Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 12-28-2012, 11:07 PM   #15
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by ahausheer View Post
The real issue is/was not coolant level. Its where did the coolant go? Im sure the full and low line include a large safety margin but the coolant should not go below the cool line ever even when cold. Now that the op has filled it (with the right coolant type I hope) just monitor the level over the next few weeks taking thermal expansion into consideration. If no change than nothing to worry about. If it goes down you must get it checked.
Mech from my dealership stated top it up with clean water and it should be okay...
I did so but i didn't top it up i only filled it to half way.
I will be watching it alot closer now to see if it goes below the cold line i set.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 12-28-2012, 11:26 PM   #16
ahausheer
Re-member
Drives: Toyota camry
The water should be fine for years and years but you really should use the proper fluid. Modern cooling systems are very sensitive to chemistry and topping it up with water (especially non deionized water) is a temporary stop gap. I encourage you to make a phone call to another dealer for a second opinion. Am if im wrong let me know. just trying to help.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 12-29-2012, 12:43 AM   #17
gmookher
top off with distilled or ro water
Old 01-29-2013, 10:19 AM   #18
KapteinBos
KapteinBos's Avatar
Drives: Toyota 86, Pearl White, Manual
mine is half when cold and full when warm...
KapteinBos is offline   Reply With Quote
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
hid light levels jaiminsong Cosmetic Modification (Interior/Exterior/Lighting) 16 10-27-2012 09:44 PM
Radiation levels adam Scion FR-S / Toyota 86 GT86 General Forum 7 07-01-2012 03:32 PM
FR-S Trim levels... nate89 Scion FR-S / Toyota 86 GT86 General Forum 155 08-05-2010 02:51 AM
