Old 12-11-2012, 09:00 AM   #57
wparsons
wparsons's Avatar
Originally Posted by WiKKiD View Post
I can pay a friend of mine to break there encryption on the dongle and USB stick it will just be a little expensive. There's always a back door or exploit left open by the programmer who designed the software
If your friend was charging a typical consultant/contractor developer rate to break the encryption you would be FAR better off just buying a legit cable... A cheap consultant will bill at $100/hour, and I bet it takes him a lot longer than 3 hours to do it.
flickr
Old 12-11-2012, 09:12 AM   #58
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Drives: 2001 Audi TT Quattro "BT 300+Whp"
That was my point. Just buy the cable
Sent from my iPad using Tapatalk HD
WiKKiD is offline   Reply With Quote
Old 12-11-2012, 09:01 PM   #59
xwd
Hardware is the same it's the software that talks to the cable that's different.
I have a ecutek cable and a rosstech vcds cable and eurodyne maestro dongle and opened them up to compare and they are almost identical
I can pay a friend of mine to break there encryption on the dongle and USB stick it will just be a little expensive. There's always a back door or exploit left open by the programmer who designed the software.
There is the cable and the hw dongle which are two different things. You could do something to make the software recognize a non-Ecutek cable perhaps fairly easily.
Generally with the USB dongle people create emulators to emulate the key, these days it's fairly difficult to crack software which uses a hardware dongle. People create the emulator and then grab an image of a working hardware dongle. There are functions all over the software which check for the dongle so it's not like it checks on startup and then that's it. Also if you need to update the software you may be screwed as well and if the software itself phones home so to speak to register a dongle with a specific hardware ID it also makes things difficult.
Easier to just buy the cable.
Old 01-16-2013, 12:41 AM   #60
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Shit Luck View Post
have you ever seen a Ross tech cable.
Its the exact same cable. I would bet my car they are assembled in the same factory by the same child in china.
Originally Posted by Uwe@Ross-Tech View Post
You can deliver your car and title here:
http://www.ross-tech.com/contact.html
-Uwe-
@Shit Luck, did you ever deliver your car??
The Following User Says Thank You to Sportsguy83 For This Useful Post:
xjohnx (01-16-2013)
Old 01-16-2013, 06:38 AM   #61
ralpho
ralpho's Avatar
Drives: scion frs
reflash
Anyone in socal reflashing ecu's?
ralpho is offline   Reply With Quote
Old 01-16-2013, 10:22 PM   #62
obriennathaniel
obriennathaniel's Avatar
Drives: Satin White Pearl Limited BRZ
Thanks again for not actually answering the question.
please go play in traffic
obriennathaniel is offline   Reply With Quote
Old 01-17-2013, 12:03 AM   #63
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
-Uwe-
Will you be porting your software to be compatible with the twins?
crazyfrenchbiker is offline   Reply With Quote
Ecutek cable markmatley Hawaii 11 07-22-2013 07:36 PM
Anyone have an EcuTek cable? ProTekk NY / NJ / CT / PA 9 12-05-2012 10:28 PM
Ecutek Cable jpit Northwest 0 09-04-2012 02:14 AM
Ecutek Cable brz007 Northwest 0 08-25-2012 07:11 PM
Cable in glovebox KamalT AUSTRALIA 8 08-23-2012 08:52 AM
