Old 01-14-2013, 08:58 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Sway Bar Mouting Brackets/Bolts Integrity
This is just a simple question directed to those that have beefier sways. How are the brackets/bolts/bolt holes/chasis holding up? In my experience with my previous two car's and a few of my friends cars, this is a weak point on production vehicles. I've seen everything from bushings disintegrating, threads stripping, brackets cracking, endlinks snapping etc.
How are the beefier sways holding up on this platform?
Old 01-15-2013, 08:35 PM   #2
xwd
The front hasn't shown to be an issue, either the mounts or endlinks. The rear I know on the 08+ WRX/STi Whiteline made a swaybar reinforcement bracket, but it looks pretty stout to me and I can't see someone putting a huge rear swaybar on this car. Both front and rear use decent sized bolts, in the front you have a nut and a bolt, you need to make sure you get the bolt lined up or else you could cross thread it.
One nice thing is if you did crossthread it, the swaybar brackets are bolted into the chassis by themselves, so it wouldn't be difficult to replace. With the other Subaru models the swaybar brackets are welded to the main front crossmember...
Old 01-16-2013, 03:33 PM   #3
sw20kosh
Yeah I am used to the brackets being welded on. This puts my mind at ease a little bit.
Old 01-16-2013, 06:36 PM   #4
mla163
Overthinking it
Drives: BRZ in CS
Keep in mind the sways are much smaller than on other cars. The forces are much less than say, a Mustang or BMW.
I wouldn't be too concerned.
mla163 is offline   Reply With Quote
FS: Bride Euro II w/brackets for BRZ/FRS Alliedforces86 Interior Parts (Incl. Lighting) 10 01-21-2013 09:02 AM
Side Mounted Fixed back seat brackets? Vonsamhain Cosmetic Modification (Interior/Exterior/Lighting) 0 11-21-2012 11:01 PM
BRZ License Plate Brackets Ogleberry AUSTRALIA 8 10-31-2012 10:08 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 08:14 PM
Recaro brackets Being Made kanundrum Electronics | Audio | NAV | Infotainment 12 04-14-2012 04:38 PM
