Old 01-30-2013, 11:56 AM   #99
djliquidsteele
Drives: Scion FR-S
Originally Posted by plucas View Post
Well it is a little more complicated than just changing something. Really thorough analysis and testing is needed. Basical engine cooling like radiators, oil coolers, and radiant heat need to be able to exit out of the top, like the hood or out the bottom. Both can be done but out the top is more common for simplicity. Transmissions and rear ends are cooled with the air under the car. If that gets covered, cooling in these areas are needed also. You could add things like NACA ducts for inlets and exit it out the bottom by creating an area with even lower pressure. Another option would be external heat exchangers to cool the oil in these areas. There are a ton of possibilities.
If you are really interested in doing this, I can give you a good direction. I would pm me though to keep the thread clean.
In my opinion, lets keep the discussion here as anyone that is truly interested in improving the aerodynamics of the car for race purposes is probably going to be interested in cooling possibilities.
djliquidsteele is offline   Reply With Quote
Old 01-30-2013, 01:33 PM   #100
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
random question, the answer to which i almost know but want to confirm
at very low speeds (20kmh, for instance) is the downforce generated by almost any device essentially entirely negligible?
Old 01-30-2013, 02:51 PM   #101
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
i would say yes, but some circumstances (F1) design around what little downforce is produced at lower speeds IIRC. i could be wrong though.
FreshFRS is offline   Reply With Quote
Old 01-30-2013, 03:16 PM   #102
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Hehehe
I dunno, I doubt it, the slowest speed an F1 car goes is in the pits, and it's way faster than 20kph :P
Old 01-30-2013, 03:53 PM   #103
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Hehehe
lower speed relatively i should have clarified. 40mph in some corners is the slowest ive seen. for an average car is not affected at all i would say.
Old 01-30-2013, 05:06 PM   #104
EarlQHan
Drives: Subarus
It depends on the situation, but in the situation of road cars, I'd say it is negligible. It would be like using relativistic equations when Newton's will suffice.
EarlQHan is offline   Reply With Quote
Old 01-30-2013, 06:19 PM   #105
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
The formula for downforce by definition uses the square of the velocity. That being said theres always a minimum speed for lift/downforce to work. Think of paper planes. The formula also includes the area relative to the angle of attack which means if you have a sufficiently big wing with a big angle you can still get some downforce at low speed (Pikes Peak Unlimited class cars) but at the cost of high drag.
Xanatos is offline   Reply With Quote
Old 01-30-2013, 06:52 PM   #106
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
my inteded application is ice racing, where the cornering speeds at apex are about 15-20km/h
and if i should bother designing any aero at all
Old 01-30-2013, 06:53 PM   #107
Dimman
Kuruma Otaku
Dimman's Avatar
You'd need a World of Outlaws level of wing.
Edit:
Because titanium.
Old 01-30-2013, 06:57 PM   #108
ZDan
ZDan's Avatar
Drives: '23 BRZ
You should be designing in aero a la the Chapparal 2J and Brabham BT46B "sucker cars"
Old 01-30-2013, 06:59 PM   #109
Xanatos
Xanatos's Avatar
Nah, I wouldn't worry about aero. I suspect you will be drifting some of those turns as well which means the area of the wings is essentially zero.
The right suspension would have much more of an effect on your grip than aero.
Old 01-30-2013, 07:04 PM   #110
robispec
Drives: Black frs project
weight reduction CG location (if you have minimum weights) would be the big ticket items vs aero (and I'm a big fan of aero). if you look at the basic wind resistance curve it starts bending upwards pretty fast in the high teens (just ask any bicycle racer) and you start doubling HP requirements for a minimal increase in speed in the mid to high twenty mph
But we are talking about a very low HP engine here...lol
robispec is offline   Reply With Quote
Old 01-30-2013, 07:54 PM   #111
jamal
jamal's Avatar
Drives: Legacy GT
Basically until you are going 60-70mph you don't really gain anything. Here's a chart from a neat book I'm reading:
jamal is offline   Reply With Quote
Old 01-30-2013, 08:01 PM   #112
plucas
plucas's Avatar
Drives: Subaru
I do not get what you are saying
plucas is offline   Reply With Quote
The Following User Says Thank You to plucas For This Useful Post:
Rayme (02-01-2013)
Front aerodynamics... need help! TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 16 10-23-2012 09:27 PM
Interesting aerodynamics differences between USDM, JDM, etc. yargk Scion FR-S / Toyota 86 GT86 General Forum 25 09-20-2012 04:00 PM
Coefficient Drag & Aftermarket Aerodynamics FT-86GOD Scion FR-S / Toyota 86 GT86 General Forum 1 06-28-2012 01:20 AM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-26-2012 09:19 PM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-21-2012 12:47 PM
