Old 01-21-2013, 09:28 PM   #85
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by switchlanez View Post
Several people in my area have sprayed their FR-S/BRZ tail lights and sidemarkers with no problem. They used a brand named VHT. They are also able to completely remove the spray whenever they want (using Goof Off I think). I don't think spray tint causes cracks but you should research to double check.
I have another question which might sounds stupid. Sorry for that.
I live in PA which allow 70% window tint.
I did 35% ((side and rear) which is pretty safe. I never bother by any police even stop in front of them.
(I hear that might get ticket very easy, if tint the windshield)
How about the light tint?
How dark still in safety range? Both head and tail light is OK?
It sounds like spray paint is a better option than overlays.
I just worry might difficult to remove. I am not the shop will offer ”VHT” or not.
Thanks for your suggestion.
cslntuee is offline   Reply With Quote
Old 01-21-2013, 09:42 PM   #86
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Sure, any sort of constructive discussion here is cool with me!
There are different laws for light tints and colors in different states. For example, it's pretty strict in California and tints aren't allowed on any lights. Neither are blue nor red lights even if they have no tint (such as colored bulbs). In other states, I hear colored lights can be ok, perhaps even some tint. You have to look-up the laws for PA (you'll probably find it in your state's DMV site). You can order VHT online and should be able to find the removal procedure with google (according to my friends).
Old 01-22-2013, 02:43 AM   #87
Jeffboyarrdee
Jeffboyarrdee's Avatar
Drives: 2013 Subaru brz limited wr blue
I was wondering what kind of suspension you're running. I am interested in just swapping to the STI springs like you have, how do you like them? I am intending to run 18x8.5 gram light extremes, do you think this would be ok? Or should I stick with the stock sized wheels 17inchers since I'll still be on the stock shocks.
Jeffboyarrdee is offline   Reply With Quote
Old 01-22-2013, 02:51 AM   #88
switchlanez
I got your PM and posted part of my answer a few posts earlier but I'll recopy it down here:
My only suspension mod listed is STI springs so I'm on stock struts (which the springs were designed for). I think they are very nice, a little firmer than stock but not jarring. The car stays planted over sweeping undulations in the road. It also helps that I am on wider/taller 225/45/17 rubber all around. It feels lower than stock when I sit inside. But not so low that I scrape everywhere. I do scrape occasionally but that's because my STI front lip+rubber flap take away 2" of clearance and the rubber flap absorbs all the impact.
About the 18x8.5 Gram Lights, those should be fine with the STI springs. Be sure to select offsets that follow the Wheel Fitment Guide. 18s will just have a shorter sidewall with less vertical cushioning than 17s so the ride will feel a little stiffer on 18s (assuming you select tires that maintain stock overall diameter). It's all a matter of preference. Let me know if anything seems unclear.
Old 01-22-2013, 10:14 AM   #89
86BRZ
86BRZ's Avatar
Drives: BRZ Limited arrived on 9/1/2012
Want me to say I "hate" your threads again? JK... Super nice bro!!!
86BRZ is offline   Reply With Quote
The Following User Says Thank You to 86BRZ For This Useful Post:
switchlanez (01-22-2013)
Old 01-24-2013, 03:35 PM   #90
cslntuee
Will the taillight also has the nonuniform temperature distribution issue or
only the headlight?
Thanks again.
Sorry, I just noticed your post. Thanks for the question. I had yellow overlays on my fog lights but after researching it a bit I found any overlay will increase the potential for cracks to form in the lens. So I took them off. When temperature changes, the lens expands/contracts at a different rate than the overlay because they are different materials. Since they are mated together, one has to give way. The overlay usually has some flexibility and gives way. But when it's not flexible enough, the lens will form cracks.
I don't plan to put overlays on any lights unless there is a brand proven to not cause cracks. Cracks don't happen 100% to everyone, but the risk is there and it's up to you if you want to live with that risk. I'd say the side markers are the lowest risk and bigger pieces higher risk.
Old 01-24-2013, 03:40 PM   #91
switchlanez
only the headlight?
Thanks again.
Yes, it should because the overlay is a different material than the tail light lens so they would have different rates of expansion/contraction with temperature.
The Following User Says Thank You to switchlanez For This Useful Post:
cslntuee (01-27-2013)
Old 01-27-2013, 12:50 AM   #92
cslntuee
HI,
Do you plan to add the JDM BRZ under panel?
http://www.japanparts.com/db/parts_d...=&SEARCH_page=
Thanks.
Old 01-27-2013, 01:25 AM   #93
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I have probably one of the most unlikely mod questions for you. The little guy you've got hanging from your windshield, how is he hanging there? It looks like it's probably a suction cup. I have an 1-up mushroom for my car and I wanted something to hang it with.
Nevermore is offline   Reply With Quote
Old 01-27-2013, 02:44 AM   #94
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
This Thread= Pure Sex
R2RO is offline   Reply With Quote
The Following User Says Thank You to R2RO For This Useful Post:
switchlanez (01-27-2013)
Old 01-27-2013, 01:16 PM   #95
switchlanez
HI,
Thanks.
I've thought about it... it is a nice, functionally aerodynamic item. But I'd want it more if it were something I can see, hear, or feel in additional to being functional (like my other mods). Maybe next time when I get a crazy itch to mod.
chanomatik (01-28-2013)
Old 01-27-2013, 01:21 PM   #96
switchlanez
You got it... it's a suction cup from Walmart. Wrapped a tiny rubber band around the nub of the suction cup and the keyring which came with the toy. 1-up mushroom would look cool.
Nevermore (01-27-2013)
Old 01-27-2013, 09:54 PM   #97
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Looking at your picture of it now, it's a much nicer suction cup than anything I could find at Walmart, but I did find a solution. I bought a bath sponge that had it's own suction cup so you can hang it in the shower and cut the suction cup off. I have to take a picture of it tomorrow when I have more light.
The Following User Says Thank You to Nevermore For This Useful Post:
Old 01-27-2013, 10:13 PM   #98
FA5
FA5's Avatar
Drives: 2008 CIVIC SI, 2013 BRZ, 2013 M5
One of the most beautiful BRZ on road.
Please keep us update.
FA5 is offline   Reply With Quote
The Following User Says Thank You to FA5 For This Useful Post:
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
August 1st Charity Lapping Day - Subaru Canada - Davenport Subaru - SPDA - TSC wparsons CANADA 10 07-22-2015 01:24 PM
Subaru Cross Sport Design Concept = Subaru BRZ Shooting Brake Hachiroku BRZ First-Gen (2012+) — General Topics 91 04-01-2014 06:53 PM
Subaru LIBIRD Supercar Concept & BRZ (April Fools) switchlanez BRZ First-Gen (2012+) — General Topics 18 04-15-2013 02:20 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
