Old 01-12-2013, 09:21 AM   #2059
hooman
hooman's Avatar
Drives: GTS86
I can't wait!
hooman is offline   Reply With Quote
Old 01-12-2013, 05:17 PM   #2060
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Bump for intake pictures
Tansey86 is offline   Reply With Quote
Old 01-12-2013, 05:36 PM   #2061
mact
Drives: 13 GTI
Originally Posted by Tansey86 View Post
Are we limited to only AVO made turbos for this kit? If not can share what lineup we could use if we had to replace one?
I always had a similar question running through my head regarding aftermarket kits. When it comes to maintenance/repair/upgrades, what are the options and costs..
I wonder how many OEM sourced, cheap and readily available turbochargers would be good match for this motor?
mact is offline   Reply With Quote
Old 01-14-2013, 08:46 AM   #2062
gmookher
what stress testing, and high heat testing has been done with the one avo stateside test car? anything documenting that its been thru the 111F litmus test at full load?
when is paul coming to PHoenix to do said testing? or will the kit be for sale without this sort of stress testing done by vendor? I want to get on the track with this car.
I will be tracking mine after I get it from Vortech, in Caliofornia, maybe paul can drive down? Thats the only test rig right?
We see 100 degrees here by march...I've cooked turbo bearings by lunch on a car not setup to run cool enough. ymmv
Old 01-14-2013, 02:23 PM   #2063
AVOturboworld
Why would we test the acidity of our turbo kit?
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (01-14-2013), BRZranger (01-14-2013), Dimman (01-14-2013), Drift-Office (01-15-2013)
Old 01-14-2013, 02:46 PM   #2064
Dimman
Kuruma Otaku
Dimman's Avatar
Maybe if you put those pH test strips on the motor somewhere and they burst into flames it is too hot?
Heh...
Because titanium.
The Following 2 Users Say Thank You to Dimman For This Useful Post:
MSTiFK8R (01-15-2013), Sportsguy83 (01-14-2013)
Old 01-14-2013, 04:21 PM   #2065
fenton
He means figuratively not literally.
Many people refer to this an experiment to determine the state of a project.
fenton is offline   Reply With Quote
Old 01-14-2013, 06:59 PM   #2066
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'll just leave this here....
The Following 12 Users Say Thank You to Sportsguy83 For This Useful Post:
2forme (01-14-2013), Alienate (01-15-2013), Brody602 (01-14-2013), BRZranger (01-14-2013), civicdrivr (01-14-2013), Draco_PR23 (01-14-2013), Drift-Office (01-15-2013), Nazarite (01-23-2013), seven (01-15-2013), Tansey86 (01-14-2013), thebear21 (01-17-2013), zohare (01-17-2013)
Old 01-14-2013, 07:37 PM   #2067
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
@AVOturboworld I realise extensive testing and tuning has been done but I do have one question, I live in Northern Ontario, the winter here reaches -20°C to -30°C and even colder (-4°F to -22°F). My question is, with the cold weather the air is a lot more dense, will the car still run properly off the base tune, or can I run into over boosting issues? Thank you
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
The Following 2 Users Say Thank You to Brody602 For This Useful Post:
AVOturboworld (01-15-2013), Sportsguy83 (01-14-2013)
Old 01-14-2013, 11:16 PM   #2068
AVOturboworld
With the standard secondary cat in place, you won't be running into overboost (boost spike) issues at those temperatures. Without the secondary cat (catless) or with a high-flow cat, that may change - but you better not be running on a stage 1 basemap at that point anyways!
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 01-15-2013, 02:33 AM   #2069
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Any single letter reg. Stage_2 figures & availability is highly awaited
that's what I'm in for
MSTiFK8R is offline   Reply With Quote
The Following 2 Users Say Thank You to MSTiFK8R For This Useful Post:
Alienate (01-15-2013), itdansharpe (01-15-2013)
Old 01-15-2013, 02:43 AM   #2070
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
I suppose he should throw in an oil cooler for free too right?
Unless something changed recently, AVO provides a power solution, not a cooling for track solution.
If a car you owned wasn't setup to run cool enough, that's YOUR (or whomever you paid to setup the car's cooling system's) fault.
I wouldn't have called East Coast Supercharging if my coolant boiled over on my corvette because they sold me a cam/heads and flycut my pistons. Nor would I call Carbotech if my brake fluid boiled over when they sell the pads only.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
The Following 3 Users Say Thank You to seven For This Useful Post:
BRZranger (01-16-2013), MSTiFK8R (01-15-2013), Sportsguy83 (01-15-2013)
Old 01-16-2013, 11:36 PM   #2071
Sportsguy83
Drives: Limited BRZ
Any updates on Stage 2? @AVOturboworld
Old 01-17-2013, 02:41 AM   #2072
AVOturboworld
Nothing complete - Tokyo Auto Salon took a big dent out of our time, and our next big task is getting Stage 1 kits in boxes and out to customers!
But that's not to say there isn't anything going on - the AVO FR-S has been through some power abuse on a dyno, and we've certainly seen some gains. Waiting on some exhaust before we go any further.
Alienate (01-17-2013), BRZranger (01-17-2013), Drift-Office (01-17-2013), Sportsguy83 (01-17-2013)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
