| View Poll Results: Do you plan to use an oil cooler? | |||
| Yes, prepackaged kit |
77 | 71.96% |
| Yes, fab my own |
18 | 16.82% |
| No |
12 | 11.21% |
| Voters: 107. You may not vote on this poll | |||
#57 |
Site Moderator
Drives: Stuff
Yeah without preventing air from bypassing the radiator (and other coolers) it'll be tough to make sure air flow isn't described. We won't find an oil cooler to fill the space completely so that's unavoidable too
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#58 | |
Drives: really slow...
Only testing will tell! Again, please post your results. I still contest that a radiator designed for low air flow (i.e. better fin design) and made out of copper (copper has better heat transfer coefficient than aluminum at the expense of weight) is the right solution for FI applications where FMIC are used. |
#59 |
Drives: Nevermorange FRS
I'll drink to that!
PRO86 | WTCC | STL
#60 |
I think the biggest problem with the stock radiator is that its rather thin compared to what i am used to. Here's a comparison to a koyo core for our car:
![]() Thats not a lot of surface area, so i could see why this car has heat issues especially if the water pump is pushing water through that skinny core faster than it can cool it. With the added surface area of an aftermarket core i think the flow will also slow a bit to allow the water to cool more before leaving the radiator. I could be really wrong but, I'm pretty sure the added volume + cooling area would effectively cool the engine better. |
#61 | |
Drives: '06 AM V8V Coupe
The speed of the water actually is the opposite; The faster the water moves through, the more passes it makes through the radiator in the same amount of time, the smaller the temperature variation, and the greater turbulence/surface velocity helps improve thermal conductivity by a little. However in a car engine, the water is flowing pretty quickly so this isn't something you have to worry much about. |
#62 | |
While copper sounds attractive at first, you have to remember that "copper" usually means brass tubes, joined with something like solder, which don't have great thermal conductivity. On top of that, brass, copper, and tin are all over 3 times the density of aluminum, and you might need to start paying attention to corrosion in the aluminum block though the antifreeze usually makes it a non-issue. An aluminum radiator of the same mass can be bigger and ultimately transfer more heat. |
#63 | |
A copper solution still has merit, though I do echo some of your concerns. Let's wait and see... I know the copper vs. alum heat exchanger has been a debate for decades and i've been surprised by what i've seen especially in the Server CPU world. |
#64 | |
#65 | |
Site Moderator
Drives: Stuff
I would definitely run one with a seperate oil-to-air cooler, unless it's an endurance race car then it's fine without one
-Dave
#66 | |
http://www.garagefrs.com/koyo-radiator-install/ |
#67 | |
#68 |
Drives: 370z,Evo X
If you track or mod the car, there is NO negative to an oil cooler. There are only positives. It helps your engine in general to stay cooler and have a better life expectancy when it's being thrashed on. And if your boosted, it aam cools engine and possibly turbo oil etc. for the most part, I would say fab your on. Don't be scared, it's extremely simple. And it will save a lot f money. Mostly you an also have higher quality parts and lines and cooler core like setrab for instance. Don't skimp on an extremely effective and reliability parts of the car/build. Pm me if anyone needs info of what they need or where to get pars. I've built plenty of them for all my cars, most notably the 370z which everyone knows ran very hot.
#69 | |
You can see the slip-fit fittings i'm talking about here. It's the black hose butted up against the plastic collar on the AN10 elbow fitting.
#70 |
Drives: Whiteout FR-S
My distributor has pricing for the Perrin kits now, much more reasonable than the hks or Greddy. Pm me if interested I think it's pretty reasonable I plan to get one if I ever get boosted.
| Does one change the oil in an oil cooler? | Captain Snooze | Engine, Exhaust, Transmission | 29 | 05-09-2016 05:42 PM |
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 05:42 PM |
| Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 12:55 AM |
