Old 01-22-2013, 07:32 AM   #15
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Originally Posted by Stance86 View Post
I'm running a rear 255/35 on a 9.5 + 38 and I don't think you could go much wider on stock guards.. it's close at the moment, maybe a 265.. think the only way to get a 275 would be to run more camber... if you run coilovers you will get more room on the inside so you might be able to run a higher offset wheel than the +40 you were planning and get a 275 on.
And.. it will change the way your car drives, be ready for it..
My rear offset is +40 so I think I'm gunna go with a 265/35 where is it going to rub? and changing the way it drives in what aspects?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-22-2013, 02:02 PM   #16
ScionFR-S
ScionFR-S's Avatar
Bump
Old 01-22-2013, 02:37 PM   #17
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i ran a 275/35/18 on my sti, its the perfect width IMO. the issue is all tires run different. some 255's are as wide as other companies 275's so when you buy, look up the width in inches.
here is what that looked like:
those are sumitomo HTR Z III 275/35/18 they are middle of the range as far as width. i know Starspecs run really wide so do michelin PSS. if my sti wasn't hit, i was going to step up to the same sumitomo's but in a 295/30.
however, anything bigger than a 255, as long as it's a good grippy tire will be over kill for the brz. i plan on doing 9.5' wide all around with a 255/35 PSS tire. adding so much rubber will make it a purely momentum car, and it'll struggle to really turn it. by saying change the way it drives, the car will not rotate as easily, so you really will have to turn in and hammer the gas to get it right. you dont want to simply slap on maive tires in the rear and keep something skinny in the front either, a nice square setup will be perfect for this car. just do a start spec or a michelin PSS in a 255, trust me those run wide.
this bug eye is running a 255/35/18 starspec on 18x9.5 +38 works...look how meaty it looks:
jut remember, when it comes to tires its not the width aspect that counts, but its compound and the actually contact patch you put down. bigger doesn't mean more contact...
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
charged86 (01-08-2014)
Old 01-22-2013, 03:19 PM   #18
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
^^ Beautiful pics
Chimpo is offline   Reply With Quote
Old 01-22-2013, 03:40 PM   #19
ScionFR-S
ScionFR-S's Avatar
How do I find out the actual width ? Is the Yokohama mid range for width ?
Old 01-22-2013, 03:55 PM   #20
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
yokos are pretty much middle of the pack IIRC
FreshFRS is offline   Reply With Quote
Old 01-22-2013, 08:32 PM   #21
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I just put on my new wheel/tire setup bout an hour ago. 18x8.5 +35 Fronts with 235/35/18 and 18x9.5 +30 Rears with 255/35/18. Fitment is excellent, fronts clear lock to lock, rears have a safe distance of clearance. I went with BF Goodrich G Force TA KDW. I went with these because I dont do much cold or wet weather driving and BFGs have a strong sidewall and a great contact patch. They are 300 AA A rated so theyre not as sticky as a Starspec or R888, but at temperature, they grip very well on dry road.
Pure Automotive is offline   Reply With Quote
Old 01-23-2013, 09:43 AM   #22
Pure Automotive
Old 01-24-2013, 11:49 PM   #23
ScionFR-S
ScionFR-S's Avatar
Nice man looks great...pretty sure u guys follow me on insta haha names mikeymacfrs
Old 02-08-2013, 10:10 AM   #24
AtlasMick
Drives: FR-S 2013 Asphalt
Sorry, new to the wheel game. What does "clear lock to lock" mean? Do these size wheels/tires combo clear the fender when you hit bumps or turn sharply? And do you have aftermarket coilovers or shocks that alter the ride height?
Cheers!
AtlasMick is offline   Reply With Quote
Old 02-08-2013, 12:07 PM   #25
Pure Automotive
It doesn't hit when the steering wheel is turned all the way left and all the way right, or lock to lock.
I have stock shocks with Eibach Pro Kit 1" drop
Old 03-07-2013, 10:02 AM   #26
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
are the R888 okay to drive to the track? sounds like you own a set?
Huehuecoyotl is offline   Reply With Quote
Old 03-07-2013, 12:29 PM   #27
wWaldo
Drives: Asphalt Frs
i'm running 255/35/18 just a bit of a poke but nothing dramastic!
fits perfect imo
When i drop it, it'll look flush
wWaldo is offline   Reply With Quote
Old 03-07-2013, 12:59 PM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
They are definitely fine to drive to the track. They might get hairy if you shave them down to 4/32nds and then drive to the track in the rain though.
WTB: 1 OEM wheel with or without tire #87 Wheels and Tires 11 01-31-2013 01:21 AM
tire/wheel setup? kosoku Tracking / Autocross / HPDE / Drifting 0 11-25-2012 09:53 PM
What is the widest tire for these wheels? ngabdala Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 09-12-2012 09:20 AM
18x9 wheel fitment and options? epson1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-31-2012 05:36 PM
Widest rear tire for a staggered setup? Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-22-2012 08:52 PM
