Old 01-12-2013, 02:52 PM   #1
NickFRS
Drives: 2013 Asphalt FRS
motul 300 vs motul 300ls about to buy some need help.
just used the search button 100000 times but don't want to dig through thousands of pages of people argueing what oil is the best..... so don't be like
Which one do I need???? Standing in the store lol.
NickFRS is offline   Reply With Quote
Old 01-12-2013, 02:54 PM   #2
Hanakuso
Normal 300. The LS can be used in the diff but not needed but cannot be used in the tranny
Hanakuso is offline   Reply With Quote
Old 01-12-2013, 02:58 PM   #3
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Which store are you getting the motul from? I need to pick up a few bottles of the non-ls stuff.
tech4pdx is offline   Reply With Quote
Old 01-12-2013, 03:17 PM   #4
NickFRS
I guess its not a store... my buddy has an online store and has loads of oils he is getting rid of at his place. Looks like the regular motul is spoken for though.... So looks like im using redline. Thx for the help @Hanakuso This can be deleted now!
Old 01-12-2013, 03:27 PM   #5
tech4pdx
Make love
tech4pdx's Avatar
It's all good. I'll order it online. I can't find anybody out in the Portland area that carries it in stock.
Old 01-20-2013, 02:09 AM   #6
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I used motul 300ls in my trans and rear end.
"100% synthetic lubricant for all mechanical transmissions of high performances and racing cars. For synchronised or none synchronised gearboxes, gearbox/differential, transfer gearboxes and hypoid differentials with limited slip system operating under shock."
I see no reason why this is a problem
I love it and have no issue with second gear notchy issue.
jdzumwalt is offline   Reply With Quote
Old 01-20-2013, 02:59 AM   #7
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I wouldn't use the ls in the trans, no limit Motorsport is a great source for Motul they have everything in stock and ship fast. Adam is a great dude too!
Old 01-23-2013, 11:27 AM   #8
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Thanks Joe.
I may not be the best with everything, but I do have many thousands of dollars worth of Motul in stock at any given point. Tons of 0W20 8100 and 300V, as well as all the tranny fluids such as the Gear 300's, and all the brake fluids. Basically everything they carry.
Adam
No Limit Motorsport is offline   Reply With Quote
Old 01-23-2013, 11:37 AM   #9
JoeBoxer
JoeBoxer's Avatar
Originally Posted by No Limit Motorsport View Post
Thanks Joe.
Adam
Don't want to start a new thread for this question but do you think mixing a can of 300v and 4 quarts of 8100 is a good idea? I've seen it mentioned but seems contradictory to what i've been told in the past.
Old 01-23-2013, 11:40 AM   #10
CSG Mike
CSG Mike's Avatar
You can do it with no adverse effect
Old 01-23-2013, 11:41 AM   #11
No Limit Motorsport
I say keep them separate, 300V is liquid gold. However I believe you can mix the oils. Call Motul USA they are very helpful and knowledgeable 1 (800) 926-6685
Old 01-23-2013, 11:42 AM   #12
CSG Mike
CSG Mike's Avatar
The 300 works in both the trans and diff. However, we use the 300LS in our diff, only because we like the lockup characteristic better. Both will protect the diff just fine.
If you park the car in sub-50 temps, please let the diff warm up before driving hard! You'll notice it locking very easily when it's cold.
Old 01-23-2013, 11:43 AM   #13
JoeBoxer
JoeBoxer's Avatar
I like the 300v a lot but just wondering if its overkill since i don't ever get the oil really hot at the track or anything.
Old 01-23-2013, 12:01 PM   #14
No Limit Motorsport
You have a good point. For your use the 8100 is probably the best choice.
Motul gear 300 or Redline MT90? BRZ NA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 70 11-30-2016 03:02 PM
Motul fluids Filipino Royale Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 88 04-20-2014 09:36 PM
motul Oil whitefrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 05-24-2013 10:12 AM
Delete driver01 CANADA 5 08-30-2012 04:58 PM
Service Parts! Motul Oil / Oil Filters vividracing Mechanical Maintenance and Tools 8 06-20-2012 12:46 AM
