Old 01-20-2013, 05:29 PM   #43
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by Sean-S View Post
No biggie, wish they wouldn't have removed my initials from my name though. Got ahead of myself, was going to become a vendor in Feb. but wanted to check out the forum first, see how the community was.
Yeah that's weird, sorry to thread jack again but good luck!
Old 01-20-2013, 07:27 PM   #44
ScionFamily
ScionFamily's Avatar
Drives: Magnetic Gray tC, Silver FR-S
Dude that's sick! Any turbo lag?
ScionFamily is offline   Reply With Quote
Old 01-20-2013, 08:31 PM   #45
Supermassive
Supermassive's Avatar
Well it's like any turbo you have to be in boost for it to make power and it really isn't in boost until about 3500rpm, so up to that point its almost stock feeling. After that it maxes boost somewhere around 4500 and it just pulls like a freight train about 8500rpm. It's too much fun, I have to be careful now because all i want to do bury the throttle and hold on...it will do roll on burnouts now in second...kinda surprised me.
Supermassive is offline   Reply With Quote
Old 01-20-2013, 09:21 PM   #46
JoeBoxer
JoeBoxer's Avatar
Just saw the video on Facebook, can't believe it's going to 8500 rpm I bet the sound is awesome in person.
Old 01-21-2013, 04:26 PM   #47
Supermassive
The sound is ridiculous...
Just a heads up for anyone who cares I'm gonna be going to the Import Face Off at Firebird Raceway this coming Sunday, hoping to get at least Best Scion.
http://www.importfaceoff.net/
I have a bit of work to do to clean up the car a bit, it's really short notice for a car show, but I figure I'll get my feet wet with this one. By April-May time frame I should be almost done with this car. I've decided to postpone the 818R for the time being while I finish this car up.
Old 01-23-2013, 05:47 PM   #48
Supermassive
DYNO CHARTS!!!!
23JAN13 7PSI DYNO by Supermassive80, on Flickr
Old 01-23-2013, 08:06 PM   #49
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
How do 255's work with 255rwhp? How do you plan on keeping traction with 420rwhp in the future?
Tansey86 is offline   Reply With Quote
Old 01-23-2013, 10:03 PM   #50
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
What Psi?
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3
2013 Scion FR-S
2011 Land Rover LR4
2013 Lamborghini Gallardo LP570-4 Superleggera
Kochinopride is offline   Reply With Quote
Old 01-23-2013, 10:04 PM   #51
Kochinopride
I'm running the same turbo with 20psi... Easy way to keep traction is running 18x11 on the front and 18x12... So that equals wide body kit!
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
Old 01-23-2013, 10:09 PM   #52
Visconti
Drives: 05 STi
RaceRom traction control and per gear boost control is the best way to take care of traction
Visconti is offline   Reply With Quote
Old 01-23-2013, 10:44 PM   #53
Xdragonxb0i
Drives: ex500r
What are you gonna do about Cooling your oil and engine? Especially in AZ
Xdragonxb0i is offline   Reply With Quote
Old 01-23-2013, 11:12 PM   #54
Supermassive
My current Invo's are having a hard time keeping from spinning, I need to get with a suspension guru to get the car set up properly and let a little air out of the tires. I'm planning on going with 275's in the rear probably in line with some Hoosier semi slicks. It will square up the tire so I have more tread in contact with the ground plus with a lower tire PSI I should be fine.
Originally Posted by Kochinopride View Post
What Psi?
This is running 7 psi at the moment, waiting on the flex fuel kit from @Visconti before i push it further.
If there was a widebody kit that didn't scream Tokyo Drift, I would probably get one, until then I will just work on getting suspension and tire combinations right to keep things semi sane.
^^^^ Can't wait to get all this done!
P&L Motorsports has been working on an oil cooler I am planning on buying as soon as they finish it. As for the radiator...Koyorad has me covered You'd think I could get a sponsorship or something since I'm practically P&L's posterboy for all things FRS/BRZ!!!
Old 01-25-2013, 02:37 AM   #55
Supermassive
So someone wanted a line by line tally of what i have invested in this car so far...this isn't a **** measuring stick, but I will say it's not as much as I had thought it was. Of course this is all MSRP and I did get some discounts but paid shipping on other things so it's probably close to the actual amount of money I have spent...so far
P&L Motorsports Stage 1 Turbo kit $4,999.00
Red Wrinkle Coating $150.00
Fuel Pump & 700CC DeatschWerks Injectors $550.00
EcuTek Cable/License/Base Map$800.00
4 Bar MAP Sensor $129.00
P&L Motorsports 2.5" Overpipe $279.99
P&L Motorsports Street Series Catback Exhaust System $799.95
AEM Failsafe Gauge $316.65
Prime Motoring Gauge Cluster $280.00
Agency Power Lightweight Crank Pulley (Red) $130.00
Agency Power Adjustable Rear Lower Control Arms $650.00
GrimmSpeed Oil Filler Cap Billet Aluminum $99.99
Whiteline Positive Shift Kit Bushing $34.90
Whiteline Positive Rear Crossmember Mount Insert Bushing $44.90
Clutchmasters FX400 6 Puck Clutch/Flywheel $1,150.00
KW Suspension Variant 3 Coilovers $2,200.00
Rays Gram Lights 57 Extreme Wheels (Satin Black) 18x8.5 (x2)$906.00
Rays Gram Lights 57 Extreme Wheels (Satin Black) 18x9.5 (x2) $952.00
Nitto Invo Tires (235/40/18) x2 $363.30
Nitto Invo Tires (255/35/18) x2$424.20
Muteki Lugnuts - RED CLOSED Ended $65.00
Tactrix 3-Port Electronic Boost Control Solenoid$93.00
Speed By Design 290LPH Fuel Pump $149.99
Subaru BRZ Rear Diffuser $749.00
Seibon TS-Style Carbon Fiber Hood $780.00
Seibon Carbon Fiber Rear Fin Spoiler $380.00
Seibon SN-Style Carbon Fiber Rear Spoiler$460.00
Billet Pro Shop Short Shifter (Red) $239.00
Team Voodoo Shift Knob Magnum Pearl $41.95
Pioneer AVIC-X940BT Navigation Head Unit $800.00
Total $19,017.82
The Following User Says Thank You to Supermassive For This Useful Post:
kanundrum (01-25-2013)
Old 01-25-2013, 01:20 PM   #56
Turbowned
Turbowned's Avatar
You see kiddies, a properly modded car is more than throwing a bunch of eBay Chinese parts on your car and installing them with Harbor Freight tools in your parents' driveway. You gotta pay to play! I shudder looking at this because the list of things I want to do is even longer
Very nicely done, sir!
p&l motorsports, supermassive, turbo fr-s
MT Whiteout available now... JohnATL Southeast 8 08-09-2012 01:12 AM
Too much whiteout?? PrinzJ FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 07-27-2012 01:10 AM
My new Whiteout FR-S! Flawless22 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 07-05-2012 02:46 AM
My whiteout fr-s F3dzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 07-04-2012 07:25 AM
Whiteout FR-S/86 just86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 04-01-2012 01:16 AM
