Old 01-12-2013, 07:58 PM   #15
OrbitalEllipses
Drives: Attitude
True...but TIC/MAW always has good shit. Though like I said, I went Group-N because it was still rubber and didn't change NVH except start-up. I needed new mounts anyway and it was a cheap solution that provided the least cons for me.
Regardless of user experience I would always prefer tailor-made rather than adapted parts. While the use of a spacer may not be entirely deleterious to the design/use of the part, it says something to me.
OrbitalEllipses is offline
Old 01-12-2013, 09:19 PM   #16
Supermassive
Supermassive's Avatar
How much do these run? Are they available right this second, because my car is technically in a perfect situation to get these on since it's just in pieces waiting for my damn turbo to arrive in the mail...
Supermassive is offline
Old 01-12-2013, 09:38 PM   #17
gmookher
I dont have my car now, so you can have these so long as you order a 2nd set for me-did the ups truck bring you the turbo friday?
gmookher is offline
Old 01-12-2013, 11:08 PM   #18
nonicname
Drives: it has 4 wheels and a motor
do they cause unbearable vibrations in the cockpit that will loosen the already loosened car?
nonicname is offline
Old 01-13-2013, 01:16 AM   #19
Supermassive
No turbo yet...I am a walking frowny face right now. Just PM the cost and whenever you can come over we'll install them should be cake since the headers are off!
Old 01-13-2013, 09:48 PM   #20
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Got these on the way for our build as well. Good for the track guys. DD people stick with the stock mounts.
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
gmookher (01-13-2013)
Old 01-13-2013, 09:53 PM   #21
gmookher
lets talk monday AM...
gmookher is offline
Old 01-13-2013, 10:01 PM   #22
nix
nix's Avatar
Drives: AVO BRZ
We are gonna install these on the BRZ at the same time as the turbo, already noticed a lot more engine movement on the dyno after installing stiffer tranny mount.
nix is offline
Old 01-13-2013, 10:09 PM   #23
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Without having them on the car it will be hard to say how bad NVH will increase, but you can be sure it will increase.
Sent from my Nexus 7 using Tapatalk HD
Ricepuddin is offline
Old 01-13-2013, 10:25 PM   #24
gmookher
maybe perrin can chime in?
gmookher is offline
Old 01-14-2013, 12:33 AM   #25
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Which shift mount are you using?
When you say movement what do you mean?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline
Old 01-14-2013, 01:50 AM   #26
nix
nix's Avatar
Drives: AVO BRZ
Cusco. It's just a normal lateral engine movement caused by sudden change in rotational force of the flywheel/drive line but it's exaggerated now since the engine is still soft oem mounts and transmission is stiffer.
nix is offline
The Following User Says Thank You to nix For This Useful Post:
DriftEightSix (01-14-2013)
Old 01-14-2013, 01:56 AM   #27
Racecomp Engineering
This question is directed to Jeff:
With Group-N mounts on a WRX or STI, most notice after a few hundred miles that the mounts "break in" and the vibration at idle is NO where near as bad as it was initially. My question is.....do you think this ENERGY bushing you use, ..will "break in" and mellow out some of the initial vibration?
Myles Williams
RCE
ps: Love my exhaust on the BRZ.
Racecomp Engineering is offline
whataboutbob (01-16-2013)
Old 01-14-2013, 03:35 AM   #28
gmookher
And I hope Jeff answers, but I will add what I can:
I have urethane motor mounts on other cars, and yes, there is some break in over time. Not alot, not like rubber mounts.
But alot more time, not two weeks lor just a few hundred miles ilke rubber. Seems heat is key for the breakin, normal use will do it, in time.
gmookher is offline
Whiteline Com-c top mounts sw20kosh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 349 05-27-2015 05:15 AM
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-11-2013 11:31 PM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 08:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 10:48 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 07:07 PM
