Old 01-21-2013, 06:00 PM   #1023
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by stockysnail View Post
I've seen pics with it installed so I would assume yes.
Me to, but I've seen plenty with it off as well. Honestly what I'm thinking is that everything fits, but when the engine is under heavy load it might be making contact. I have nothing to go on for that so please don't ask for proof. It's just that at least half of the pics have the bar off and I can't think of any other reason for this.
Calum is offline
Old 01-21-2013, 06:48 PM   #1024
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by swift996 View Post
- Will using a different intake solution throw off the tune? A lot of the intake kits mount right where the OEM box is, so I assume would be easy to fit right up.
This applies to all FI kits, YES, it will throw off the tune.
You know how our stock ECU is sensitive to intake changes?... Well, when you go FI it is even more sensitive.
Sportsguy83 is offline
Old 01-21-2013, 07:09 PM   #1025
drifter
Drives: truck and old car
Question for those who have experience; I am really interested in this stage 1 sc as it seems it will be safe and easier to maintain than other FI, and also reasonably priced. My main concern is engine saftey. I don't want a lot more power, just a little more.
So to add an intercooler to the stage 1 would be about $1300.
1. I don't live in a super hot or freezing area,
2. I would only plan to take this to a track once in a while (most, once a month)
3. I'm only looking for a little more power,
4. Miles would be be less than 10k year
Am I still risking it if I don't have an intercooler.??
Thank you...
drifter is offline
Old 01-21-2013, 07:15 PM   #1026
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Thank you...
Good question and I know intake and oil temps are totally different things but would an engine oil cooler be a good idea with the stage 1 kit if we don't want to run the intercooler?
JoeBoxer is offline
Old 01-21-2013, 07:58 PM   #1027
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I will definately not be doing an cooling to begin with if I go with this kit from past experience with an uncooled roots supercharger. (I know... I've said this before but...) I made 280whp on a Jackson Racing SC without cooling using an 11psi sized pulley and 550 injectors.. stock fuel pump on a K Series 4 cylinder. In the heat of summer you could notice some loss of power, but it was still nicely quick. I also knew a guy with the same setup in Phoenix and he loved it and never complained of heat issues. To be fair, the K has an oil cooler (of sorts) cooled by engine coolant.
A twin screw has a naturally cooler air charge than a roots blower, so I'm not sure I'd ever need the cooling... and for a street car with light track time, you're probably good. It's great you can add it if you need it. I do think I'll add an oil cooler since this motor does not have one.
Jeff86 is offline
Old 01-21-2013, 08:18 PM   #1028
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Thank you...
Doesn't stage 2 also have fuel upgrades?
industrial is offline
Old 01-21-2013, 08:51 PM   #1029
subatoy
subatoy's Avatar
Drives: subatoy
Thank you...
at 5psi no car needs IC specially with a SC even a turbo could get away without IC at 5psi but ask the experts.
subatoy is offline
Old 01-21-2013, 09:38 PM   #1030
Vonsamhain
Vonsamhain's Avatar
Drives: Scion FR-S (Raven)
Really? An N/A motor that already runs hot, and you don't think track use should use an IC? That's nuts. You must be a very gentle driver.
2013 Raven FR-S MT + Sparco Assetto 18x8 + Michelinn Pilot Super Sprot 225/40/r18 + Takeda CAI + Fortune Auto 500 coilovers + Tanabe Sustec front and Rear strut tower brace + Carbeau FX1 / 6 point harness / Harness Bar + Nameless front pipe + Perrin cat back + FA20club E85 tune + Wilwood front & rear brakes
Vonsamhain is offline
Old 01-21-2013, 09:41 PM   #1031
roddy
roddy's Avatar
Drives: '13 Ultramarine
I'll back this statement up. I'm running a roots (4th gen Eaton MP-90) on a 4.0 in an '07 Mustang, non-intercooled @10+ PSI. I have pretty much the same observations as above... power drops somewhat in the heat, but no damage done. If the tune is properly set up, as temperatures rise, timing is pulled to prevent detonation.
As stated above, twin screws create less heat. That combined with lower PSI, makes it a non-issue in my mind. Frequent track users may still want to opt for the intercooler though.
roddy is offline
Old 01-21-2013, 09:49 PM   #1032
swift996
swift996's Avatar
The cost differential between intercooled and non is pretty small. If you're going to do it, you might as well do it right IMO.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 01-21-2013, 09:52 PM   #1033
OrbitalEllipses
Drives: Attitude
I'd assume the already high compression nature of this engine makes running without an intercooler that much less desirable. Sounds like knock city.
OrbitalEllipses is offline
Old 01-21-2013, 10:14 PM   #1034
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Not to be rude, but a K20 is a high compression 4 cylinder. I never had any issues with knock. Most people actually experience knock on their tune during winter due to dense air charge, not heat. Warmer air just makes you slower. Just trying to bring first hand experience to the discussion.
Jeff86 is offline
Old 01-21-2013, 10:17 PM   #1035
cruzinbill
Drives: Argento 6spd FR-S
Sounds like you're just making assumptions, because people keep bringing up the compression issue and there still hasn't been anyone blow up the motor with proper tuning.
Its more likely that Innovate is going to properly tune it for the measly 5 psi and there isn't gonna be any knock issues come up.
cruzinbill is offline
Old 01-21-2013, 10:56 PM   #1036
OrbitalEllipses
Drives: Attitude
This engine is higher compression, no?
In any case I did say assume, so I don't see why we must point out that I MUST be assuming.
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
