Old 01-20-2013, 11:52 PM   #43
ayau
Drives: Some rust bucket
According to Bernoulli's principle, lowering the car will also increase air speeds under the car.
http://en.wikipedia.org/wiki/Ground_effect_(cars)
If the car is lower, then that means there's less air traveling underneath the car. Less air = less pressure = less lift/more downforce?
Old 01-21-2013, 12:10 AM   #44
EarlQHan
Drives: Subarus
My partner and I have been doing some CFD testing on the FR-S. Using the model we have, we estimate the CL to be .179, but our model has a smooth underbody. I don't expect the BRZ to have a different coefficient. A little more info is on our blog here: http://hanchagroup.wordpress.com/201...s-cfd/#more-27
EarlQHan is offline   Reply With Quote
Old 01-21-2013, 12:24 AM   #45
Dimman
Kuruma Otaku
Dimman's Avatar
Awesome.
Because titanium.
Old 01-21-2013, 01:00 AM   #46
ayau
What are you using for your model? Is it a computer generated model or a physical model?
Old 01-21-2013, 01:27 AM   #47
Hanakuso
Originally Posted by industrial View Post
Does anyone have more pictures of the TRD Griffon underbody work? I'd like to try and replicate their work since it's probably the most extensively tested stuff for our cars so far.
I hope there is more clear pics as well since the only thing I know what shows it all is in the YouTube video.
I'm planning only covering the cat + res area. I don't feel comfortable with the diff only getting air from the bottom like the TRD Griffon, whereas our stock get airflow all around the diff
Hanakuso is offline   Reply With Quote
Old 01-21-2013, 04:51 AM   #48
serialk11r
Drives: '06 AM V8V Coupe
@serialk11r Don't know if you've seen this thread. Thought you might be interested.
Hello there. Mentions aren't showing up for me.
Ecomodder has really good information on streamlining that more people in this world should go read. I actually think it's the one subforum completely untainted by people spouting crap, though ecomodder as a whole has a lot less BS floating around than just about any other forum out there.
Old 01-21-2013, 05:11 AM   #49
serialk11r
Gets complicated. Say you have a straw. The straw is really narrow, but does that mean air actually wants to go through it and suck the walls of the straw in? Not unless you have enough of a pressure difference to make flow happen.
If you want to force air under the car, it's really easy. Just channel the air below the car. I am fairly sure the only job of the diffuser is to slow the air down as it leaves the rear and recover most of the energy that went into accelerating the air as it got under the car. Of course, the air "rubs" the ground and slows down and loses energy, so there's a cost to downforce produced in this manner, but it's not nearly as bad as the high angle of attack wings.
This makes sense now when you say that most cars will generate lift. The shape of a car is similar to the shape of an airplane wing. The air above the car has to travel a longer distance than the air below the car. This pressure difference generates lift.
No, if you put an airplane wing to the ground it'll get sucked to the ground. The ground is a tricky thing.
The reason cars generate positive lift is because typically cars have a giant low pressure zone behind them (called the "wake") and a far-from-streamlined shape, so that this low pressure zone influences (and sometimes extends directly over) regions of air sitting over the top of the car. The bottom sides of a car are usually very "dirty" and so not much air tends to flow through and you don't get much negative lift from the bottom side of the car.
I guess another way to put it is that the usual car has close to zero attention paid to aerodynamics. Softened edges and tire spats have been around for a while, but they're only starting to actually put effort into aero for everyday cars.
Old 01-21-2013, 05:25 AM   #50
serialk11r
I still wonder if the OEM "diffuser" is actually decreasing lift, or if it's just there for aesthetics. For a sub 30k car, I have a feeling it's the latter.
What most people recognize as the "diffuser" isn't actually doing most of the diffuser-work. What's happening is that basically the muffler body combined with the "diffuser" is likely approximating the correct shape. Obviously, having exposed suspension, and a muffler with pipes sticking out in a few places, it's not an ideal situation.
The reason the diffuser isn't high is because there's not enough air going under the car. If you switch out the rear bumper and muffler and put on a typical aftermarket diffuser for aesthetics (yes, even the ones that are angled 10 degrees because someone thought that would always work), the diffuser will now sit in the wake and be more useless than the stock setup.
Thanks for doing the testing. Your C_d is lower than the manufacturer claim most likely because you essentially have a sealed front grill (radiator causes drag), smooth bottom, and non rotating wheels.
There's no need to tuft test the car as this is essentially the usual fastback. Lesson number 1 about streamlining is it's all about the rear, not the nose. Pointy nose is (slightly) worse than blunt nose at subsonic speed, just look at a Boeing 747.
