Old 01-06-2013, 02:26 PM   #15
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Originally Posted by Derrickchai39 View Post
I know they have the ignition start prevention system with the specific chip in the keys for your car. But my girlfriend the other day went to one of her grandparent's friend who knew how to copy these keys for less than 100$ with a machine. I doubt that just having that system would keep thieves away. I was told by my sales rep that Toyota came out with this on all their cArs starting from 2008. But did that stop any thieves from taking toyotas from then till now? What do you guys think!
Toyota has been using chipped immobilizer keys for a lot longer than that.
Subie is offline   Reply With Quote
Old 01-22-2013, 11:06 AM   #16
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Still figuring out this alarm thing on my frs that toyota dealer installed..do I have to activate it? I read the manual and says has to be activated by scion dealer but they told me thats already installed and has the low jack thing were its disables the engine/ecu ect..
When I lock the door with the remote and
wait like a min then I open the car with the key and the alarm wont beep/go off..also tried like pushing/bang on the windows and no alarm goes off..this have like motion alarm ?
Seems like its not activated and only locks/opens door/trunk and panic alarm beeps if I hold the panic button down..
Old 01-22-2013, 01:31 PM   #17
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
You should try locking it with the windows down then opening the car door from the inside to see if that trips the alarm. I doubt this car has some sort of Window banging sensor lol
bdanisi is offline   Reply With Quote
The Following User Says Thank You to bdanisi For This Useful Post:
marky (01-22-2013)
Old 01-22-2013, 01:56 PM   #18
Burninator
Trogdor ftw
Burninator's Avatar
Drives: Asphalt FR-S M/T
If you just have a LoJack installed, it is generally only activated when you file a police report if your car is stolen and the police get involved:
http://en.wikipedia.org/wiki/LoJack#How_it_works
There is an upgraded version that sends you alerts if your car is moved without a paired keyfob nearby though (although I've read that it even can have lot of false positives sometimes if your keyfob isn't working right or has a weak battery, etc.).
Burninator is offline   Reply With Quote
The Following User Says Thank You to Burninator For This Useful Post:
marky (01-22-2013)
Old 01-22-2013, 01:59 PM   #19
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
Have the dealership look at it. My alarm was from Toyota as well, it has vibration sensors which will give 3 horn blasts when it feels vibration. The full alarm will only go off if a door or window is breached. The dealership should be able to adjust your sensitivity.
EK_Golfer is offline   Reply With Quote
The Following User Says Thank You to EK_Golfer For This Useful Post:
marky (01-22-2013)
Old 01-22-2013, 02:17 PM   #20
marky
marky's Avatar
Originally Posted by bdanisi View Post
You should try locking it with the windows up then opening the car door from the inside to see if that trips the alarm. I doubt this car has some sort of Window banging sensor lol
Yeah I tried that even locked myself inside with windows down and locked it with the lock button on the key and waited a min or so then open the car and nothing..no sound alarm..
Can I go to any toyota/scion? Or has to be the same one I got my car from? Dont like to drive that dealer due to its a bit far and I have a dealer closer to me...
Also can I adjust/set it myself ? Or has to be done by dealer only?
Thanks
Old 01-22-2013, 09:45 PM   #21
EK_Golfer
EK_Golfer's Avatar
Thanks
Each dealership contracts their own alarm people so it's probably easier to go back to the same dealer, especially if it sounds like the wiring is not quite right. I don't have enough experience with alarm wiring so I didn't bother looking at it myself, plus I don't know where they put my vibration sensor etc.
Old 01-22-2013, 10:27 PM   #22
marky
marky's Avatar
Yeah have to go back to same dealer.. not feeling it over that dealer
Old 01-22-2013, 11:22 PM   #23
Lonewolf
Lonewolf's Avatar
Drives: Moped
So the FRS actually does come with a factory alarm that is simply deactivated? Why isn't this anywhere on the website?
I have heard this before, but have not seen any evidence to support the notion. Can anyone confirm this?
Old 01-22-2013, 11:25 PM   #24
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
i doubt it. i know for sure that it has a immobilzer pre installed but not alarm.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 01-22-2013, 11:56 PM   #25
EK_Golfer
EK_Golfer's Avatar
No, the alarm is definitely an add on as I had to bring my car back to the dealership to get it installed.
Old 01-23-2013, 12:05 AM   #26
marky
marky's Avatar
yeah have to go back... not feeling that dealer after they rob me..well lessoned learned
you have like the motion sensitive alarm ? mine do beep if i lock the doors with the key button and im inside and wait like a min and bounce around the seat and even open the door and no alarm goes off... cant wait to go back to the dealer tomorrow if they call me in just want my alarm fixed/ re work my tint and get the F%$* out there and never come back
did it take long to get the alarm fixed ?
Old 01-23-2013, 12:18 AM   #27
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
dealer installed my alarm for 1hour 30min. everything works well. my alarm gives u also a beep signal, after locking doors, after 3-5 minutes it gives u a fast 6 honk sound (lol hard to explain), just a signal that my car is fully locked and alarm activated. its like if i dont hear that sound, that means i forgot to locked/alarmed the door.
The Following User Says Thank You to 86 FRS For This Useful Post:
marky (01-23-2013)
Old 01-23-2013, 02:11 AM   #28
Mo707
Mo707's Avatar
My sisters friend has it. I find it extremely annoying. Haha
And it always makes me think someone hit it so I always run out in my boxers and a shot gun... :P
Mo707 is offline   Reply With Quote
Alarm System on the Limited Smokinbuffalo BRZ First-Gen (2012+) — General Topics 10 05-29-2015 10:17 PM
Anyone do a Viper alarm by themselves yet? hansthegerman Electronics | Audio | NAV | Infotainment 40 02-01-2014 03:31 PM
Tint and Alarm. Mo707 Scion FR-S / Toyota 86 GT86 General Forum 4 07-27-2012 10:24 AM
No Alarm? Mo707 Scion FR-S / Toyota 86 GT86 General Forum 40 07-08-2012 11:35 AM
Update on alarm ? Dkittrell Electronics | Audio | NAV | Infotainment 4 06-26-2012 02:48 PM
