Old 01-12-2013, 08:20 PM   #169
OrbitalEllipses
Drives: Attitude
Originally Posted by Propaganda View Post
I think some others have posted, but I kept forgetting to chime in. After the reflash, yes the car gets up to temp SO MUCH faster than before.
I've noticed it takes a while for the water temp to hit where it usually stays, but it's been cold so I hadn't given it a second thought. It usually takes me 5 miles or more of driving to see that needle close to where it needs to be. I'll report back after I get this recall whenever that is.
Old 01-13-2013, 11:09 AM   #170
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
Originally Posted by Mo707 View Post
I haven't noticed. Haha
Maybe it's just me? Lol. Before the reflash, I could sit for a minute or 2 idling and then after a 5 minute drive, the needle would barely move. Same conditions (low 30°s) it now actually moves a decent amount.
Propaganda is offline   Reply With Quote
Old 01-14-2013, 11:03 AM   #171
Marrk
Drives: Honda Fit
Originally Posted by frs23 View Post
Same for me, but they didn't order a new one for me, instead they said they had link problems and for one car it took over a dozen tries to flash. Thus, they said they will wait for Scion to address the problem before flashing later on.
Which dealer?
Marrk is offline   Reply With Quote
Old 01-16-2013, 12:41 PM   #172
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I agree. At least, the temp starts going up much sooner. With stock gauges, who knows when it really reaches operating temp.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-25-2013, 04:18 PM   #173
developer
Drives: BRZ Limited
I was wondering why I hadn't been notified yet of this TSB by Subaru. So I took a look at my ECU and I already have the second version of the ECU (811) from the factory so it looks like the recall only applies to BRZs with an orignal 810 version ECU.
FYI: Reading the number on the ECU without removing the ECU is not easy.
developer is offline   Reply With Quote
Old 01-25-2013, 07:21 PM   #174
whtchocla7e
Drives: 2013 FR-S Hot Lava
I have the 811 chip and it qualified for this reflash.
Also, I have noticed that the tach sweep is gone after this update. Did anyone else notice this?
Live to drive another day
whtchocla7e is offline   Reply With Quote
The Following User Says Thank You to whtchocla7e For This Useful Post:
developer (01-26-2013)
Old 01-26-2013, 10:49 AM   #175
Marrk
Drives: Honda Fit
"the tach sweep"? You mean on start-up?
Old 01-26-2013, 06:31 PM   #176
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Had the re-flash done at the dealer. Still get the sweep.
davesrave is offline   Reply With Quote
Old 01-26-2013, 07:02 PM   #177
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Just picked mine up from the dealer after having the Toyota version of this reflash.
The RPM drop during hard braking is gone and it feels like it's picked up some thing extra in the top of the RPM band.
Huzzah!
Freeman is offline   Reply With Quote
Old 01-26-2013, 07:02 PM   #178
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
RTFM.
Subie is offline   Reply With Quote
Old 01-27-2013, 08:26 PM   #179
whtchocla7e
Originally Posted by Subie View Post
RTFM.
THXA.
Old 01-27-2013, 08:46 PM   #180
developer
Drives: BRZ Limited
I really appreciate you letting me know about your ECU version. I will call up Subaru tomorrow and see why I have not been notified about the TSB. If the flash turned off the tach sweep that would be a change in DEFAULT behavior as mine had/has the tach sweep turned on from the factory. If I can talk Subaru into giving my car the flash, I will let you know if mine gets turned off.
I don't understand why people can be so grumpy?
Old 01-29-2013, 10:42 PM   #181
developer
Drives: BRZ Limited
Okay this is the official word for WQC-39 from "Jodie" at Subaru corporate. I cut and pasted this from the email. My car missed by about 400.
"The VIN range was from D*600007 through D*603007"
Old 02-25-2013, 04:59 PM   #182
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Originally Posted by bryan View Post
Just got the reprogramming done this morning for the recall. I've only driven it from the dealership to the office, about a quarter mile, and can definitely feel a significant lack of throttle response. It has the throttle response of a 1970s vintage classic. The 30 mile drive home should help the computer get back up to speed.
So did throttle response improve since then?
I just got this reflash on Saturday and immediately noticed the throttle tip in is much slower (requires more input at the beginning).
Parked the car and drove to work this morning (only 3 mile commute), so probably have less than 25 miles on the car since reflash.
Sort of feels like those Mercedes Benz throttle, requiring lot of throttle tip in to get it to start moving, except now it's throwing off my manual transmission timing. Have not stalled it, but got close to it from not giving enough pedal tip in compared to before.
Hope it goes away or my right foot adjusts to it.
brz7400 is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
