#827 |
Definitely something to consider. I haven't dived deep enough into the knowledge of either. That's something I'll have to research extensively especially since the FR-S is my DD. Last thing I want to introduce is problems due to a turbo or SC, but I definitely wouldn't run a dangerous amount of boost.
| The Following User Says Thank You to FR-S Matt For This Useful Post: | Sportsguy83 (01-15-2013) |
#828 | |
Drives: Skoda Yeti DSG diesel 4x4
I can barely hear mine cruising at 100 - 120kph in 6th but on cruise at 80kph around 2000rpm it's very noticeable as it throttles up for inclines. I threw a bed quilt in the boot and that helped. I was thinking of unbolting the heatshield above it and refitting it with some fibreglass roof insulation sandwiched above it? It's not unpleasant but needs to be a bit quieter in that range. How is yours in that situation? |
#829 | |
I Love custom Turbo kits
Drives: Limited BRZ
#830 |
#831 |
Kuruma Otaku
Because titanium. |
#832 |
Site Moderator
Drives: Stuff
Installed my offset axleback today. With all of the people who said they were loud I was shocked.. it's quieter than I expected by quite a margin.. I see how it is over a few more days of use.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Sportsguy83 (01-15-2013) |
#833 |
I thought the Nameless Downpipe connected to the header? Unless there's an alternate way to do it with an overpipe as well? Otherwise, I'm just thinking of the factory fit pipe.
#834 |
Drives: Limited BRZ
Because there was some people (ahem... including me) who replacing the frontpipe left the donut gasjet on the OEM pipe and it sounded super loud at certain RPM's. But just the Axleback should not sound very loud. There are certain specific RPM's where there is more sound, but it really shouldn't feel too loud.
#835 | |
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | FR-S Matt (01-16-2013) |
#836 | |
The only sound before was from the induction and that combined with the sound from out the back is magical. It's just a bit disproportionate at 2000rpm in 6th with a bit of throttle wound on, as the cruise will do up a hill. Not much from the induction but a bit from the exhaust. I would imagine the offset is perfect if it balances that out. I'm hoping this overpipe from the FA20 club that they say fits both L and RHD does fit because it would be a pain to drop it down and trap it or have it touching and have to remove it again. It might be that the Nameless one fits? I bet no one has tried it? |
#837 |
Drives: Limited BRZ
I think it probably won't, because they rerouted the overpipe to take space where RHD cars have the steering column.
#838 |
#839 |
Drives: Limited BRZ
Because the one size fits all only replaces the downpipe, leaving the stock overpipe. The downpipe does not interfere with the steering column. The High Flow Cat is located in the downpipe (Perrin calls the downpipe the Frontpipe).
#840 | |
http://www.fa20club.com/product.php?...cat=302&page=1 Here's what they said in the email when I questioned the fit. I notice the Perrin overpipe was made to fit both LHD and RHD manuals. Will your overpipe fit my RHD manual and is it OEM fittings at each end? im sure it will fit both LHD & RHD models. yes flanges are designed to fit all the oem connections. freight will be $60.00usd to AUS I mentioned that because Nameless said theirs is LHD specific because the steering column is close on the RHD. So I was surprised the Perrin fitted both. I have a Nameless cat back and down pipe with HF cat. It had better fit after all that. |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 10:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
