Old 01-12-2013, 02:59 PM   #1
fastfrs
Drives: frs
race/track car
doing some research for my build and i need some help. my car will be a track only race car. but i need help with a few parts, i come from the nissan world and this car is built way different.
i need help with SOLID SWAYS and REAR CAMBER
again this will be a track only car. opinions and thoughts are needed
fastfrs is offline   Reply With Quote
Old 01-12-2013, 06:29 PM   #2
Racecomp Engineering
Need more information. What is your suspension set up now and do you have any planned mods? And what tires?
- Andrew
Old 01-12-2013, 06:43 PM   #3
gmookher
whiteline sways
whiteline rear camber bushes
lca's from several vendors
Old 01-12-2013, 06:47 PM   #4
fastfrs
Drives: frs
right now all stock
will go with kw v3 coils, vorshlag front camber. ill be running enekis (17s) with RS3 tires. most likely AP racing brakes. gt spec bars all around.
is whiteline solid?
Old 01-12-2013, 07:21 PM   #5
driver01
Drives: brz 13
whiteline Rear Sway bar - 16mm heavy duty blade adjustabl
whiteline Front Sway bar - 22mm heavy dut
Kw v3
vorschlang camber plates
cusco rear lower control arms
whiteline for front control arms bushings, rear subframe, differential, transmission mount.
perrin engine mounts.
ap racing sprint brakes
thats my setup, I could use some help with the tuning regarding sway bar, shocks and alignment settings, and your setup looks identical to mine
whiteline sway bars are solids
driver01 is offline   Reply With Quote
Old 01-12-2013, 07:26 PM   #6
fatoni
i would recommend deciding not to make a track only car until you know what you want. things like street tires and strut bars are kinda wasted on a track car. the best thing to do in search of a track car would be to just buy a spec miata for a fraction of the price.
Old 01-12-2013, 10:10 PM   #7
CSG Mike
CSG Mike's Avatar
What's your long term plan? What's your budget?
Old 01-12-2013, 10:56 PM   #8
fastfrs
Drives: frs
long term plan is trailer only race car. life long budget lol i want quality. i want the best. things like trunk struts im not looking into. my car will be caged.
ive been racing cars for a long time now, i know how a car should behave on a track and under extreme conditions. i just need to know the corrrect adjustable parts so i can adjust after each track session.
Old 01-12-2013, 11:00 PM   #9
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
What parts do you want to adjust? Check in to cortex they have some pretty awesome looking suspension parts.
Old 01-12-2013, 11:06 PM   #10
fastfrs
Drives: frs
would the bigger front and rear sways cause too much under/oversteer? i mean it is adjustable. so y not have it just for the drift days (i perfer to grip n go instead of drifting). also isnt the gtspec rear camber arms better built?
Kw v3
Old 01-12-2013, 11:07 PM   #11
fastfrs
Drives: frs
camber/caster, sways, coils
Old 01-12-2013, 11:15 PM   #12
JoeBoxer
JoeBoxer's Avatar
Yeah check out cortex they have some front lower control arms you would be interested in. For sways I'm a big whiteline fan and they also have some rear lower control arms coming out soon.
Tein src coilovers (highly recommended by CSG)
Cortex front LCA
Whiteline rear LCA
Whiteline front and rear adjustable sways
Ap racing endurance bbk
Should be a good start for a track car from what I have seen.
Old 01-13-2013, 12:16 AM   #13
CSG Mike
CSG Mike's Avatar
What's the short term plan? Budget for now?
W2W? Time attack? Weekend track car? Classing? Restrictions?
Weight and power goals?
What is your driving experience? What classes have you raced? What cars have you previously driven? What mods? How do you want the car to behave?
The more information you provide me, the more I can provide for you. I don't like recommending parts for the short term that are eventually going to get replaced in the long term, and I can make recommendations for any budget, but I gotta know what your eventual goal is to do so.
JoeBoxer (01-13-2013)
Old 01-13-2013, 03:22 AM   #14
fastfrs
Drives: frs
short term is DD and weekend track car. ive done time attack mostly, few drift event but mehh i like grip and laptimes more. i enjoy doing hot laps, getting the fastest times possible. weight is as low as possible, power for this car i want 280-320whp. ive been racing starting with karts since i was 13. my frist and second track car was both a 350z (ive had 2). ive always signed up in the super advanced class. ive had a few power mods but mainly was chasis/handling/braking/r-compounds. thats all i need, but this car is way underpowered. i dont believe in doin work twice, if imma get a mod, i will save up and get the correct mod the first time, not go back and change things, only things i would change is adjustments.
Hutchinson Island Race Track Savannah Georgia BillyStrato Southeast 6 12-24-2012 09:20 PM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
Got to test a FR-S on the Race Track on Saturday gbhstrat Scion FR-S / Toyota 86 GT86 General Forum 5 09-24-2012 07:16 PM
Track Race circuit aloretoc Southeast 3 08-08-2012 11:55 AM
Toyota 86 race track? sneaky AUSTRALIA 6 06-14-2012 10:56 PM
