Old 01-16-2013, 11:18 PM   #15
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
1. Get rid of the useless analog speedometer and put in actual oil temp and oil pressure gauges in it's place. (will be integrating a dual oil pressure/temp gauge into steering column cover...)
2. Get rid of that torque dip...power should be linearly responsive no matter the load and rpm range.
3. The seats do not go low enough...need seats to go 2" lower (have plans to remedy this)
4. Oil cooler needs to be installed (will be doing my own oil cooling system.)
5. Needs more front camber adjustment (will be fixing that soon...)
6. Better brake system truly designed for heavy track use (have plans for that but $$$)
7. Get rid of the fake 'sound tube' intake system. (already done)
8. Put a better exhaust system that really belongs on the car (already done)
9. Put real functional fender garnish/vent pieces on the front fenders...(thinking of the TRD ones...but $$$ for what they are.)
10. Some kind of spoiler is needed on the rear...have yet to see one I really like and would not mind sticking on the car though - I want it to be like a part of the trunk, not a stuck on trim piece...
11. Engine RPMs could be more responsive to throttle input...thinking lightweight flywheel should have been standard (I very much plan on upgrading to one, but not a priority at this time)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-16-2013, 11:27 PM   #16
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
if money was not an issue i would replace every single part of my brz with ferrari parts and make it a ferrari. of course i'd hire a team of ferrari specialists since money is not an issue. ;-)
chenshuo is offline   Reply With Quote
The Following 2 Users Say Thank You to chenshuo For This Useful Post:
boonFRS (01-16-2013), Demandred7 (01-17-2013)
Old 01-16-2013, 11:37 PM   #17
bdohazelnuts
Drives: Asphalt Grey FR-S (soon)
Originally Posted by circuithero View Post
As I see it, the car is nearly perfect. In honda speak, this car is a GSR and I want it to be an ITR. Or conversely for porshe this would be the GT3 and I want the GT3 RS. This car will serve as a permanent DD and a weekend warrior. I want to visit a couple of the new tracks that have popped up on the west coast, and hit PIR this summer a couple times as well.
So:
Reliable, simple boltons for 30-50hp, NA. No boost. Not in a hurry, Ill let the parts develop and copy someones formula.
Drop 100-150lb without compromising the comfort or interior of the car via:
-17x9 RPF1's w/225 RS3's
-10lb battery
-Loose the junk in the trunk
-FIA Bucket for drive
Aside from that, hook up my SoloDL and chase porsches . Rinse and repeat!
I think that I am looking to do this actually more short term... All but the seat probably. I am definitely getting a works drop in, and one of the silicon intake pipes, and considering one of the nameless exhausts with one of the e85 or flexfuel reflashes.
Having a hard time deciding whether to do so now, or just save and wait until I can drop a turbo kit into it.
bdohazelnuts is offline   Reply With Quote
Old 01-16-2013, 11:42 PM   #18
koyv90
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
400whp turbo kit, a nice oem style carbon fiber hood, built engine with lower compression maybe 10: something, and the Aero package from Germany with the more expensive hid head lights, oh and 17x9 gramlights 57, with kw coilovers.
koyv90 is offline   Reply With Quote
Old 01-16-2013, 11:47 PM   #19
boonFRS
Drives: 2013 Scion FRS whiteout
9000hp!
Nah I kid. I would like a bit more power and less weight. 275whp and around 2200lbs.
boonFRS is offline   Reply With Quote
Old 01-16-2013, 11:48 PM   #20
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'd do this:
Oh wait.. I already did.
Well, maybe I'd add an Innovate Supercharger.
But since we're working with someone else's money.....
I'd build a second BRZ, do a full tear down and rebuild into a hill-climb monster complete with widebody and 500hp turbo build with anti-lag tune.
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
6-Shift (01-17-2013), Anthonytpt (01-17-2013), ravenblackfrs (01-16-2013)
Old 01-16-2013, 11:53 PM   #21
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
2GRFSE thanks. stock everything else. oh and a decent clutch.
Surok is offline   Reply With Quote
Old 01-16-2013, 11:55 PM   #22
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
The Subaru premium sport concept is almost perfect to me, add a litchfield supercharger and I'd be happy with that.
Otherwise I'd start with a wrb brz, add the Ings kit, SSR wheels in gold with polished lip, racecomp Tarmac II coilovers and sways. This one would be more extreme so Crawford spec c turbo kit and short block. Ap racing/Stillen front and rear brake kits too.
Old 01-17-2013, 12:39 AM   #23
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Grimmspeed brake reinforcement
GT86 climate control, headlights, foglights, and spoiler
Nameless header back exhaust
Wheels (Work, Volk, or TSW) with tires that are better in the wet (maybe Bridgestone Potenzas)
And last, but, certainly not least, some sort of supercharger (probably Vortech or TRD)
Demandred7 is offline   Reply With Quote
The Following User Says Thank You to Demandred7 For This Useful Post:
ravenblackfrs (01-17-2013)
Old 01-17-2013, 01:01 AM   #24
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
I wouldnt be opposed to TRD. But I think a third party or independent performance shops supercharger will do a little more than the TRD one. I like the vortech stuff perrin is doing. I'm going to save until my warranty is out to do the s/c. Are the potenzas good in water?? I know Michelin makes some pretty good ones for driving in water.
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 01-17-2013, 01:21 AM   #25
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Well then:
To design itself: make car hatchback. To MY car:
1. Replace every removeable body panel with carbon fiber
2. some sort of tall time attack spoiler
3. superlight racing wheels
4. Brembo big brake kit front and rear
5. coilovers that raise and lower from controller but handle like stock
6. some supercharger
7. UEL header and full custom exhaust from HKS
8. Headlights produced by Audi
9. full selectable underglow kit (why not?)
10. TRD leather seats
11. Full audio setup from JL audio, tuned by Bose engineers
Think that basically covers it.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
The Following User Says Thank You to 6-Shift For This Useful Post:
Old 01-17-2013, 01:22 AM   #26
akyp
Drives: 2012 86
Keeping it bone stock.
I guess I'm not very picky.
akyp is offline   Reply With Quote
The Following User Says Thank You to akyp For This Useful Post:
strat61caster (01-18-2013)
Old 01-17-2013, 01:39 AM   #27
Demandred7
Demandred7's Avatar
I don't have my heart set on the TRD one. I am liking what I read in the Vortech/Perrin thread and may actually go that way. If money was no object, I wouldn't care about warranty. Every Michelin tire that I have ever owned have been horrible in the rain while every Bridgestone Potenza that I have owned have been great in the rain (both with respect to traction and anti-hydroplaning). It is somewhat of a generalization based on my own experience (although I haven't driven every type from both brands).
Old 01-17-2013, 01:45 AM   #28
DBacon1052
DBacon1052's Avatar
Drives: Argento FR-S
I would tear it down to the steering wheel and build an Audi R8 around it(:
DBacon1052 is offline   Reply With Quote
Perfect Run? yomchi1989 AUSTRALIA 4 01-13-2013 10:38 PM
HKS Spec L - Perfect! Vicious LED Engine, Exhaust, Transmission 24 11-16-2012 09:44 PM
perfect car! marine321 Scion FR-S / Toyota 86 GT86 General Forum 65 10-19-2012 02:52 AM
perfect parking bay Vladror Scion FR-S / Toyota 86 GT86 General Forum 17 10-05-2012 08:56 AM
Perfect driveway Jason952 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 09-17-2012 09:39 AM
