Old 01-15-2013, 08:21 PM   #29
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Mine showed up today!
17x9 in back
17x8 on the left and 17x9 on the right
kask2_6.0 is offline   Reply With Quote
Old 01-23-2013, 11:19 AM   #30
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Foobar View Post
I ended up buying the 2" Knockout Seals that Home Depot sells in its electrical section. There are a few DIY posts out there on various car forums talking about how people have used them as cheap centercaps. I did a test fit and it looks like it'll fit with the hubcentric ring in. I'll plasti-dip it black and take some pictures this weekend.
I decided that the knockout seals looked cheap, and I wasn't confident that they'd stay on the wheel since I had to bend the tabs in a bit to clear the hubcentric ring.
Instead, I got some 56mm black center caps which I attached to the hubcentric rings themselves. I still have to do a test fit to make sure it left enough clearance for the hub. It looks good and will match my black lug nuts nicely if so.
Old 01-23-2013, 12:18 PM   #31
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I haven't had a chance to look at the wheel that closely. Haven't test fitted the wheel to the car yet either. Does it look like a one piece hubcentric ring/center cap can be made? If so I can machine a few up if you guys are interested.
Old 01-23-2013, 12:20 PM   #32
Foobar
SLO NO MO
Foobar's Avatar
Yeah, if you take the hubcentric ring and put a flat face right on top of it, I bet you could fabricate something that sits flush with the face of the wheel.
Old 01-23-2013, 12:24 PM   #33
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I bought the expensive Weds center caps, but I would be willing to pay for a solution that somehow integrated them into a hubcentric ring.
Old 01-23-2013, 12:28 PM   #34
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
17x9 in back
Looking forward to seeing these on SWP.
spitz is offline   Reply With Quote
Old 01-23-2013, 12:44 PM   #35
Foobar
SLO NO MO
Foobar's Avatar
Same here, depending on cost of course - it doesn't look like it would be too hard to fabricate though, as the hubcentric rings that came with the wheel have sufficient space between its top and the wheel's face, so if something can plug that area up so that's it's flush, it would be a perfect spot to put any desired center cap decals that one would want. It would have to be ever so slightly smaller in diameter than the ring itself though, since there's a cutout in the wheel that the ring butts up against. If you take a look at the wheel, you'll see what I'm talking about. Nothing a lathe couldn't handle.
Old 01-23-2013, 05:37 PM   #36
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
They would definitely be a lot less then the weds caps. I'd just be looking to cover my costs. I will have something drawn up either tonight or tomorrow to see what you guys think.
Same here. Haven't seen this setup in black on a car yet. I'm just waiting on tires so I can test fit them. That and its like 4 degrees outside.
Old 01-23-2013, 05:51 PM   #37
OrbitalEllipses
Drives: Attitude
Still sour the center caps don't fit with the hub-centric ring (as reported by others). Interested in solutions...
Old 01-23-2013, 05:52 PM   #38
spitz
spitz's Avatar
Looking forward to it!
Old 01-24-2013, 08:14 AM   #39
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I was thinking something like this:
Will mount the wheel this weekend to double check the clearance between the hub nut and the face of the wheel.
Old 01-24-2013, 08:18 AM   #40
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
The taper on the bottom may not be worth putting on there. It is there to hold the hub centric ring from sliding in and out (or fix it to the hub). With this being a wheel specific ring it wouldn't really be necessary as it would be held from the front lip. Any thoughts on this?
The taper on the ID would still be there since it provides clearance for the radius on the hub.
Old 01-24-2013, 12:38 PM   #41
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
I don't think it can sit flush with the wheel. Rear hub extends beyond rim face I think.
hamlet is offline   Reply With Quote
Old 01-27-2013, 06:50 AM   #42
Foobar
SLO NO MO
Foobar's Avatar
If that's the case, his design could still work if he just makes it a tad taller to clear the rear hub. Maybe a few mil taller than the face. Could put a taper on the edge to make a nice transition even.
As for the OD taper on the base of the ring, wouldn't you want to keep it there since the back of the wheel pushes against it to help keep it in place?
Sent from my Galaxy Nexus using Tapatalk 2
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
WheelDude.com | Staggered & Square MXR - In stock and Ready to ship!! WheelDude.com Wheels and Tires 3 12-14-2012 03:59 PM
WheelDude.com | 17" & 18" DPT in stock and ready to ship - Staggered and Square WheelDude.com Wheels and Tires 15 11-09-2012 01:12 PM
Square or Staggered? dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 02-02-2012 10:40 PM
