Old 01-27-2013, 01:49 PM   #1
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Eyebrow Turn Signals
Well sometimes it is hard to find a good supplier of bulbs. These are the type two switchbacks which have a constant white (or amber depending on how the pins are configured). There are about 3 other bulbs types that we'll be stocking, but this isn't a sales thread.
I was just thinking of something I could do in the meantime and came up with this.
[ame="http://www.youtube.com/watch?v=CKkXjhL54DI"]PhastekPerformance.com - Eyebrow Turn Signals - YouTube[/ame]
PhastekSport is offline   Reply With Quote
The Following User Says Thank You to PhastekSport For This Useful Post:
Anthonytpt (01-27-2013)
Old 01-27-2013, 02:08 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I really like the idea (and your headlights), but they aren't bright in any way.
Old 01-27-2013, 02:09 PM   #3
DIM
Do a video of this outside, I wanna see how it looks in the sun.
DIM is offline   Reply With Quote
Old 01-27-2013, 02:13 PM   #4
boredom.is.me
Custom User Title
Also, your advertising photos aren't great. The car doesn't come with white headlight housings, so having all of your headlight products mounted to your white headlight housing is a bit pointless as it is damn near impossible to get a good perspective of what it might look like in person on a stock headlight.
Just a little constructive criticism.
Old 01-27-2013, 02:19 PM   #5
PhastekSport
Not a sales thread. Just a guy with an FR-S in this thread.
I'll do some video outside. I mounted them really far back so that the LEDs themselves couldn't be seen.
Old 01-27-2013, 02:27 PM   #6
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
what's that green car? show us the green car!
chenshuo is offline   Reply With Quote
Old 01-27-2013, 02:37 PM   #7
PhastekSport
Green car...
35mm f/1.4 lens @ 25 meters away. DX camera so 1.5 crop.
It's cloudy outside, so the best I could do is turn all the lights on including the halos. All those lights are very good at washing out anything else, but you can still see the eyebrows. They were moved a little lower.
[ame="http://www.youtube.com/watch?v=gll6sgjK7NQ"]PhastekPerformance.com - Eyebrow Turn Signals x 2 - YouTube[/ame]
The Following 3 Users Say Thank You to PhastekSport For This Useful Post:
BRZranger (01-27-2013), chenshuo (01-28-2013), Dadhawk (01-27-2013)
Old 01-27-2013, 07:08 PM   #8
PhastekSport
Oh and this is what white CCFLs look like in a stock casing.
Old 01-27-2013, 08:00 PM   #9
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Definitely like the idea but i would personally user bigger led strips that span the entire length of the top of the headlight and the outer curve. That might help the visibility of it a bit
abutterman is offline   Reply With Quote
Old 01-27-2013, 08:39 PM   #10
PhastekSport
Thanks for the suggestion. It was moved down from the original video. I'm just worried I'll get into a situation where it wouldn't look clean. Right now it's easy to do AND clean. To continue around the curve, they would probably have to mounted to the inside of the lens.
The density of this strip is much greater than most. If the sun decides to come out tomorrow, I'll see if they can be seen across a typical intersection under the brightest of conditions.
Old 01-27-2013, 10:24 PM   #11
abutterman
abutterman's Avatar
ahh yea if they're thicker it might be tough. I would definitely want to test in both day and night to see if the drls or the low beams drown out the light. HIDs would be something to consider too. You got me interested though... might have to take a closer look at the available space around the lights.
Old 01-28-2013, 01:52 AM   #12
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
It would be cool to get the "boomerang" light to act as a turn signal on the BRZ.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
eyebrow, turn signal
DIY JWMotoring LED turn signals sirhc DIY (Do-It-Yourself) Guides 54 03-16-2013 03:22 PM
Are Switchback Turn Signals Legal? i_4got CANADA 7 11-03-2012 05:47 PM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
