Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 01-08-2013, 05:14 PM   #1
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
GTS Model - Air Con Button
Hey Guys,
So in the GTS model the far left button in picture
Does it actually turn your AC on? I have to play with the middle vent dial to turn mine on.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-08-2013, 05:27 PM   #2
Nardi330
Nardi330's Avatar
Drives: 86
No. That's to switch between the air con and the fan. I usually press the auto button to turn the system on.
Nardi330 is offline   Reply With Quote
The Following User Says Thank You to Nardi330 For This Useful Post:
DriftEightSix (01-08-2013)
Old 01-08-2013, 05:36 PM   #3
DriftEightSix
Pegasus White
Drives: 86
Lame... auto just goes full ballin... if you use the the fan switch it just uses the last settings
Old 01-08-2013, 06:05 PM   #4
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
use the auto button, then play with the fan speed dial.
Surok is offline   Reply With Quote
Old 01-08-2013, 07:24 PM   #5
Nardi330
Nardi330's Avatar
Drives: 86
that's what i do. let it adjust to the set temp first then i'll fine tune with fan speed dial.
Old 01-08-2013, 08:10 PM   #6
sierra
Drives: Skoda Yeti DSG diesel 4x4
I find it irritating on auto that it changes the air from top and bottom vents to just the top vents. Otherwise it works very well and has virtually no effect on performance and cuts out when you give it some stick, as it should. Gotta get the priorities right.
sierra is offline   Reply With Quote
Old 01-09-2013, 08:21 AM   #7
Devie
Drives: Tornado Grey 86 GTS
wat? afaik that button labeled A/C turns the A/C on...? Am I missing something? I've only done 700kms and its been hot as hell recently probably hasn't needed to turn itself off.
Devie is offline   Reply With Quote
Old 01-09-2013, 08:34 AM   #8
DriftEightSix
Pegasus White
Drives: 86
Well essentially it does... if you press it to turn just fans on instead of AC running.
Press the off button and think to yourself... hey now that i've pressed the off button where is the on button... i know i'll press the a/c button... cause you know that should turn the damn thing on....
OH LOOK NO IT DOESN'T!!!!!
The Following User Says Thank You to DriftEightSix For This Useful Post:
Surok (01-14-2013)
Old 01-14-2013, 11:11 AM   #9
crouchy35
crouchy35's Avatar
Drives: 2013 Mt Fuji Red 86 GTS (MT)
After reading this, i might just change my order to a GT! O_O
crouchy35 is offline   Reply With Quote
Old 01-14-2013, 03:16 PM   #10
lazyluka
Drives: GT86
If you press the off button, playing with the fan speed turns it on, doesn't it?
The AC button is just used to turn AC on/off but doesn't do anything if you turned the entire thing off.
lazyluka is offline   Reply With Quote
Old 01-14-2013, 07:22 PM   #11
st162celica
Drives: 86 GTS Manual - Tornado Grey
Why ? ?
LOL at this thread...
Its climate control, not rocket science.
While my wife has her seat warmer on and heater on on her side, I have cold air on my side... works quite well.
st162celica is offline   Reply With Quote
The Following 2 Users Say Thank You to st162celica For This Useful Post:
fuddbutter (01-14-2013), Roadliner (01-15-2013)
Old 01-14-2013, 07:40 PM   #12
gmookher
glad you said it not me,
I'd get a ban threat pm in my case, lol
... mine works fine, your first time in modern a car possibly?
dial down the temp to what it is inside the car, and it wont go full baller on you
wheres that hall of fame section on this forum?
gmookher is offline   Reply With Quote
Old 01-14-2013, 07:43 PM   #13
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Aircon on, Seat warmer on, window down.. its the way to be
and when i turn mine on, i usually just turn the fan downwards .
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following 2 Users Say Thank You to fuddbutter For This Useful Post:
nix (01-15-2013), st162celica (01-14-2013)
Old 01-14-2013, 08:19 PM   #14
IMOA
Drives: 86 GTS
I must be missing something but I set the temp, leave aircon on and have the fan set to auto and don't need to touch it again. If I'm desperately annoyed by the fan blowing hard I turn the fan dial down to decrease the speed. I don't understand what is so complicated.
IMOA is offline   Reply With Quote
when you hit the lock button on your key... pr086 Scion FR-S / Toyota 86 GT86 General Forum 15 11-28-2012 01:55 AM
FS [SYD]: TRD Start Button eleu2166 Australia Classifieds 3 11-04-2012 07:31 AM
Thanks button? TuxedoCartman Off-Topic Lounge [WARNING: NO POLITICS] 17 07-25-2012 04:25 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 08:16 AM
ABS off button? NESW20 Engine, Exhaust, Transmission 21 04-20-2010 11:47 PM
