| AUSTRALIA Australia and New Zealand |
#15 | |
Drives: Skoda Yeti DSG diesel 4x4
I wish the start button was somewhere else. I tend to press one of the others above it and wonder why it isn't starting. |
#16 | |
Drives: 86 GTS Manual - Tornado Grey
The only car i haven't really noticed a difference with aircon on is on my wifes aurion. 3.5L v6 powwwaaaa |
#17 |
Potato Farmer
Drives: #SLOBRZ
The aircon will shut off under WOT..
Something something butter..
www.vic86brzclub.com |
#18 |
Drives: 86 GTS
I don't know why people are adjusting the fan.. these cars have climate control, press 'auto' set your temp & leave it. Need it warmer? Adjust temp. Need it colder? adjust temp.
The reason fan speeds go up/down is to adjust to your temperature setting, so if you find it's doing annoying things, you probably have the wrong temp setting on. I leave mine sitting at 21.5 for 90% of the time.. I can't understand how this is so difficult? |
#19 | |
I also notice it cuts out way lower than WOT, which is fine by me. I'm not bothered about it getting slightly warmer when i'm moving on a bit and it soon brings it back down. Best A/C i've ever had. |
#20 | |
Potato Farmer
Drives: #SLOBRZ
Cause we wanna be difficult Dale! I have mine on LO, and most of the time the fan on the lowest setting, then crank it up as the heat goes up!
#21 | |
I can't even listen to music in this car and turn it off almost straight away to listen to the noise it makes instead. |
#22 |
Pegasus White
Drives: 86
lol looks like people missed my point.
If there is a simple off button i was expecting that the ac button would be that simple on button... none of this press the auto and turn the dial down on the speed.... I just want the fucken air con on what i had it set to previously.
Driving: Pegasus White Manual GTS 86.
#23 | |
I leave mine on auto and it starts up when I get in without touching anything but the start button for the engine. |
| when you hit the lock button on your key... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-28-2012 12:55 AM |
| FS [SYD]: TRD Start Button | eleu2166 | Australia Classifieds | 3 | 11-04-2012 06:31 AM |
| Thanks button? | TuxedoCartman | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 07-25-2012 03:25 PM |
| Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) — General Topics | 68 | 02-14-2012 07:16 AM |
| ABS off button? | NESW20 | Engine, Exhaust, Transmission | 21 | 04-20-2010 10:47 PM |
