Old 09-30-2012, 03:27 AM   #12
FRSCr8z
Drives: Hot Lava with Five Axis kit
USB head unit doesn't work most of the time on my Droid Incredible 2
I've been having quite a difficult time to get my Droid Incredible 2 to be recognized by the USB head unit. I have the upgraded BeSpoke radio unit and most of the time it just gets stuck trying to sync with my phone.
Anyone seen this happen?
FRSCr8z is offline   Reply With Quote
Old 09-30-2012, 08:30 AM   #13
ML
ML's Avatar
Drives: 13 White MT FR-S
Yes! Bespoke is such crap. I have to unlock my phone before it will connect, and sometimes bt won't connect unless I turn the car off and back on.
Old 10-08-2012, 07:43 PM   #14
JayNutter
I have a droid razr with ICS. Bluetooth hooked up easily and taking phone calls is simple. Haven't synced my contacts, but I don't use my phone much so I don't care.
One problem: Pandora connects, plays and allows skipping tracks, but the screen flashed "PAUSED." It won't let me adjust the volume unless I switch it from BTA and back again. then I only have 1 second to adjust the sound before the "PAUSED" starts flashing at me. Any know fix?
JayNutter is offline   Reply With Quote
Stock Stereo Head Unit Languages Bonburner Electronics | Audio | NAV | Infotainment 12 08-18-2012 08:41 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
stock nav head unit outputs brzzz Electronics | Audio | NAV | Infotainment 2 07-13-2012 03:37 PM
Anyone removing their BRZ stock head unit with Navi DrDuquette Electronics | Audio | NAV | Infotainment 1 07-01-2012 01:48 PM
Is the standard stock FRS head unit good to go if I.... Liquidsnake Electronics | Audio | NAV | Infotainment 2 06-17-2012 03:16 AM
