Old 01-16-2013, 05:28 PM   #57
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Good read
TouchMyHonda is offline   Reply With Quote
Old 01-16-2013, 05:46 PM   #58
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
I'm installing my own DIY kit tonight or tomorrow. It's definitely much cheaper than buying a complete kit like the Perrin, Blitz or Greddy. I used some stuff I had laying around already. You can get a nice Setrab oil cooler core for around $150-$200. The Mocal sandwich plate/spacer kit was $169, and the hoses would run you about $100.
Parts list:
1.) Brand new Trust (Greddy) 13 row core (from another car project/build I am doing)
2.) Earl's Stainless braided hoses with -10 AN fittings
3.) Mocal thermostat controlled sandwich adapter with spacer kit (Part# SP1T-FA20, made specifically for ours cars)
4.) Machined my own oil cooler mounting blocks out of aluminum
I'll do a little install DIY thread on here when I get everything done. I need to get an oil temp gauge sensor for my greddy gauge I already have.
Mark Slide Squad is offline   Reply With Quote
The Following User Says Thank You to Mark Slide Squad For This Useful Post:
CSG Mike (01-16-2013)
Old 01-16-2013, 06:41 PM   #59
Hanakuso
Originally Posted by balance View Post
Cooler oil will result in lower water temp. Even if an oil cooler is located in front of radiator and there is enough space between the oil cooler and radiator, the air will be able to get around the cooler and hit the radiator.
Complete kits offered by tuning companies are nice in that they come with everything including installation instructions, but you can achieve the same by assembling your own kit and save money.
Thanks. I figured the heat coming off the oil cooler would be small for the radiator.
I like the complete kits for less hassle and less chance of a leak or something worse. Hopefully I can get the HKS oil cooler for cheap and get it soon.
Hanakuso is offline   Reply With Quote
Old 01-16-2013, 08:31 PM   #60
celica73
I've got to say, all yall are high rollers. When I do this, it will be with a Long/Trucool cooler. They don't look as nice, but are way cheaper and work just fine.
A NASCAR takeoff is also a big savings, but I worry about a used oil cooler.
Old 01-16-2013, 09:44 PM   #61
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tru-cool's are fine IMO. I like the 2" core and the mounting style of the Setrab/Mocal more, those items and previous experience are the reasons I have a Mocal cooler.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-17-2013, 12:48 AM   #62
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Parts have been ordered
Assuming it fits, my setup will consist of:
Mocal 19 row 235 cooler (already have this)
Aeroquip SS hose (-10AN) (already have this)
Mocal sandwich plate with spacer
Cheap sandwich plate for oil temp and oil pressure gauges (already have this)
Defi Advance CR gauges, going to have to find a place to mount the control box (already have this)
Assorted Aeroquip -10AN reusable fittings (already have some of these)
Blood from cutting SS hoses (already have, just not relocated to the hoses yet...)
Zip ties
Maybe some AL blocks to make the mounting more stable, going to check spacing first.
Looking forward to your full DIY write-up. Thanks for volunteering! Take lots of pics!
PRO86 | WTCC | STL
Old 01-17-2013, 11:03 AM   #63
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Some parts sitting in a box
Cooler itself (19 row Mocal 235)
Once I get some other parts in I'll start test fitting this larger cooler (so far everyone else is running a 13 row I believe) and start measure hose lengths, etc.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Anthonytpt (01-18-2013)
Old 01-17-2013, 12:13 PM   #64
Mark Slide Squad
Ok, put my DIY oil cooler kit in last night. Took me about 3 hours from start to finish, and was taking my sweet time I'm going to do a write up within the next several days hopefully, but here's a sneak preview. The pics aren't the best, and the 90º AN fitting going into the sandwich plate isn't ideal, but it's all I had laying around. Planning on revising that, but it works for now, just not aesthetically pleasing I will be taking the car to the track on Saturday though, so that shall be the real world test!
The Following 2 Users Say Thank You to Mark Slide Squad For This Useful Post:
Anthonytpt (01-18-2013), TAP Auto Parts (01-17-2013)
Old 01-17-2013, 12:46 PM   #65
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I like it That's basically what my setup will look like, except a different cooler obviously.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Mark Slide Squad (01-17-2013)
Old 01-17-2013, 01:03 PM   #66
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Ugh Racer Parts Wholesale is waiting for the sandwich plates to come in stock, they are saying about 1.5 weeks until it will ship so I probably won't have a working setup until early Feb unless I can find a sandwich plate elsewhere. I'll still be test fitting my larger cooler this weekend though just to make sure that part will fit at least
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-17-2013, 01:05 PM   #67
Mark Slide Squad
I ordered mine directly from Mocal in Florida a couple days ago and they had them in stock. Might wanna try calling Mocal directly. Hopefully they got one for ya!
Dave-ROR (01-17-2013)
Old 01-17-2013, 01:08 PM   #68
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Damn they are 45 minutes from me and I never even knew that lol I'll call them and then see if RPW will cancel that part of the order
Thanks!!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-17-2013, 01:43 PM   #69
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Mocal has them. I called RPW back to remove the part from the order but they offered to drop ship it from mocal instead which means sales tax (same as me buying it directly from mocal so I'm fine with that). So now, I should get my parts quicker
Thanks again Mark! BTW I am working with someone on the aluminum standoffs/feet but if that falls through (should know next week hopefully) would you be opposed to making another set?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-17-2013, 01:58 PM   #70
Mark Slide Squad
No prob, Dave! If I get enough interested people, I would definitely consider making the aluminum standoffs. All I would need to know is the spacing from hole-to-hole center on your core.
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