The "problems" with the rear end are as you can see the 2 giant blue vortices (this is because while the rear window is sloping downward at a nice gentle rate, the car's body isn't getting narrower laterally, so the air that gets pushed to the side of the car is still travelling fast while the air going over the top of the car is slowing down), and the green zone over the trunk (separated flow, read the aero streamlining template thread on ecomodder for more info).
The factory spoiler helps with these slightly by essentially raising the effective height of the trunk lid and bringing it closer to where it "should" be for that length of car. Lowering the car has the effect of blocking off more of the tire area "visible" to the flow, and it also affects the "fineness ratio" (in a positive way, as in reducing drag) which I understand to be a sort of height vs. length thing, I don't really understand it but I think the effect lowering has on this is because of the ground.
Old 01-21-2013, 08:08 AM   #51
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Agreed. We have an opportunity to keep this forum untainted and really make something special happen.
EarlQ, the world is a better place because of your work. If you'd be willing to distribute your solid model, I (and others) would be glad to improve it and run a heap of simulations. I'm a MechE that primarily works with Pro/E, and so-so with SolidWorks and Inventor. Minimal CFD, but some magnetic and stress FEA work. If it's validation, we can do that... but I imagine the primary benefit will be identifying "hot spots" and testing solutions for both Eco and Track purposes. Alot of smart folks on here with similar interests.
Serial, you mentioned that the classic fastback shape and its implications. Which are your expectations for the FR-S? Boxy sedans will benefit from vortex generators + well placed spoiler (use turbulence to minimize the volume of "dead air" behind the car). Porsche-style cars are pretty eco-friendly out of the box, and tend to benefit from grille blocking and diffuser work. Once the car is "eco" it becomes a great platform for downforce, such as in the Hennessy Venom GT:
Shankenstein is offline   Reply With Quote
Old 01-21-2013, 11:42 AM   #52
Dimman
Kuruma Otaku
Dimman's Avatar
This has been demonstrated quite dramatically a few times on LeMans' Mulsanne straight. At least Porsche and Mercedes (don't know if others) got their closed roof prototypes airborne there when the speed and bumpy surface pitched their noses up just a tiny bit too much. The Porsche does an actual flip. Mercedes a bit more.
[ame="www.youtube.com/watch?v=rQbgSe9S54I"]Mercedes CLR-GTR Lemans Flip - YouTube[/ame]
So even the high downforce cars are pretty much wings if you take them away from the ground.
Because titanium.
Old 01-21-2013, 07:36 PM   #53
dasklein
Drives: rex
This is a great thread! I'm excited to follow it!
What are you guys using for your CFD sim? I'm definitely interested in seeing the results.
One thing to note about CFD: its not actual "real life" data. Its one of the most ground breaking additions to the design and testing process, but its still a simulation. It's a big misconception that its 100% (or even 99+%) accurate to real conditions. Its all about the software, the 3D model, and how the programmer/aerodynamicist sets everything up.
In the end you still have to get it on the track or in a "real" wind tunnel...
dasklein is offline   Reply With Quote
Old 01-22-2013, 01:24 AM   #54
robispec
Drives: Black frs project
some real time testing on venting the hood
don't have that fancy F1 paint but at streets of willow there were PLENTY of people kicking up dust when they went Agricultural
YES any air going out the top is air not going out the bottom so less lift up front...
robispec is offline   Reply With Quote
Old 01-22-2013, 05:24 AM   #55
serialk11r
I think the reason those cars went airborne so easily was because they have some kind of stupid mandate on the underbody, something like it has to be flat all the way to the diffuser? I seem to recall these LeMans cars having some giant flat splitter, and they're obviously very low to the ground, so a small angle of attack, and you can run into a lot of trouble.
I would guess that F1 cars don't go airborne since 1. giant wing in front 2. their high noses have a smooth curve channeling air to the underbody.
Old 01-22-2013, 06:19 AM   #56
johnnie
Drives: GT86
Great work guys!! Unfortunately I don't have your skills or knowledge, so I'm just watching and trying to learn something.
Keep it up.
johnnie is offline   Reply With Quote
Front aerodynamics... need help! TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 16 10-23-2012 09:27 PM
Interesting aerodynamics differences between USDM, JDM, etc. yargk Scion FR-S / Toyota 86 GT86 General Forum 25 09-20-2012 04:00 PM
Coefficient Drag & Aftermarket Aerodynamics FT-86GOD Scion FR-S / Toyota 86 GT86 General Forum 1 06-28-2012 01:20 AM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-26-2012 09:19 PM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-21-2012 12:47 PM
