Old 01-29-2013, 09:35 PM   #2451
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Good question. I'd assume it's an 810 as it's never been changed.
MVJ1975 is offline   Reply With Quote
Old 01-30-2013, 10:50 AM   #2452
Marrk
Drives: Honda Fit
Originally Posted by MVJ1975 View Post
Update - they swapped the valves and the same error popped right back up. Now they're replacing a cam gear. Current ETA is early next week.
"swapped the valves" ? I'm not sure what this means, nor do I recall seeing anything about swapping valves in this thread. Maybe I missed something (?).
Could you explain?
Thanks.
Marrk is offline   Reply With Quote
Old 01-30-2013, 11:01 AM   #2453
Yruyur
Yruyur's Avatar
Most likely swapped sensors to see if its a cam sensor issue like they did on mine.
Old 01-30-2013, 11:03 AM   #2454
Marrk
Drives: Honda Fit
^^Okay. Swapping sensors I understand. Thanks.
Old 01-30-2013, 09:38 PM   #2455
xfire0384
Drives: RIP 2013 Scion FR-S
xfire0384, Scion FR-S, 5,400 miles, 7078XX, 1 day - repaired, CA, USA
They scanned the ECM and got error code P0019 - Cam Sensor Correlation.
They reflashed the ECM and it seems to have fixed the issue.
Talked with the Service Consultant and he said he had seen a number of FR-S come through and in all cases the reflash or replacing the ECM has fixed the problem.
Here's hoping...
xfire0384 is offline   Reply With Quote
The Following 2 Users Say Thank You to xfire0384 For This Useful Post:
eurospeed (02-08-2013), Marrk (01-30-2013)
Old 01-30-2013, 10:47 PM   #2456
jrodz09
Drives: Subaru BRZ Lmtd
Damn! Just got my BRZ on Thursday.. See what surprises await. :/ Currently at 680mi. Have experienced a rough shake when completely stopped. Is that the start to this problem?
jrodz09 is offline   Reply With Quote
Old 01-30-2013, 11:32 PM   #2457
acro
Drives: GT-86
So i got the flash today.
No more idle issues no more CEL
Car runs smooth as butter. This is the way it should have come
U can count me as case solved
acro is offline   Reply With Quote
The Following 2 Users Say Thank You to acro For This Useful Post:
eurospeed (02-08-2013), Marrk (01-31-2013)
Old 01-31-2013, 10:11 AM   #2458
xfire0384
That is what I had just before my FR-S gave me the CEL/SL lights. Think it was about a month for me from the first rough idle to that.
Old 01-31-2013, 12:26 PM   #2459
Marrk
Drives: Honda Fit
What's you VIN, bro?
Old 01-31-2013, 09:46 PM   #2460
jupillam
jupillam's Avatar
Drives: White out Scion Frs
Have my frs checked in at the dealer for CEL. They will keep my car for couple of days to drive it to regenerate the code again. Hope to get my car back soon.
jupillam is offline   Reply With Quote
Old 01-31-2013, 10:32 PM   #2461
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Tuckdaddy number 209 now around 9,000 miles and still kicking strong!
tuckdaddy is offline   Reply With Quote
Old 01-31-2013, 10:51 PM   #2462
jrodz09
6055XX.. Hope my made it clear from all those major problems..
Old 01-31-2013, 11:34 PM   #2463
BRZnut
Drives: BRZ DGM Limited
605554.. Hope my made it clear from all those major problems..
The problems should have been fixed for you at the factory...keep us posted on the rough idle.
Old 02-01-2013, 12:02 AM   #2464
foxhu
Went in for the ECM recall(01/31) for about 10 min and everything is set hopefully the light doesn't come on XD
foxhu is offline   Reply With Quote
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
