Old 01-27-2013, 08:54 PM   #43
avp1
Drives: Traded BRZ for Supra
Originally Posted by jmaryt View Post
$750.00 to $1000.00 dollars a few bucks? (a.s.) will cut it if ya just need to get home and get out of a storm,then just wait for the roads to be plowed,before venturing out again.i can do this as i am retired would "never " buy dedicated snows.don't need,or want 'em! waste of money for me,especially when you end up traveling most of the time on bare asphalt,as they just wear out prematurely anyway!,and ya just give the money away! f**k that! just sayin' ehe! he! he!
Proper funeral costs more than a set of decent tires.
avp1 is offline   Reply With Quote
The Following 2 Users Say Thank You to avp1 For This Useful Post:
Allch Chcar (01-28-2013), Jive Turkey (01-28-2013)
Old 01-27-2013, 09:10 PM   #44
Doug&Julie
Boxer Fan
Doug&Julie's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Allch Chcar View Post
Tires are designed for a certain temperature range. Summer tires are better when it's warmer, winter tires are better when it's at or below freezing. All seasons are that mid-range (spring & fall) where if they get too warm they suck, too cold they suck.
On a 2WD car, it is necessary to get proper winter tires if/when your average temperatures are at or below freezing.
I'm not sure of the exact temperatures since it can vary with different models of tires. It can also varie by manufacturer too.
Originally Posted by dsgerbc View Post
Those don't help one bit when one needs to slow down. Even worse, it creates a false sense of grip on acceleration, increasing the perceived 'safe' speed.
Originally Posted by Enemies View Post
It really depends what your 4th season is like. The colder the weather the harder the rubber gets and the less traction you have.
The difference in stopping on snow and ice (especially in plummeting temperatures) is quite dramatic.
I personally don't need winter tires since it doesn't get cold enough here to require them over all seasons. But with that said, I always put them on regardless. Winter tires are less of an expense than the toll of having to live with the fact that you maybe injured or killed somebody in an accident due to trying to save a few bucks.
Not arguing any of these points. Only saying that a tire described as "all season" is designed to run in all seasons...not exclusive of winter. I'm well versed in summer v winter tire usage (and, in fact, use them both on almost all of my cars).
Doug
2012 Subaru Impreza 2.0i
1986 Porsche 911
Doug&Julie is offline   Reply With Quote
Old 01-27-2013, 09:26 PM   #45
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
I never understood the cost argument against winter tires. While you use them, your other set of tires doesn't wear. While it might cost a few bucks at the end of it all, you really don't spend all that much more by swapping to a set of winters. Heck, if you have really good summer tires, you might even save some money.
The BRZ did just fine friday evening at 6:30 heading up a decent, unplowed hill in the snow. Blizzak LM-60s in stock sizes on stock wheels (the "performance" snow tires from Bridgestone). Even when it doesn't snow, it can get pretty cold. Much better driving on winter rubber than rock hard, zero grip summer tires.
Alan is offline   Reply With Quote
Old 01-28-2013, 05:29 AM   #46
Dipstik-sportech
Dipstik-sportech's Avatar
[ame="http://www.youtube.com/watch?v=To4bdBzkAAg&sns=em"]Impreza, BRZ, WRX drifting on Ice Oval - YouTube[/ame]
Fun on Lake Superior
The Following 4 Users Say Thank You to Dipstik-sportech For This Useful Post:
dsgerbc (01-28-2013), glorydays (01-28-2013), grst1 (01-28-2013), racecaresuaceb (02-03-2013)
Old 01-28-2013, 06:47 AM   #47
Enemies
Drives: '13 SWP Sport-Tech (Limited)
To each their own. I don't think any of us have an aversion to saving money. But with that said, I think there's definitely some places where it should be spent. I don't see any point in buying a $30,000 car if you can't spend a fraction more to keep it out of the ditch.
