#2087 | |
What if what breaks, the kit parts, or the engine? |
#2088 |
Drives: Perrin/VORTECH Supercharger TestBRZ
Assuming innovate and vortech are both offering buyers 12month written unlimited miles on things examples bearing failure, hopefully major parts like if the kit includes a sensor or similar part, if you offered 12 month warranty also it may help a buyer on the fence, that's all I mean.
#2089 |
Drives: AE86, 2x GT86, TE27
Paul,
Has any testing been done on pushing the system beyond the OEM fuel system capacities? Seeing as your system seems to be theortically capable of 360hp at the crank, then running ~14 psi should result in a safe 300whp? Its the OEM fuel system holding it back..? I guess what I am getting at, is if I can everything the kit is showing on the dyno now, but with 50 more hp, for the additional cost of injectors + pump + clutch, I see this as a cheap cost for an extra 50hp, which imo would be a great street setup. Another questions, the ECUTEK system, I take it this is a piggy system? Is this able to be told that there are larger injectors - eg full tuneabiliy on fuel mapping? Can it also adjust timing? The ECUTEK is not common in NZ at all. Sooner just put a link in it, if the ECUTEK is holding it back. I have no issue being the first to take your system to this level if it hasn't been done yet, but interested in knowing if this has been considered/tested. Thanks Last edited by diss7; 01-18-2013 at 04:46 PM. |
#2090 | |||
We'll test larger injectors/fuel pump in the near future, but we are concentrating on the stage 1 turbo kit launch for the present, and after that Stage 2. In regards to a Stage 3 build, you'd be factoring in the cost of rubber, braking, and other upgrades so that the rest of the car keeps up with the engine! Quote:
Ecutek as a reflash solution, though, can indeed be edited for larger injectors, ignition timing, and more. Plus it maintains the daily driveability of the car. Edit: Final Note The turbocharger is not *that* small. We are running it at 5-7psi, but it will push up to 18psi if run all out. Last edited by AVOturboworld; 01-18-2013 at 05:14 PM. |
#2091 |
We have the same fuel here. 280whp is great, and in my experience 90% duty cycle on injectors is not anything to worry about. Sure, its not ideal, but I personally wouldn't upgrade a system for that reason.
Not looking to do the car in 'stages', would rather just spend the money upfront. Works out cheaper in the long run, have learnt that lesson many times over. Agree that rubber/brakes/suspension should be upgraded to match. Will be doing this at the same time as well, parts already arriving and I don't have the car yet. Your next point about the front pump, I assume is a typo and should say front pipe. Bugger, I was hoping to keep stock exhaust for a more stealth look, but looks like this isn't an option. Thanks for the advise. No issue with a reflash system, as keeping driveability is number one focus. As long as we can fine tune here I see no issue. I will go and talk to my tuner on Monday whether he has come across the system before, and what his thoughts are. Cheers. |
#2092 |
Oops, changed the pump to pipe. Not enough coffee in my system, or not enough beer...
#2093 | |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
Same here
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
#2094 | |
Slide Ways
Drives: 2013 SWP BRZ, 85 VW Golf
#2095 | |
For people that buy a kit directly through us, we can adjust the base map. But the further you get away from the stage 1 hardware, the more possibility you'll need tweaking to the map to keep up with those changes. |
#2096 |
[ame="http://www.youtube.com/watch?v=XPOwiw0s4xw"]AVO Turboworld - Turbocharged FR-S Drift Sessions Jan 2013 - YouTube[/ame]
This was on the 5psi base tune and the 245/45 Direzza's. |
#2097 |
Can't understand the forum logic about being okay running base maps. Every car/climate/local fuel is slightly different.
IMO if you can't afford a tune after putting a turbo kit on, you can't afford the turbo kit. |
#2098 |
#2099 |
Don't look at me, show's up fine on my computer! And it is Youtube, not Facebook this time.
#2100 |
Weird. I can't even click it in your post, but can in my quoted post.
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
