Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > New England
New England MA, ME, NH, RI, VT
Old 01-28-2013, 01:04 AM   #29
Wasabi
おい、だいじょうぶ?
Wasabi's Avatar
Drives: BRZ Limited 6 Speed
is it too late to get in on this??
Wasabi is offline   Reply With Quote
Old 01-28-2013, 06:10 AM   #30
2forme
Anyone have any pictures? I'd definitely be interested if they provide salt protection.
Old 01-28-2013, 10:28 AM   #31
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Pics of what? The under panels?
Originally Posted by ayau View Post
JDM models have 4 panels, 2 in the front, 2 in the back.
USDM models have 1 small panel to cover the brake lines.
Beyer Subaru is offline   Reply With Quote
Old 01-28-2013, 05:24 PM   #32
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
There is a pretty big thread about these. I think $250~350 is cheap for OEM windtunnel tested aero that improves MPG, reduces road noise, offers underbody protection and decreases lift. They aren't too heavy either, I think around 5 pounds or so. I mean, this is knock off front lip money here for OEM aero! Bargain if you ask me.
I got notification from japanparts that the parts are on their way...Estimated time of arrival (around) 2013/02/12. I'm just going to PM people in the order they posted here when they arrive.
industrial is offline   Reply With Quote
Old 01-28-2013, 05:31 PM   #33
Beyer Subaru
Just be very careful at install not to over torque the nuts. You only want to pull them in snug or just past hand tight.
Old 01-28-2013, 05:34 PM   #34
schtebie
Drives: CBS BRZ Limited
Same here.
schtebie is offline   Reply With Quote
Old 01-28-2013, 05:55 PM   #35
2forme
I'm interested, @industrial.
Old 01-28-2013, 06:29 PM   #36
jmaryt
Drives: 2012 honda civic ex
Realistically, your benefit per dollar spent is better on tires and wheels.
In theory, the panels will reduce drag coefficient to 0.27cd vs 0.28cd (if you have the wing) and better gas mileage.
There's also the benefit of protecting the undercarriage from road salt. Although, it will probably still seep in, but the amount will be reduced.
one wonders if the salt is able to "seep" in,so to speak,won't it be trapped,and be difficult to wash off the car?
jmaryt is offline   Reply With Quote
Old 01-28-2013, 07:03 PM   #37
ayau
Drives: Some rust bucket
Theoretically, yeah. I'm almost 100% sure particles will get in between the panels and the underbody because it's not a vacuum sealed system.
Old 01-28-2013, 08:47 PM   #38
jmaryt
yup! this is what i think too! if salt gets trapped under there,it will still be exposed to air and moisture,a deadly combo. as mentioned, these panels are NOT air,and moisture tight.
i would think that keeping the under body open will allow for a thorough cleansing and drive all the salt from the car!..just sayin'
Old 01-29-2013, 11:25 AM   #39
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
If you look at the front two panels it looks like they seal pretty tightly up against the body so they would definitely probably help with salt. If you're really worried about it you could run a bead of RTV silicone around the edge of the panel. The rear panels are in an area that doesn't get much salt anyways so it probably just helps with aero.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 01-29-2013, 12:00 PM   #40
MannyO
Night Owl
MannyO's Avatar
I was thinking about this on my commute this morning. Only difference is that I would use an adhesive foam seal.
MannyO is offline   Reply With Quote
Old 01-29-2013, 12:15 PM   #41
Sony
Sony's Avatar
That would work too, probably a better option as well. I was just throwing RTV Silicone out off the top of my head.
Old 01-29-2013, 06:37 PM   #42
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I plan to just use rubber foam weather seal around all the edges and around all the fasteners. That stuff is pretty amazing at compressing down and keeping stuff rattle-free and weather proof. I'll probably put a dab of outdoor silicone caulking with every fastener. That stuff is pretty durable and stays pliable. My panels will be sealed up pretty tight. I don't think it'll really take that much effort unless there are some huge gaps to deal with.
Undercarriage aero panels: Not on US BRZ? YankBoffin BRZ First-Gen (2012+) — General Topics 122 01-03-2015 10:56 PM
FS: FRS (oem) Rear 3/4 interior Panels NRG x FRS Interior Parts (Incl. Lighting) 8 10-19-2013 05:26 PM
FS: FRS (oem) Driver/Passenger Door Panels NRG x FRS Interior Parts (Incl. Lighting) 3 11-28-2012 12:22 AM
GTA - JDM underbody panels? wparsons CANADA 7 11-24-2012 12:18 AM
replacing body panels after racing dmg... Slide Scion FR-S / Toyota 86 GT86 General Forum 45 11-13-2011 03:13 PM
