Old 01-11-2013, 01:47 PM   #239
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
George, I have a Hotchkis bar in as a temporary solution until Sam's is ready. If you want, you can give mine a try anytime (Id say this weekend if you were coming to Sebring ). It's slightly softer on its current setting than Sam's but I wanted something to help with the camber challenged car.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 01-11-2013, 02:02 PM   #240
cityhugo
Drives: white
FYI: from my understanding, that bar is more then 2x stiffer then Sams bar even in the soft setting. No way it is softer...
cityhugo is offline   Reply With Quote
Old 01-11-2013, 02:06 PM   #241
Kido1986
Dodging cones
Kido1986's Avatar
The percentages are lower on the soft setting from what I read. Maybe I read it differently?
It says 170% (which is actually 70% due to the way swaybar manufacturers tend to advertise, read Sam's website). Sam's is 185% (true 85%) I believe
Edit: Link - http://www.stranoparts.com/partdetai...235&ModelID=36
Old 01-11-2013, 02:13 PM   #242
xwd
The Hotchkis 25mm is rated at 170% stiffer than stock, the Strano bar is roughly 85%. Both use increase over stock and not the 100%+ increase like the JDM vendors seem to do.
The Hotchkis would be 270% vs 185% for the Strano, its a big bar.
Old 01-11-2013, 02:27 PM   #243
Kido1986
Dodging cones
Kido1986's Avatar
Oh really? I didn't realize that. Is this for sure? I was so used to everyone else's ratings. I still plan on getting Strano's then selling the Hotchkis, got it as a temporary.
Old 01-11-2013, 04:43 PM   #244
xwd
Just to double check I looked at some of the other bars Hotchkis sells like the WRX rear bar and they list the rates as like "87%, 115%, etc." so they definitely do not add the 100% like Cusco, Tanabe, and others do. Just using logic, a 25.4mm hollow bar is going to be stiffer than a 22mm hollow bar.
Old 01-11-2013, 05:06 PM   #245
Kido1986
Dodging cones
Kido1986's Avatar
Well damn. We'll see how it does this weekend. I like the way it changed the response in street driving. I have still been able to oversteer a bit so hopefully it's not TOO damn stiff!
Old 01-11-2013, 05:57 PM   #246
simpleisbest
Senior Citizen
Drives: Scion FR-S
Im pretty sure that the Strano bar is 185% vs stock. I remember Sam explained that he didn't like some the industry terminology about sway bar rates and this chose to rate the bar as 85% stiffer than stock, vs x1.85 or 185% of stock. Ironic that his efforts to use clearer terminology led to this confusion...
So on the softer setting the Hotchkis bar would be softer or about the same as the Strano bar...(big assumption!!).
simpleisbest is offline   Reply With Quote
Old 01-11-2013, 06:15 PM   #247
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
What DXW said is correct, it is 1.85x for the Strano bar hotchkis is 2.70x. Hotchkis advertises 500 ft/lbs for their soft setting. There is no way the stock bar is the better part of 300 lbs/in. The hotchkis bar is not softer than the Strano part.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 01-11-2013, 06:22 PM   #248
cityhugo
Drives: white
Car will push like a pig on exit, but it will feel great in a airport course like serbing, lol. can't use street driving to judge...
Old 01-11-2013, 06:37 PM   #249
Kido1986
Dodging cones
Kido1986's Avatar
I know, I dont except street to give me an indication of performance.
It was a last minute decision to go to that bar as a temporary one. Going to stagger pressure to try to neutralize it. Who knows, it may work well
Never autocrossed out there before (just track days). What makes their layout good for a understeer setup?
Old 01-11-2013, 07:31 PM   #250
cityhugo
Drives: white
I havnt been but from looking at youtube the course is long and narrow so not so much the understeer but ur transition will feel great.
Old 01-11-2013, 08:27 PM   #251
Kido1986
Dodging cones
Kido1986's Avatar
That's what Im going for. Transitions before had a lot of oversteer, even with .12 degree toe in on each side. Im at .10 now
Old 01-12-2013, 12:33 PM   #252
xwd
Had a chance to check out my grinding noise this morning. I took a good look, loaded the suspension and turned the wheels and nothing. I did kind of bend back the brake shield on the side making noise. In the end after dorking around with it for an hour I didn't have anything conclusive. Took the car back out and beat on it, no more noise... I guess I fixed it. .
I did the same parking lot tests I did with the Whiteline bar on its two settings and the Strano bar seems not quite as stiff as the Whiteline on its "21mm" setting. My parking lot test is a mock slalom, stock tires. Both bars mad the car feel a lot more stable than stock. I'm at like 1/16" total toe in.
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
What SCCA autocross class will the FRS be most competitive SVThis Tracking / Autocross / HPDE / Drifting 5 07-30-2012 04:29 PM
Share/discuss (this mornin) 86 Newsletter... RebootWindows AUSTRALIA 6 07-19-2012 04:15 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
Discuss.... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 12 02-11-2012 12:55 PM
