Old 01-15-2013, 10:39 AM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by celica73 View Post
Any installed pictures (under the hood)? Did you have to use the little spacer to make room for the senders, or will they fit in spite of the oil cup?
The greddy unit comes with a spacer as well.
For what it's worth, I've seen sandwich plates read high.. as in 50-60 degress F higher than other locations. You can get massively different numbers in the pan and elsewhere in the engine, the sandwich filters tend to heat with the block which affects the temp sensor reading. The pan can be equally bad as it's cooled by the air somewhat.. What we really want to know is the temp of the oil in the galleries in the heads probably..
So if one is seeing 300F at the sandwich plate (which my race car does for 24 hours straight in endurance races) the real temp is going to be lower, in the race car it's more likely around 270F which I don't worry too much about - by too much I mean I don't worry at all. I'd prefer a little lower but any good oil can take that for awhile before shearing/etc becomes a problem IMO.
I'm not a lubrication engineer though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
FT-86 SpeedFactory (02-01-2013)
Old 01-15-2013, 10:45 AM   #16
gmookher
270 is high I'd try a bigger cooler setup or better ducting
250 or cooler yet -in the low 240s is ideal for me
on an SC setup oil temp is really the only thing I watch and its not for the sc its for the motor
once boost is dialed in, u dont need to see what it is
Old 01-15-2013, 10:53 AM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Agreed that it would be better, but unfortunately it's hard to prove anything one way or the other. There are probably 200 race hours on this motor with 300 degree (at the plate) oil temps. Leakdown, compression, etc hasn't changed measurably at all. The previous engine lasted over that number of hours.. plus 214,000 HPDE/Street miles before it was raced.
That's why I'm fine with 270 or so, I haven't seen it cause any issues at all in my other cars with a lot more abuse than my BRZ will likely ever see. I know there's a massive logical fallacy in that arguement, but without a large number of statistics it's the same logical fallacy in the other direction.. both arguements are post hoc ergo propter hoc.
What's your opinion on oil weights? In the past I've adjusted based on clearances. So far I've kept to 0W-20 but was considering a swap to some 0W-30.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-15-2013, 11:18 AM   #18
CSG Mike
CSG Mike's Avatar
We haven't had any problems with our 2nd engine... the 1st engine's failures were not oil related at all.
We've ran some 30 minute sessions on both engines, sometimes back to back. 5W30 300V for both engines.
I run 300V in my s2k, and while the oil does get toasty (with the factory cooler), UOA shows no problems, and my engine is still strong after 115k mixed miles.
Old 01-15-2013, 12:24 PM   #19
orthojoe
Subscribed to a great an informative thread. I'd let to know if oil temps truly are an issue when tracking this car or not. I'm going to put an inquiry to AiM to see if they can work on adding the oil temp channel, since it's apparently available through the obd2 port. Mike, do you guys run an oil cooler?
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 01-15-2013, 12:32 PM   #20
CSG Mike
CSG Mike's Avatar
Not yet... although we've always planned on getting one at some yet-undetermined point.
orthojoe (01-15-2013)
Old 01-15-2013, 01:43 PM   #21
gmookher
Can it be done piece meal by someone with experience? sure
is the kit they sell nicely put together? yes
worth it? yes
Its a nice pc of kit I am buying for our other BRZ as well. from them. full price minus a lil discount, I'm a pretty frequent flyer. They are making a standard% on the item in my estimation,seems reasonable.
I dont think I would go and try and assemble this all to try and save $80-$100 bucks at the end.
got aPM asking for pics of feet, this is off perrins blog
I like the FEET, the kit works, heck I have tracked and tested the shit out of it for them.
There is a spacer they machined too for the puck that you need if doing self assembly. I can dig up a pic if you want..
Old 01-15-2013, 01:51 PM   #22
sw20kosh
Drives: 2013 Black FR-S
So the verdict so far is:
Our oil does get hot (130C) during track driving but it doesn't cause any catastrophic failure. To be safe though, plan on getting an oil cooler.
Old 01-15-2013, 01:51 PM   #23
gmookher
are you aware of the cST you are running at 7000 rpms? Its exceeding the viscosity ideal for this oil pump, and no, at 7k it doesnt matter, but at 8k, it might
I also suspect youre loosing HP and TQ to viscosity. try tracking on fresh fill of 0w20(subaru SM is fine! if you want the good stuff the motul 0w20 is nice too), it also is faster at transfering heat than 5-30 so you will run cooler than you are now, and that may matter 5 months from now and have more power listening to my suggestion. if youre tracking it and change out your 0w20 every 3000 miles, you be GOLDEN. why the feel that you may benefit 5w30-'splain yoself!
if HTHS concerns you add a can of MOS2 like I do and you can raise the HTHS and pack load of your oil for a little extra coin you get better track protection than 5-30 with out the heat and power compromises of a thicker oil.
try it and and LMK what u find. dyno prove it if you doubt me!
once you keep the )w20 cooler, using the right cooler, you will see why I refer to 5w30 as the wrong oil
you will have more on tap esp up top
no offense meant, in my opinion the 5w30 hurting ya rather than helpin
-welcome(?)
Old 01-15-2013, 02:01 PM   #24
CSG Mike
CSG Mike's Avatar
-welcome(?)
We have every fluid tested at every changed by Blackstone
I posted a few, but had no interest in the threads, so I stopped posting them.
The dyno showed zero loss from oil viscosity; we have around 300 pulls on our car between the two engines, as well as dynos from other FRS/BRZ to contribute. None of the cars show a significant variance in power output going from a 20 to 30 weight.
Same goes for other components in the driveline; we're running Gear300 in the trans and Gear300LS (slight overkill) in the diff, again, with no measurable difference in output.
Old 01-15-2013, 02:03 PM   #25
CSG Mike
CSG Mike's Avatar
Old 01-15-2013, 02:21 PM   #26
gmookher
lets get you some 0w-20 sustina(its in my sump sitting on a dyno right now!)
would love your feedback,and VOA on that one too!
Old 01-15-2013, 02:23 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
worth it? yes
I like the feet too. I'll have to ask if I can buy the stands/feet. I didn't see the feet in your original pic thats why I was asking about them
I can't justify the whole kit when I literally have everything I need (except for the Mocal thermostate/spacer they use which I can get from them or anyone else, I'd buy it from them just to support them though) sitting on a shelf next to the racecar. It looks like a 13 row mocal core, which is a nice cooler. I have a 19 row mocal core here so if it doesn't fit I may just buy the whole thing from them. I don't mind spending the money, I just don't want to waste it when I have most of the parts already
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-15-2013, 08:28 PM   #28
orthojoe
Hmmm... Now I'm even more confused.
a) 0w-20 or 5w-30
b) oil cooler or no oil cooler
I'm only going to track the BRZ 3-4 times a year, so probably the best thing to do for now is keep everything stock....?
Why is gmookher banned?
2013 Subaru BRZ
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
