Old 01-15-2013, 06:24 PM   #813
OrbitalEllipses
Drives: Attitude
Originally Posted by GTB/ZR-1 View Post
Just got home...Weight is 21 lbs (I'm all abt weight #s)
Powerrrrrrrrr! Or just louder? Or terbo?
Old 01-15-2013, 06:27 PM   #814
sierra
Drives: Skoda Yeti DSG diesel 4x4
Primary tubing is 2.5", but 3" @ the merged section.
That's a lot more than the original at 16lbs.
It looks bigger diameter at the flange than the previous one and that was 2.5" at the primary with more and less than that where it meets the secondaries and they squash it to blend.
Does it have offset mufflers?
sierra is offline   Reply With Quote
Old 01-15-2013, 06:37 PM   #815
sierra
I got this snippit about a month ago from John at Nameless.
He didn't say it was top secret so I assume it's out there.[Hope so, it is now!]
"We are developing a 3" catback that sounds great in preparation for our forced induction build."
Old 01-15-2013, 06:38 PM   #816
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Offset is what I ordered.
Just bolt ons for now. Probably putting a hairdryer in it for the '14 season & jumping to Street Mod in SCCA classing.
GTB/ZR-1 is offline   Reply With Quote
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
sierra (01-15-2013)
Old 01-15-2013, 06:56 PM   #817
OrbitalEllipses
Drives: Attitude
Ah, they dropped this jewel quite some time ago.
Jason@Nameless (01-17-2013)
Old 01-15-2013, 07:11 PM   #818
sierra
Not keen on that set up.
Why not keep it single until the back so that's it's just one pipe and resonator, then the split and 2 mufflers?
Too much weight for no performance gain.
They've already said that any 2.5" centre pipe with resonator that they build will be heavier than the stock one. That version will be twice as heavy.
The only advantage is that it goes either side of the diff for clearance and is in balance but it's not worth the weight penalty.
Old 01-15-2013, 07:28 PM   #819
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Please, post a video as soon as you can. I may look into changing mine for this....
Edit: Just spoke to Ryan@Nameless. They will be offering a 3" Catback. The new axleback has WRX Mandrell bends and that helps keep their cost down.
Eventually I will replace my axleback with this.
Old 01-15-2013, 08:28 PM   #820
sierra
If you weren't far away I would buy your offset axleback and sell my axleback. The offset, I assume, reduces the volume in the car in the lower rpm range? That is my only criticism, the sound is better than I had hoped.
Old 01-15-2013, 08:38 PM   #821
Sportsguy83
Drives: Limited BRZ
Yeah, it reduces volume at lower RPM range you are correct. I won't sweat it too much, this is very long term planing (of course if you were close we could make a deal!)
The Following User Says Thank You to Sportsguy83 For This Useful Post:
sierra (01-15-2013)
Old 01-15-2013, 09:09 PM   #822
FR-S Matt
This 3" option may be a better long term investment if I plan on going FI a year or two down the road.
Old 01-15-2013, 09:18 PM   #823
sierra
Perhaps?
Hasn't 2.5" been estimated as suitable up to 350hp?
Also the larger volumes for flow are more critical close the turbo outlet, decreasing as the temperature falls and volume/pressure decreases towards the back of the system.
Old 01-15-2013, 09:24 PM   #824
Sportsguy83
Drives: Limited BRZ
Perhaps?
Yep, that is true. I stopped my thoughts for a moment because I was getting carried away. The truth is the setup I have right now is good enough for my HP goals. 3" won't be needed until north on 300 WHP.
Old 01-15-2013, 09:27 PM   #825
FR-S Matt
Yeah, the 2.5" system is probably more than sufficient for me. This 3" option is just throwing me off again. I think I like their revisions and new products too much.
My initial goal is a header + exhaust, already have my intake, then tuning the car. That alone would maybe get me close to 200 whp. If I were to go an FI path, I'd probably supercharge to eliminate that torque dip for good. I don't think that will push above 300 supercharged with that tune.
Old 01-15-2013, 09:32 PM   #826
Sportsguy83
Drives: Limited BRZ
Keep in mind all SC kits to date still have the dip. Some TC kits have eliminated it. Just a thought, there is no wrong either way.
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
