| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Ultramarine FR-S 6MT
Pinch weld jack point paint damage?
So I jacked my car up this weekend to do the usual tire-swapping work, starting at the front and then moving to the back. I picked up some jack stand pads, thinking they would protect the finish.
Turns out no. The pinch weld cut down in to the pad, and the pad material A) kind of scraped away at some of the paint, causing some to flake off and B) caused the layers of metal to separate slightly at one corner, kind of peeling apart. When I took the jack stands out the stupid pads were stuck to the car :@ Anyway, how should I go about touching up an area like this? I figured I would clean it with dawn dish soap, wipe down with alcohol, and then apply... something. Any ideas? |
#2 |
86 Noob
Drives: Firestorm FR-S
I believe they make a rubberized under body paint in a rattle can. Or you can just go with the regular primer/paint setup.
#3 |
Yeah, sort of what I figured.
Should I try to flatten it all back out? |
#4 |
86 Noob
Did you bend the pinch weld? I was under the impressions you just scrapped the paint off.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
#5 | |
I will take a pic this afternoon to illustrate what I'm talking about. Describing it is difficult
#6 |
That happened to me before on a past car. The previous owner must have jacked the car up from that side to do his oil changes. If it bothers you, you can use vice clamps to straighten the pinch weld back out, then coat it with underbody spray. May want to think about using a pinch weld adapter of some sort.
I fixed mine because the factory jack wouldn't work with the bent pinch weld.
2022 BRZ Build 2013 FR-S Build |
#7 |
Drives: '89 911, '06 GTI, '13 BRZ
I use hockey pucks. They are harder and will not cut. So far on my BRZ no damage to the pinch weld or the paint.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
#8 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#9 | |
Drives: 2013 BRZ, 2002 WRX
#10 |
#11 |
The Answer
Drives: Mazda 2
Lift it from the front subframe and rear diff instead...pinch weld damage is always bound to occur.
#12 | |
got a floor jack just for this but I hate the idea of working supported only by the jack. So I put the stands on and this jazz happens.
#13 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
For swapping wheels/tires, I never use jack stands, because I'm never under the car. Just a floor jack with a hockey puck (with a slit cut in it) to protect the pinch weld, and I lift one side of the car at a time. Works great, no damage to the pinch weld or paint.
When I do need to use jack stands, I have some poly jack stand pad protectors that I believe are made by Prothane, that I bought at Summit. They do not get cut by the pinch weld when supporting the weight of the car, even on much heavier cars like my Mustang.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#14 | |
| Does Vinyl Wrap Damage Paint? | GhostofAkina | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 01-09-2013 01:54 AM |
| What is the point of this car? | dem00n | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 10-09-2012 03:31 AM |
| Minor paint damage | Double4Free | Great Lakes | 8 | 07-23-2012 07:35 PM |
| BRZ at Point Mugu, CA | ashtray | BRZ Photos, Videos, Wallpapers, Gallery Forum | 5 | 07-01-2012 06:52 PM |
| All it needed was some JB Weld... | 82mm 4g63 | Other Vehicles & General Automotive Discussions | 2 | 09-15-2011 08:12 PM |
