Old 01-22-2013, 09:16 PM   #1
Asphalt~86
Drives: Asphalt AT
Another "Get New Tires" Article
http://news.consumerreports.org/cars...rformance.html
Almost got that other "Boxer".
Short read.
Asphalt~86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Asphalt~86 For This Useful Post:
jadewbj (01-23-2013), Splat (01-22-2013), Stevieray (01-23-2013)
Old 01-22-2013, 09:25 PM   #2
PNW FRS
PNW FRS's Avatar
Would have nice if CR had mentioned a bit more info on the specs of the Yoshihara 18x8 wheels.... which model.... offset...
Guessing from the price mentioned... I'm guessing they went with the DY-12C wheels. http://www.yoshiharadesign.com/d-12c-2/
PNW FRS is offline   Reply With Quote
The Following User Says Thank You to PNW FRS For This Useful Post:
Asphalt~86 (01-22-2013)
Old 01-22-2013, 09:28 PM   #3
Asphalt~86
Drives: Asphalt AT
Thanks for that I was wondering myself and trying to look into it.
The Following User Says Thank You to Asphalt~86 For This Useful Post:
Ocala FR-S (01-22-2013)
Old 01-22-2013, 09:31 PM   #4
HotLava
Drives: Hot Lava 2013 FR-S Automatic
I guess I'll embarrass myself with this question. But does going to 18 inch rims maker your speedometer reading inaccurate? I just remember that when I had my Mustang guys would have to report what non stock tires and rims they were using to their tuner, so their customer tunes could compensate for that.
HotLava is offline   Reply With Quote
Old 01-22-2013, 09:32 PM   #5
ayau
Drives: Some rust bucket
If you browse around in the autox/track forum, you'll see a lot of guys running 17x8. It seems to be a nice compromise between weight and width. Most people don't go with 18" unless they have a big brake kit.
Old 01-22-2013, 09:34 PM   #6
ayau
Good question. Your speedometer will not be off that much as long as you go with a lower profile tire. The diameter of the tire is the important number, not the wheel diameter. As long as the old and new tire diameters are similar, then your speedometer will still be relatively accurate.
The Following User Says Thank You to ayau For This Useful Post:
dem00n (01-22-2013)
Old 01-22-2013, 09:37 PM   #7
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Change the tires if you know what your doing, if you don't know what your doing then leave it stock.
I speak to most of the forum when i type that.
The Following 3 Users Say Thank You to dem00n For This Useful Post:
CaptainSlow (01-23-2013), Ingen (01-23-2013), lantsalot (01-23-2013)
Old 01-22-2013, 10:02 PM   #8
Synack
Boosted
Synack's Avatar
Drives: Sideways
We all know that the tires that come on it completely suck. The biggest reason why they are used is because they allow the driver to break traction a bit easier. After all this car was built with drifting in mind.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 01-22-2013, 11:23 PM   #9
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I think for 99.5% of the people doing daily driving these tires are just fine. That said, when it comes to replacing them I'm going with a stickier tire.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
The Following User Says Thank You to russv For This Useful Post:
strat61caster (01-23-2013)
Old 01-23-2013, 06:05 AM   #10
fistpoint
Drives: Supercharged Golf Cart
Just about every tire seller has a section somewhere on it describing how to upgrade your wheels/tires using what they call +1 or +2 etc.
The trick is keeping the overall diameter of your new tire to be the same as the old one. It's that simple. Discount tire for example tells you the overall tire diameter right there for every tire they sell for every size.
fistpoint is offline   Reply With Quote
Old 01-23-2013, 09:52 AM   #11
FRiSson
Drives: FR-S MT
Hey, a little hyperbole goes a lonnnnggg way.
I like the stock tires. True, they don't have a whole lot of friction, but they communicate beautifully and predictably. If I were involved in motocross, I would want something different, but for driving on asphalt in a reasonably sane way, these tires are the best standard tires that I have experienced.
FRiSson is offline   Reply With Quote
The Following 2 Users Say Thank You to FRiSson For This Useful Post:
BadCompany235 (01-23-2013), lantsalot (01-23-2013)
Old 01-23-2013, 09:55 AM   #12
#87
I usually post drunk
#87's Avatar
Did they stick with 215 width?
#87 is offline   Reply With Quote
Old 01-23-2013, 10:07 AM   #13
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Since they used 18x8 rims, I'm guessing they bumped up width (maybe to 235? it would have been nice if they specified in the article)
campy is offline   Reply With Quote
Old 01-23-2013, 10:19 AM   #14
Synack
Boosted
Synack's Avatar
Drives: Sideways
The best stock standard tires I have experienced were the stock 275 width tires on my Nismo 370Z.
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
New article - JDM spec "Review From The Backseat" sastexan Scion FR-S / Toyota 86 GT86 General Forum 7 12-04-2012 03:07 PM
"86 Already Sold Out" Article BigM AUSTRALIA 112 06-13-2012 01:43 AM
Another Speedhunters article "Modified Toyota 86 86" blur Scion FR-S / Toyota 86 GT86 General Forum 7 11-29-2011 12:00 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