I unfortunately don't have the luxury to choose not to drive when the weather is bad so I went with (what I thought was) the safer route. I see we're not going to agree here though so... I'll drop it. Safe driving to everybody whether or not they are using winter tires or all-seasons.
I just hope nobody is driving their summers in sub-zero temperatures. Or sub-32F temperatures for you silly Americans... Just kidding!
Enemies is offline   Reply With Quote
Old 01-28-2013, 07:29 AM   #48
a2cpc
Drives: WRX
You can get a set of General Articmax(sp) 215/65/16 for $400.
a2cpc is offline   Reply With Quote
Old 01-28-2013, 07:33 AM   #49
be6sti
be6sti's Avatar
Drives: 2013 scion frs
I called and asked if my road side assistance covered rides home... They said as long as there isn't a tow ban then regardless of the situation if I don't want to drive home from somewhere for any reason I can call for a tow and a flatbed will be sent to me to take me and my car home XD! Best 8$ a month I spend
"Fuck it lets go!"
be6sti is offline   Reply With Quote
Old 01-28-2013, 07:46 AM   #50
grst1
grst1's Avatar
Drives: '94 Ford Aspire
Good stuff! I miss MN winters and ability to drive on snow and ice for good several months...
NJ winters suck.
grst1 is offline   Reply With Quote
Old 01-28-2013, 08:04 AM   #51
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Well its snowing this morning.. if u dont get any posts by me in 10hrs go change your tires.
glorydays is offline   Reply With Quote
Old 01-28-2013, 08:28 AM   #52
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
If you are swapping in winter tires for summer ones, you should definitely not wait until it's freezing out, summer tires will be too brittle even just above freezing to provide decent grip - it should be done when the driving temps start to dip below about 45F.
Sport-Tech is offline   Reply With Quote
Old 01-28-2013, 09:36 AM   #53
Allch Chcar
Drives: N/A
Try and find an expert that recommends all-seasons for winter as far North as Ohio.
Eg: http://www.popularmechanics.com/cars...andle-the-snow
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 01-28-2013, 09:51 AM   #54
dsgerbc
Drives: BRZ(sold), STI
NJ winters suck.
I feel your pain, I'm in MI now, and winter here is probably better than in NJ, but nothing compared to MN.
Just yesterday night we got good two inches, and I had to go out enjoy it right then, cause today it's 36, fog and rain, and it's gonna be in the 60s tomorrow.
WTF?
Old 01-28-2013, 09:53 AM   #55
Efenys
Drives: Galaxy Blue 6sp BRZ LTD
BRZ in Snow
I've read about a million of these posts. Each one followed by a post saying to get a good set of winter tires. This makes sense. But...
What should you do if you only get snow 3 or 4 times a year for a day but roads are clear the next day? It seems like a waste to get winter tires for 4 days of driving your car.
Is there any alternative? Any suggestions? Driving style changes?
/ :happy0180:
Thanks guys
Efenys is offline   Reply With Quote
The Following 2 Users Say Thank You to Efenys For This Useful Post:
Jive Turkey (01-28-2013), jmaryt (01-28-2013)
Old 01-28-2013, 09:57 AM   #56
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
yes, there are about a million of these posts. yours just made the total count to be a million and one.
now to answer your question, winter tires is more dependent on the temperature, not just snow. if where you live is really cold then you need winter tires cause your summer tires will turn into circular bricks.
chenshuo is offline   Reply With Quote
Having Fun in The Snow with FR-S Pavel NY / NJ / CT / PA 10 01-06-2013 06:32 PM
SNOW!!! Tanuki FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 65 01-01-2013 11:42 PM
BRZ vs. Snow? serith BRZ First-Gen (2012+) — General Topics 45 08-28-2012 07:26 PM
FRS/BRZ in the Snow smbrm Scion FR-S / Toyota 86 GT86 General Forum 38 03-23-2012 07:03 PM
BRZ in snow sieeegel BRZ First-Gen (2012+) — General Topics 40 02-22-2012 12:44 AM
